Home » Archived » Maven Integration (M2E) » Maven embedder
Maven embedder [message #1008] Thu, 17 April 2008 02:29 Go to next message
I guess m2eclipse is using the Maven Embedder technology. We (Buckminster) would like to do that
too. What is the status of the Maven Embedder technology? Has it been formally released yet? Has it
been blessed with regards to the Eclipse IP process?
Another more open question is where this project and Buckminster touch base. What are our
differences and where do we share a common ground? Are there any parts that we can do together? Any
integration points that would give the user great benefits?
Kind Regards,
Thomas Hallgren
Re: Maven embedder [message #1223 is a reply to message #1008] Thu, 17 April 2008 23:54 Go to previous messageGo to next message
Isn't Buckminster having overlaps with Kepler?
Rahul
Thomas Hallgren wrote:
> (Buckminster) would like to do that too. What is the status of the Maven
> Embedder technology? Has it been formally released yet? Has it been
> base. What are our differences and where do we share a common ground?
> Are there any parts that we can do together? Any integration points that
> Kind Regards,
> Thomas Hallgren
Re: Maven embedder [message #1249 is a reply to message #1223] Fri, 18 April 2008 02:05 Go to previous messageGo to next message
Hi Rahul,
The Kepler proposal was revised specifically to avoid such overlap.
Kind Regards,
Thomas Hallgren
> Rahul
>> Kind Regards,
>> Thomas Hallgren
Re: Maven embedder [message #3619 is a reply to message #1008] Tue, 29 April 2008 01:32 Go to previous messageGo to next message
In article <fu6qon$cd8$1@build.eclipse.org> Thomas
Hallgren<thomas@tada.se> wrote:
We actually use any external version of Maven or the embedder for
execution, but the embedder is used for dependency resolution and
provides access to Plexus to execute components like Maven Archetype
and Maven SCM.
No formal releases of 2.1 where the embedder lives.
I was hoping that the Buckminster project had started on the IP
process :-)
> touch base. What are our differences and where do we share a common
> ground? Are there any parts that we can do together? Any integration
We are focused on Maven integration so if there are any Maven
technologies you are planning on using we can definitely collaborate
there.
What do you see as the common ground?
> Kind Regards,
> Thomas Hallgren
I'm trying a new usenet client for Mac, Nemo OS X.
You can download it at http://www.malcom-mac.com/nemo
Re: Maven embedder [message #3650 is a reply to message #3619] Tue, 29 April 2008 03:10 Go to previous messageGo to next message
> process :-)
We tried but Eclipse EMO refuses to touch things that has not yet been released. I.e. a formal
release is a prerequisite to get the IP process started.
> there.
Two things I think. One is of course to use a common set of IP approved Maven libraries :-). The
other is that since both Buckminster and Maven can orchestrate a build, I'd like to see Buckminster
'actors' that can call on Maven goals and vice versa so that a user can integrate between them
seamlessly.
Thomas Hallgren
Re: Maven embedder [message #3683 is a reply to message #3650] Tue, 29 April 2008 10:37 Go to previous messageGo to next message
In article <fv6hnm$1up$1@build.eclipse.org> Thomas
>> process :-)
> been released. I.e. a formal release is a prerequisite to get the IP
> process started.
If anyone can make a formal release happen that would be our team.
It's really drawing a line in the sand and I could make an official
release tomorrow but I think what's really important is that from an
IP perspective you can validate a set of pieces and if that set of
pieces doesn't change then the constraints on the IP are still valid.
If a project can't be provisioned until the IP is cleared from an
official release then that's fair. I'm in no dire rush honestly, I'm
more interested in making the integration work correctly for users.
>> there.
> approved Maven libraries :-). The other is that since both
There are all sorts of things happening to make this happen. One is
moving one of Maven's base dependent projects, Plexus, to Apache. I
have also started doing all the legwork to put this in motion. So
we're working on Maven on a daily basis and I'm doing the necessary
administrative work as well.
> Buckminster 'actors' that can call on Maven goals and vice versa so
> that a user can integrate between them seamlessly.
I honestly don't know a lot about Buckminster and it's capabilities,
but I would certainly defer to Maven users' desires in this regard. If
they are looking for integration with Buckminster then I'm happy to
work toward providing that.
> Thomas Hallgren
Re: Maven embedder [message #4581 is a reply to message #3683] Sun, 04 May 2008 08:53 Go to previous messageGo to next message
I think that pushing an official Embedder release is something that
maybe the three teams (Buckminster, IAM and M2E) can work together.
IAM is using the embedder as the runtime for every operation, while M2E
is not using it so much in favor of external maven executions (as I read).
The embedder is external to eclipse, so it's "officially" the focus of
any project, but the three will benefit from it.
Jason, maybe you can "draw the line" and we can help in pushing the
embedder towards it? Having a roadmap would also help.
Also, it would be useful to have the embedder bundle pushed into Eclipse
Orbit.
I'm cross posting this to the IAM group so we all stay on the same page
regarding possible collaboration.
>>> process :-)
>> process started.
>>> there.
>> Regards,
>> Thomas Hallgren
Re: Maven embedder [message #4928 is a reply to message #4581] Mon, 05 May 2008 14:48 Go to previous messageGo to next message
In article <fvkbir$i0t$1@build.eclipse.org> Abel Muiño
I'm in the process of gathering feedback from users, and this week
while a few of us are at JavaOne I plan to conduct a series of
interviews to guide the roadmap for 2.1 of which the embedder is an
important part. You can always post suggestions and when the concrete
roadmap is done I plan to solicit feedback starting work. There will
be a lot of work that the community can contribute to.
> M2E is not using it so much in favor of external maven executions (as
> I read).
> of any project, but the three will benefit from it.
> Eclipse Orbit.
> page regarding possible collaboration.
>>>> IP process :-)
>>> yet been released. I.e. a formal release is a prerequisite to get
>> valid. If a project can't be provisioned until the IP is cleared
>> from an official release then that's fair. I'm in no dire rush
>> honestly, I'm more interested in making the integration work
>>>> collaborate there.
>> is moving one of Maven's base dependent projects, Plexus, to Apache.
>> I have also started doing all the legwork to put this in motion. So
>> capabilities, but I would certainly defer to Maven users' desires in
>> this regard. If they are looking for integration with Buckminster
>> then I'm happy to work toward providing that.
>>> Regards,
>>> Thomas Hallgren
vQoxQqBuTP [message #15320 is a reply to message #4581] Fri, 22 August 2008 00:00 Go to previous message
Originally posted by: lqyxga.dfoemc.com
aTI42C <a href="http://eermvhgtaujr.com/">eermvhgtaujr</a>,
kezbzjwamdof,
wkrwlbbtbonj[/link],
http://tjmidjqovnhi.com/
Previous Topic:maven newbie question
Next Topic:stable dev build 0.9.6.20080822-1053 is published
Current Time: Thu Nov 20 20:11:53 EST 2025
Powered by FUDForum. Page generated in 0.25993 seconds
