Home » Language IDEs » C / C++ IDE (CDT) » Can't delete a resource from the C/C++ Projects view
Can't delete a resource from the C/C++ Projects view [message #131953] Fri, 17 December 2004 00:20 Go to next message
Hello.
I have a problem when deleting a file from the C/C++ Projects view.
A confirm dialog pops up twice!!
I'm wondering this is a bug or not.
How my Eclipse works:
Using:Windows XP Pro. Eclipse 3.0.0. CDT 2.0.0.
1.Create a Standard Make C Project.
2.Create a new file to that project ex)xxx.txt
I won't see xxx.txt in the C/C++ Projects view.
3.Close and open the project.
Now xxx.txt appears in the C/C++ Projects view.
4.Select xxx.txt in the C/C++ Projects view and press the Delete key.
5.Confirm Resource Delete dialog pops up and I press Yes.
6.Confirm Resource Delete dialog pops up again, press Yes again.
7.xxx.txt still appears in the C/C++ Projects view.
Why does the Confirm Resource Delete dialog pop up twice?
Why does C/C++ Projects view continue to show a file that I deleted?
Does anybody know something?
Thanks.
Fujimoto.
Re: Can't delete a resource from the C/C++ Projects view [message #132001 is a reply to message #131953] Fri, 17 December 2004 03:14 Go to previous messageGo to next message
Try to use CDT 2.1 RC6, I havent seen this behaviour in that version.
Re: Can't delete a resource from the C/C++ Projects view [message #132171 is a reply to message #132001] Sun, 19 December 2004 20:16 Go to previous message
I tried the same thing with CDT 2.0.2.
It all worked out OK.
These problems must have been secretly fixed in the latest releases...
I learned my lessons.
Thank you Gael.
Previous Topic:Adding custom rules to a managed build/builder/whatever
Next Topic:Eclipse CDT consluting services?
Current Time: Tue Jul 22 12:06:55 EDT 2025
Powered by FUDForum. Page generated in 0.03617 seconds
