Home » Eclipse Projects » DSDP - Target Management » FTP Passive setting doesn't work?
FTP Passive setting doesn't work? [message #12105] Wed, 11 July 2007 12:27 Go to next message
Originally posted by: csete.nospam.com
I'm playing with Target Management and I definitely like the concept. I
created an FTP connection to my web hosting site and specified a passive
connection. It worked fine for a while, but now it won't work anymore.
If I look in the properties, I see that it is still specified as
passive, but TM is always initiating a non-passive connection and I get:
PORT 192,168,0,22,14,66
500 I won't open a connection to 192.168.0.22 (only to xxx.xxx.xxx.xxx)
in the console.
Am I doing something wrong here or is there a bug in passive connection
handling?
Craig
Re: FTP Passive setting doesn't work? [message #12157 is a reply to message #12105] Thu, 12 July 2007 10:00 Go to previous messageGo to next message
Hi Craig,
I could reproduce this issue and it looks like a bug.
Could you file a bug in bugzilla for this?
For me, it looks like FTPConnectorSerivice.java line 99,
_ftpService.setPropertySet(_propertySet);
should be changed to
_ftpService.setPropertySet(getPropertySet("FTP Settings"));
but I'm not the owner of that component.
Martin Oberhuber
Target Management Project Lead, DSDP PMC Member
http://www.eclipse.org/dsdp/tm
> in the console.
> handling?
> Craig
Re: FTP Passive setting doesn't work? [message #12936 is a reply to message #12157] Wed, 18 July 2007 15:10 Go to previous message
I now created
https://bugs.eclipse.org/bugs/show_bug.cgi?id=196632
for this issue.
Martin Oberhuber
Re: FTP Passive setting doesn't work? [message #568830 is a reply to message #12105] Thu, 12 July 2007 10:00 Go to previous message
Hi Craig,
Martin Oberhuber
> in the console.
> handling?
> Craig
Re: FTP Passive setting doesn't work? [message #568976 is a reply to message #12157] Wed, 18 July 2007 15:10 Go to previous message
I now created
for this issue.
Martin Oberhuber
Previous Topic:Does TM and the Terminal view support a nested and heterogenous connection?
Next Topic:Does TM and the Terminal view support a nested and heterogenous connection?
Current Time: Tue Jul 22 12:02:20 EDT 2025
Powered by FUDForum. Page generated in 0.03996 seconds
