Home » Eclipse Projects » GEF » Draw2D
Draw2D [message #132219] Fri, 14 May 2004 19:56 Go to next message
Originally posted by: jsk_lam.hotmail.com
I am new to GEF and Draw2D. What I need to do is to render some readonly
images (gif/bmp/jpg) in the view and connect them with lines. Is it
possible to do this with Draw2D alone without using GEF? The images
should be listening to the mouse click events so I can display a context
menu. Also, I would like to be able to hide and show the images base on
some criteria. Does anyone know how to show and hide the graphical images
on the fly? Do I have to use GEF at all? Thanks.
sl.
Re: Draw2D [message #132287 is a reply to message #132219] Sun, 16 May 2004 09:36 Go to previous messageGo to next message
Originally posted by: rlemaigr.ulb.ac.be
I am +- new to gef and draw2d too so my answer may be wrong or inexact.
To do all you want, I don't think you need gef, draw2d should be enough.=
About images:
There is a class in draw2d that allows you to show images in draw2d =
Figures: ImageFigure.
About connections:
There is classes in draw2d that allow you to make connections between =
other figures in a relatively easy way:
There is an interface for connection in draw2d named Connection. A =
Connection is a figure that has a ConnectionRouter and ConnectionAnchors=
- the ConnectionAnchors tell the connection about what the positions of =
its endpoints should be, and notify the connection when the positions of=
the endpoints have changed and the connection must be revalidated.
- the ConnectionRouter lays out the intermidiate points of the connectio=
n =
between its endpoints.
The implementation of Connection you should use is PolilyneConnection.
They are many implementations of ConnectionRouter provided in draw2d. Yo=
u =
choose the best for your needs.
They are also many implementation of ConnectionAnchors in draw2d. Most o=
f =
them are associated with a Figure and notify their associated connection=
s =
when this figure moves.
So by setting the ConnectionRouter, you specify how the intermidiate =
points are located, and by setting the ConnectionAnchors, you specify ho=
w =
the connection will connect to its source and target Figures and what =
these source and target figures are.
I think connections should be placed in a particular layer to allow them=
to stay on top of everything else. If I have good memory, there is a cla=
ss =
for that: ConnectionLayer. Check the javadoc.
About mouse events:
Draw2d support routing of mouse event to figures, so you can add mouse =
listeners to figures to do what you need. About the menu thing, I don't =
know. Maybe you should add this menu to the swt control below draw2d, an=
d =
use draw2d to find wich figure is below the mouse pointer, using =
findFigureAt(...). I don't know.
About hiding/showing images:
I think using the setVisible(boolean) method of IFigure is the solution =
to =
that.
You could also take a look at the package "graph" of draw2d.
Hope this will help you,
r=E9gis
On Fri, 14 May 2004 23:56:50 +0000 (UTC), sl <jsk_lam@hotmail.com> wrote=
> I am new to GEF and Draw2D. What I need to do is to render some readon=
ly
> should be listening to the mouse click events so I can display a conte=
xt
> menu. Also, I would like to be able to hide and show the images base =
on
> some criteria. Does anyone know how to show and hide the graphical =
> images
> sl.
Re: Draw2D [message #132878 is a reply to message #132287] Wed, 19 May 2004 03:31 Go to previous messageGo to next message
Originally posted by: m.hassenforder.uha.fr
I am also new in GEF, but I can suggest to read the article about
classDiagram in draw2d :
http://eclipse.org/articles/Article-GEF-Draw2d/GEF-Draw2d.ht ml
You have an example about : figures, connectors and layout.
bye
rlemaigr@ulb.ac.be wrote:
> About images:
> About connections:
> Connection is a figure that has a ConnectionRouter and ConnectionAnchors.
> of the endpoints have changed and the connection must be revalidated.
> connection between its endpoints.
> You choose the best for your needs.
> of them are associated with a Figure and notify their associated
> connections when this figure moves.
> how the connection will connect to its source and target Figures and
> what these source and target figures are.
> them to stay on top of everything else. If I have good memory, there is
> a class for that: ConnectionLayer. Check the javadoc.
> About mouse events:
> and use draw2d to find wich figure is below the mouse pointer, using
> to that.
> régis
> On Fri, 14 May 2004 23:56:50 +0000 (UTC), sl <jsk_lam@hotmail.com> wrote:
>> images
>> sl.
Re: Draw2D [message #133713 is a reply to message #132878] Sat, 22 May 2004 01:14 Go to previous message
Thanks all for the info:-)
sl.
> bye
> > Hi,
> > About images:
> > About connections:
> > About mouse events:
> > to that.
> > régis
> >> Hi,
> >> images
> >> sl.
Previous Topic:translatetoAbsolute question...
Next Topic:PAFEdit - GEF editor example
Current Time: Sat Nov 08 04:23:20 EST 2025
Powered by FUDForum. Page generated in 0.03242 seconds
