Home » Eclipse Projects » Equinox » How to run the Equinox OSGi framework from within usual java code?!?
How to run the Equinox OSGi framework from within usual java code?!? [message #131690] Mon, 25 May 2009 05:50 Go to next message
Hi there,
I'm trying to understand how to use the class
org.eclipse.osgi.framework.internal.core.OSGi. Maybe someone can give me
an example?
BR,
Markus
Re: How to run the Equinox OSGi framework from within usual java code?!? [message #131699 is a reply to message #131690] Mon, 25 May 2009 08:35 Go to previous messageGo to next message
--------------010701060306000009050702
Hi Markus,
In order to see an example on how the start the Equinox RT
programmatically, check out the source code of the Servlet Bridge. The
servlet bridge starts the Equinox runtime from a servlet.
That project is called: 'org.eclipse.equinox.servletbridge';
You can find in CVS at dev.eclipse.org (see screenshot of Properties
Dialog).
Dann
Content-Type: image/png;
name="servletbridge-in-cvs.png"
Content-Disposition: inline;
filename="servletbridge-in-cvs.png"
iVBORw0KGgoAAAANSUhEUgAAAt8AAAHlCAIAAACiYQfFAAAABGdBTUEAAK/I NwWK6QAAABl0
RVh0U29mdHdhcmUAQWRvYmUgSW1hZ2VSZWFkeXHJZTwAAImFSURBVHja7J0N XBTXvffPAr6A
Ro0EMZrVJdJEkaSJMWlCIe4WyYP1uVBawqVGm1yhT6pwLTRuTV+eAnnapgmk cFPR5hbStBrj
NTQU7yXQol2shKQJsSZBJBHDmo0viPgWX3jb3eecedvZmdlleZWX3/ezrjNn zvmfM/8Zdn7z
P2fm6JxOJ5FhWBxFAAAAAABGEGtzvXw1QKFLfrBxLXwEAAAAgJGEFyGSRtHx sROauuy+u41f
udt27tIX167BTQAAAAAYGW4KCtLfMrP2Hx8eev9DXqAEyKXJR9ZT8BEAAAAA RpKLV67SD9Uh
vCahAkXo2YlcescHx21wEAAAAABuCFSHUDVy6P0P6XJA6IK7vxoTdenyFw44 BgAAAAA3DqpG
lt13N1UmLHZye5i+7fxFOAUAAAAYQzjsjs7OzrMnz/a34C1zbwmaFuTn70eX O69e6+rquXDu
Qn+NTA2aOmPmTUE3TaPL9t7eLy5dOX/ufH+NzJg1Y8bNMyZPnsyvnu+5QjXJ Wwddz+z44TAD
AAAAY4hrV69QVbF4cdj0m4J8L/XF5auffnrS4XTMmDmLrlJpcvni5eX3L+1v 7SdaT16+9EXQ
TTcxm5euUCM/jIv9yrSzfg5HgM5JnE6dk5cXdqmIn8PJCw6d06EjzgPX9UXv 1F++QG4JnaMw
LqgTh8PupQU6nU7xWhQAAAAA3FjOnTlnuP22SVMmdXX3+F5q8tTJ8/Wh1k8/ n84JC6pv7or8
