Home » Eclipse Projects » GEF » Rare bug under eclipse 2.1
Rare bug under eclipse 2.1 [message #132231] Sat, 15 May 2004 04:02 Go to next message
Originally posted by: contact.jasperassistant.com
We've received the following bug report which seems on the first sight
to originate from GEF. It appears under eclipse 2.1.2 using GEF 2.1.2.
See stacktrace below.
Peter Severin.
- JasperAssistant Team.
Appears very seldom.
org.eclipse.gef.internal.ui.properties.UndoablePropertySheet Entry.refreshChildEntries(UndoablePropertySheetEntry.java:47 3)
org.eclipse.gef.internal.ui.properties.UndoablePropertySheet Entry.refreshFromRoot(UndoablePropertySheetEntry.java:521)
org.eclipse.gef.internal.ui.properties.UndoablePropertySheet Entry.access$2(UndoablePropertySheetEntry.java:519)
org.eclipse.gef.internal.ui.properties.UndoablePropertySheet Entry$3.commandStackChanged(UndoablePropertySheetEntry.java: 587)
org.eclipse.gef.commands.CommandStack.notifyListeners(Comman dStack.java:186)
at org.eclipse.gef.commands.CommandStack.execute(CommandStack.j ava:89)
at com.jasperassistant.designer.y.execute(SourceFile:54)
org.eclipse.gef.internal.ui.properties.UndoablePropertySheet Entry.valueChanged(UndoablePropertySheetEntry.java:720)
org.eclipse.gef.internal.ui.properties.UndoablePropertySheet Entry.valueChanged(UndoablePropertySheetEntry.java:717)
org.eclipse.gef.internal.ui.properties.UndoablePropertySheet Entry.setValue(UndoablePropertySheetEntry.java:649)
Re: Rare bug under eclipse 2.1 [message #132775 is a reply to message #132231] Tue, 18 May 2004 14:53 Go to previous message
Is there also a Widget is disposed exception before this?
"JasperAssistant" <contact@jasperassistant.com> wrote in message
news:c84ic3$o2q$1@eclipse.org...
> Best regards,
> Peter Severin.
> java.lang.NullPointerException
> at
ldEntries(UndoablePropertySheetEntry.java:473)
> at
> at
> at
tackChanged(UndoablePropertySheetEntry.java:587)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Previous Topic:Connections in GEF with EMF: ClassCastException
Next Topic:custom units via graphics object
Current Time: Fri Oct 17 18:30:09 EDT 2025
Powered by FUDForum. Page generated in 0.08245 seconds
