Home » Eclipse Projects » Eclipse Platform » About Project Natures
About Project Natures [message #131982] Thu, 18 September 2003 10:05 Go to next message
Originally posted by: liziwen.eyou.com
when I create a project I must add the project nature extension
point,right?
After I add the nature to my project I must use the builder?Can I not
implement the builder in my project.Is it necessary?
Can I implement the compiler outside the eclipse and integrete the
compiler to the eclipse platform?How can I do it?
I have seen that the CDT Project use a xml file to configure the compiler
option then use compiler outside the eclipse to compile the c file.
Am I right?
Can you tell me how to make my idea true?
Thank in advance
Daniel
Re: About Project Natures [message #132501 is a reply to message #131982] Thu, 18 September 2003 16:01 Go to previous messageGo to next message
Originally posted by: John_Arthorne.oti.com_
> point,right?
It is not necessary to add a nature, but if you want to add a nature you
have to use the extension point.
No.
> Can I not implement the builder in my project. Is it necessary?
You can implement a builder, but it is not necessary.
Yes.
> How can I do it?
http://www.eclipse.org/articles/Article-Builders/builders.ht ml
Re: About Project Natures [message #133273 is a reply to message #132501] Fri, 19 September 2003 16:11 Go to previous message
You can also see how I've done exactly the same thing in
the old version of the RMI Plugin:
http://sourceforge.net/project/showfiles.php?group_id=53485& amp;release_id=144936
Genady
> Yes.
>> How can I do it?
Previous Topic:wsad and redhat 8.0
Next Topic:To change a treeviewer contents on expand event
Current Time: Fri Jul 18 05:58:08 EDT 2025
Powered by FUDForum. Page generated in 0.08543 seconds