ErXQ2aVhxM/PjxMJDkXK5En+c+eGtDce4/XD+XPnzStXLiDWY21fTLX3TOnt DnA6J3Gl/B12
nY4THFzOAKfDz26f7LRPdvRGzT4b8MADOQfemh0SrKFOqPiw272LD0gTAAAA YNThHxBw7Xr3
AErRb+nSb3c6u65r6xt18IJP6e21T5nkZuT+wFM3HTlMF7r9AmzTZuucDqfD EUCc9H9/nYPq
k1478Xfa7ToHsTvsdIHaaT/zwJdukRvhNQmRxU6carn0Zf3tMeGRN00Out7r /89Pznd027u6
eq52Xei4fqrT3uHU9eC0AAAAAG4gvb29Ay4rv/QPwA6vTiQjAb3dTHs47ZN0 vZN6u/zs9gCq
S5yOSU6nHwuiOLnuHkcAW7X7Ewdddur8CdczoxYhAZ5qXR15/8P33ecfOOVE 29Wm1stnu5zd
VJ1093Z1T/XvnU+6Jzn82/0mdeLMAAAAAG4UjqEYd+FkAQ7Bzq7fFXnPvOa7 WVIptw32Xoe9
Z7LDcX5y0LyU9NnRj3y48ZtEx41q9feXct297Y3zdX+9/PsXZvdc6/ZzEIf2 E8MBfAV2uyt0
o9Pp7gi+9Svhi6fODOyaOrXnYs/UaaxPq7u7u7OLfa5f7+q6PqXLETRlRqf/ JEXM54Efv/LY
fdJa2/4fbtl7/MYdttis/9h4T+O2J363f6AWFqX+9Pn4EELa/zv3569Yx8S5 yh0C0fOD98Ao
P0A3xKt9Y0jYmhtLqvMzd38+YCdw5x4ZOyceAOAG0NfADO9l7WIQxeG7HSkn PxhFMuJPV3t6
dcTu19NNpQkvRI6krZaXXVpaSb/p1uv/+azO3kPs/n5cP5FchPCih4ud6EhP T49cnawIu8uv
h7Sf77wSYO/s7Ll+rauru5v+u95JP51UnVzr7Lp+3b+zV3fTbEX/DlfB3yum /etHOuddlWcS
n39lXuFjv7GM1HGKM2/797n7nnrqjWOu1kw+UT29LfbC7AGYe3gjlSbv5uea fh2gc958Z9TZ
+YFj4FxlX12BR+qndt//xWA9MBJtHb3N8+TVwD7PvV7259V7ZtY/jtuWLegd mBO4nwC/9g9u
turGxIkHALgB9NoH3rMjXfodTqfvdnqZkuC6Y5yT5UZ0vb1Oew/99ncGND/+ yOI//JWXI3SZ
z8CnUGjKrJ4eXXe3MyDA4bTLjfCahLjGndjdhuOGzrr52rmrtmvOnimTLly4 durUxc6unk4m
TZguucYLlOtdpIdMm+lQxod447d2GO+oyv9t+IrvLV1muLnseMfNI3GYHnro HkI+D2p+b3rX
sstTCfnLr763+5PbPiDky3bHAF4398gDkYQc/dMLAfPv/vyO2byjRv+5KsXa nE67Y5AeGG5G
efM8edXR57kn9qHSv3n5H1e/nOAQRqNzNdoJAABo/DYN4qdT+nVysq4dV/o3 12V4KvLGjmKn
+PvGBzlcP3EOu667R0e6db3+Ol3Ax2uMd+6q5UWJtEyhyzomZbp0ji5dt5P0 2BUihEd4ZufM
2XZ56pRJkz8PnzeZPflDJt96c8jieb12WtbJvtlAWyqdHL0Ox5VLX7z6yi/c DV4V9M/1L86c
vUCusoEphi8ZTtTML3h340Pv/vfu2/4ldR4h725b/vR+sviJP2/7l9u47G+/ 8K1/ryTyFI7T
uzdmFjTzosu16fM//fAbxazX4jd/k9tkC8vp5tuiKj+JolX8kmz88QN0/f1f fu2Xb5wlZzQs
LNq883lWlojZZHvyzV/9adO99P8lz535acIL3/q+e/OEBivbwO2XHN+K3JWx 9fffulUqJOYk
nkyJ7Sduu3Dqv/9t7SsfSYeg55rxB7/9qeSB2U/8Vtu3Wk7QrsuX9jC/cW6X 7wu/y4JzuJ0l
tPZPn/iT7ADF/uRvG8m77z/0wH1eDj3vGa4KMcPqHzc8dZ9WI33cL42zKJXw nhQPFnOsTfJq
