Home » Archived » DSDP » Kertasarie VM
Kertasarie VM [message #12066] Fri, 04 May 2007 09:35 Go to next message
Originally posted by: Slawi.gmx.de
Hello together,
i'm doing currently my first steps in developing SW for embedded devices.
The current target device is a compaq with a WM 2002,
my aim is to evauluate an application with sockets and JNI. I wrote
already the java code for the usuall Java VM.
So - i read some paper and detected the Kertasarie VM.
I'm used to developing with eclipse but the Kertasarie doesn't offer any
libraries or similar stuff which i could use. Has someone experience with
this stuff?
Is there an API i could import into eclipse? Maybe even the text file API
which is availbe in the Kertasarie package, part of the avaiable text file:
de.uniro.ui.Bitmap
public class Bitmap extends Control{}
de.uniro.ui.Button
public class Button extends Control{}
public Button(String label, int x, int y, int width, int height){}
Maybe you can propose an other JVM (J2ME) for this scenario?
Re: Kertasarie VM [message #12080 is a reply to message #12066] Tue, 08 May 2007 10:50 Go to previous message
the folks on the eclipse.dsdp.mtj or eclipse.dsdp.ercp
newsgroups are the ones dealing with Java on the target,
you might want to try those newsgroups.
Martin Oberhuber
Target Management Project Lead, DSDP PMC Member
http://www.eclipse.org/dsdp/tm
Re: Kertasarie VM [message #571064 is a reply to message #12066] Tue, 08 May 2007 10:50 Go to previous message
Martin Oberhuber
Previous Topic:Kertasarie VM
Next Topic:RSE 1.0.1: Persisting property sets of an IHost
Current Time: Tue Jul 22 12:03:24 EDT 2025
Powered by FUDForum. Page generated in 0.03269 seconds
