Home » Language IDEs » Java Development Tools (JDT) » UNIX Line Breaks on Windows Eclipse
UNIX Line Breaks on Windows Eclipse [message #131861] Tue, 06 January 2004 14:44 Go to next message
Is there any way to set the line break character sequence used by
Eclipse (2.1.2)? Although not a problem for Java source files, it has
been an occasional issue with some of the other files I edit through
Eclipse.
Thanks.
Re: UNIX Line Breaks on Windows Eclipse [message #131875 is a reply to message #131861] Tue, 06 January 2004 17:39 Go to previous messageGo to next message
On Tue, 06 Jan 2004 14:44:54 -0500, justin edelson
> Eclipse.
Under Help you will find:
Converting line delimiters
The Java editor can handle Java files with heterogenous line delimiters.
However other external editors or tools may not be able to handle them
correctly.
If you want to change line delimiters used by your Java files:
Open a Java file in the Java editor
Select Source > Convert Line Delimiters To from the menu bar
Select the delimiters to which you want to convert the file to (one of
CRLF, LF, CR)
John Zoetebier
Web site: http://www.transparent.co.nz
Re: UNIX Line Breaks on Windows Eclipse [message #131922 is a reply to message #131861] Wed, 07 January 2004 06:17 Go to previous messageGo to next message
Originally posted by: bob.news.gmx.net
"justin edelson" <justin@justinedelson.com> schrieb im Newsbeitrag
news:btf35n$cl2$1@eclipse.org...
> Eclipse.
You can set those other files to binary mode if you use CVS. Then line
endings should not be touched while most other functionality (e.g. version
diffs) still work as expected.
robert
Re: UNIX Line Breaks on Windows Eclipse [message #132087 is a reply to message #131875] Wed, 07 January 2004 13:46 Go to previous messageGo to next message
>> Eclipse.
> correctly.
> CRLF, LF, CR)
Right, but it looks like CRLF is always the default. I'd rather just use
LF as the default. Is this possible?
Re: UNIX Line Breaks on Windows Eclipse [message #132285 is a reply to message #132087] Thu, 08 January 2004 05:12 Go to previous message
news:bthk4e$878$1@eclipse.org...
> >> Eclipse.
delimiters.
> > correctly.
> > CRLF, LF, CR)
Eclipse uses that of the current platform. You can try to set system
property "line.separator" during VM startup.
robert
Previous Topic:Enabling edit checking for CVS in 3.0M6
Next Topic:Formatter and organising imports
Current Time: Wed Nov 05 22:42:24 EST 2025
Powered by FUDForum. Page generated in 0.05005 seconds