+9n2SUo7ZPPOx+Xn3vJXOumf2oInvnvqCcXZpTz6yrPUrdmUc4TYL3W0fzlb 6wzx5TABAMZx
4OT65UmXggZW9sq1y9fPOngjl6+GXLx0lQ9aUC5evsKpDyKlyBG20o1+TslI z7VLzlOd5MhH
fsTeGzClK2A6Tfzw7lvu/pD+iBFJmtAUoeW9V/x6uwjxJ3PmXr3W2yV7n9yS OxYQ/iVsnPxx
+9B/0+uP1r9xuOa1997841tvlFj+a1vNjqL/KX2+fNsvdhfm/OH5H//uF5u3 5/+sRFFQ9uyx
a9l6rK2rmxsR80DUtc2Zix6t2PLs+ea5/4f+sJLXnwuZ+/PVr3Q89NSfCuOE Ip+98rtpt/6c
frb8/dbUbS99P9xJFj8uZZ7+k09u+9bzL8ROFey7bH6QHruzjpWvXz3359MS z//y8WdeZXMH
3XSpKeyqloW7MrJT553Z8ShX1ytdb9Fssh154+lvPvMWLf7Jlrk/f6Tg3jOG xz012G2/Ts9y
uWKxb0WMP6MXnvpf/JTbZbqtY17wd85ccfeqtge+9pu/PZ9KKlPCuF1oiYoJ vrVH9vj360+b
XR7w4FsNJ3j0dp/tuX3zTqob3n9mCbNG02mN3efv5faFkM75onMok66dXlL6 A2XzHprb9a0l
m6fP/d3Ln9Hm/WJ1t7YPuUNza+rTWbd3f+03T91H3t59Z+aME+fdGtmf/XI/ i0oaybx/eSKa
8+TqrzxEyMHiD15vneFyq4adkwVrX5Kfe80XJ0ve5nbnvh//7f8lEI2j73aW MgdSaXI4hzug
dH+F34aEH2ucIQYfDhM++OAzrj+9vfaenq6BfnokI8ThZCnd7MOkBrcgpcg/ rq10mZWSjPT6
E6c/N8bV38GeyuE/jZGujhO6LKXTPCwncVA1IxkRFIg07sTfz89pp2uun99r 1zuvRC2JYnFp
YmdPLDs9xU52lD6jHQCnpexf20qvHJ9bni8lk+b3sPS/123628yQ21+uIcEJ WWm3kbO/39VD
QppO//61t57IjPnq46deFkoH3dKkn32tZldF5sOJD0d9bW/Q/VLmO+r+Wk/u WBGTcuoNm8Lm
/JtnCa+8nXI6zPD5ZBLuJ6w77zVpWPh23SlC7lv3+reORT39P79vuBoyf5Ld 7pBpxQCh4+vC
bXe0PLhKq8Fl6jZ0OOyChbtklXopYn7ky4Q0Vfxm6sz579X84/3nHr7Peuzd ruuzHIGuVwLf
pdX+U7rb6LXz78X/fNNxOuyOz2v+b8OfzyztDnYdAro3kgek57UUvv1Zi9IJ 92vW9cbLc6fr
+mjPMRI9j9j+eOj5Cxduu7Nl2qxVYrRPflZIL/WhTZI1j89jbf/LteuGO//n wD/+Zf2CkIUh
YXdo+/DlP/94a+yBzD11MYR88NOkFt3MT/Uzr8q7Pz741Mf9Uh3B6t+/tv6F b6evWVT5p0dT
2Qn8q1IyY7441YPDeZcHO27n3oy7ZN5u2Ppfy9eb713xUNirdU7VCXOzywl3 xHAOfO+F68yB
t0xLozKOpj/28H3qM2TZyk19HiYAwPimu7uns7t7YGV7enonc/0p3dyb3OR2 vNuUb5Ub8XNS
SeF0+HPvWxMzRDS6XpAf2XihSRQrAVTH0Jx2pj56euxTxJ4dHdH5c7+JAa6u K1mX94n2toW9
uvc/Pf/uyYvXOruvX++keoWNOLneRZc7u7rYMJSu7hnBF28OVo47YV8PJ175 OJEtnKz+5vKG
A1NOLQiaKWyfcWqmP1VM55YuvJWQo81vX59uuEIvnPwP6uXOKaJEcrD2OPm2 TvnSfBbT/rfy
n/6brKbL0thE0WagLHLjcLh1xt2xQMvCK1sfv/35P6Queaa+4pmTFY+nln7g kDr7pZ3hzTk5
C6oGa7TB9dy2j0U+tZ0iD0Z8Pa20/O/Ouwy0SPvxpsBJk8/JxyBotv/eBbfR zC1NZMYttgCu
