Home » Eclipse Projects » Equinox » Can p2 touchpoint actions be conditional? (Sun JVM vs. Apple JVM)
Can p2 touchpoint actions be conditional? (Sun JVM vs. Apple JVM) [message #132099] Fri, 29 May 2009 16:54 Go to next message
We are using a touchpoint action to add a VM arg that is needed as a
workaround when running on a Sun JVM. It seems that these options
may cause the Apple JVM to crash, so we would want to invoke the
touchpoint action ONLY WHEN running on a specific platform (ideally
depending on the current JVM, optionally based on the OS).
Question: is a concept of conditional actions for p2 touchpoints realized
or planned?
For the records, the JVM options in question are:
-XX:+UnlockDiagnosticVMOptions
-XX:+UnsyncloadClass
Running WITHOUT these options can cause class-loading deadlocks on Sun JVM
(as discussed in https://bugs.eclipse.org/bugs/show_bug.cgi?id=212262#c13 ),
running WITH these options seems to cause SIGBUS on Apple JVM.
Has anybody seen this?
thanks
Stephan
Re: Can p2 touchpoint actions be conditional? (Sun JVM vs. Apple JVM) [message #132152 is a reply to message #132099] Mon, 01 June 2009 12:41 Go to previous message
Hi Stephan,
Filtering is done at the IU level so you can creat an OS specific IUFragment
to do the JVM option adding.
With that said, I think instruction level filtering might be interesting so
why not open a bug to track this idea.
-Simon
"Stephan Herrmann" <stephan@cs.tu-berlin.de> wrote in message
news:gvpi1b$kt7$1@build.eclipse.org...
> or planned?
> (as discussed in
> thanks
> Stephan
Previous Topic:Classloading problem
Next Topic:Installing software using the p2 director application
Current Time: Tue Nov 04 03:11:36 EST 2025
Powered by FUDForum. Page generated in 0.24442 seconds