5YFzPgokc2VOcJONmr69sjP/8YW/kTtB21dfzJ4T1NGHPw0G2qADH7cFhpwM dPO/a8wGd5pJ
DZF3nYqJU64FsGU+29RwvaYPaWP+mpEfc9j85QM/+e8icmHenHPKwSB78x7X l/qwX+ojeK76
7TPffvTO//39f/v2fFL3s7fcTmDi7MMOf+4pvN3ymY3ca/jS4i+qO1XVuW4s nItukztQctTR
zzTOkLv/d2ifhwkAML5hQ0oH+sgOF2RwCEaI+1tXfX4/q2SE3ngGOO1UVtDb cz+mTpjNxY2X
+WzNkTP45Tvfth57SM913LAfdNar4rT32nslBeIv3q4FuK4asud5/txw4P88 krwwZNrxc5c7
LlBp0iVIk87O69xDxd1dvZOmXAmadl0xksVJuIsM98yOoIOmnNTP/8zffqfr CSSuouYTp8hX
5tz50HX/Nju9xXfKIi/s0mTnozTCaqP1NPnq5JeTtv/7O666dNPmKmwKtfOG 2PNJ0gNSzqOs
uikqC45/vvjEkmfuuf2HP6h8IvGZ7x6J/+1bkzQCQfTO3q7dYOkJcYebA4Xj 4VuRQ4XPv/pg
0WO/eOETLvmtZ36y6W0SfJtdHglo1mz/kwsJuWdRxPVJNldmhROkZYdd27d0 WeGEH3nwlXwH
PbeHGL4U6u//Nm2PJDgcrn1nRqT2OXrlzdPO02SlF2a1Dx32O9e/af4yXVzx iw1bP//Or48R
9cgw3/ZrrvoIHir8r7ce/f767wQTm+XZ/yTT555wncDE2ezdDn/uKbx9+3z6 53jgWFvX9WDV
SStzArd/kgMlJ7z7/POvPqQ8Q+JpMx7q4zABAMY3vb0OuVgwb3hMnSd/+6ue yvI/F3TB3183
AHkS4O8nGaG/erpJk6YGBjBtQiZPCpi66D1hLMnx++dMCpxKv2mK/00zqUxh Kb2900g3maTr
njzJbr8i/XD5icFfP3GdpUifDz9r+evht6fOCPjq0vmLb7vZ4ei9dr2TSZNO Jk26unoDpn4x
6+Yrkyc55KV0/NQ+wq/ksfCwt+ln0fzPJsvSiVTFX9+1keDYxNt7usm9WY9+ lbT9ofAj+d7r
yJd+lPcNPfnot0+3vfXm+zTz+uzFt8x/O3x1ZHND5Leo5TlXFTb9SOuJk64U +cSG73PVqSws
++2vH5k86/DndQdZ178j5OzFIPnuyPHUYEUb3NzoWxG/xLWP6Yntj8KIkEe2 B86Ye3jWZJLy
68oP6yt/m+gypWz/Xw/U08vzk6vv62Xuevp1llnhak3kviXkawon/KXikJav zvnYnoVPrPi3
7iC5/4UmGUJWcFWv+uo8D61ycwvPe3/R9KGBb/+P5lYcIMFP/L8td3SzIvIW 6sgjvu3XVfUR
9CN/fWlPGwsi7m85MOXk7CA3rx7WPpcaPZ17zNtrlxNy5M1SMmVyt+qklVHx ltyBrsP3TY0z
5Ng+zWac02mdivjgg8+4/FBNMMnfT/po/rTKM8g/TE+IRgL83Ix4KqLYGhDg LzPi8JsaSGZM
I9ODJk0PkqTJ518Ln3LTDP5Dl/lEupXmoTlpft2UQFrW9fOrc4+dUHHicI+M //ldS8uZz+OX
Pxx99/x7F8/9Y8V7rdc6ibN36pSuyYHng6Z3Tprk0Hqw0unU6irSSG986eu/ XPTRjzNPPJHJ
3Q7+OONtEhzP4t4Ln/huxxPf5W9if7bwzd+QjrnHi7/+y4Uf/Tj5REMyIad2 PfFM5Un9nFvV
dX387I5Da56OqjwRRT4vX5dsERWeU6zO3ULcAv2DSR/Uf59zYU0CvVTPdmrt lZPd6Wo2eP4V
D/tLPO6jusgxm40s13/nu1e/w6ef2pX+1rONYq/e5Yfarr4Votn+W6uffDCo +J3vvnGYPeFj
27MlettDXbOq//bO96MejPrh43/83l8dLg9wSxq+jVqqcsJftLx9wvf2PNv0 +rNuscfqJ3+1
4iN6XFqiZJdm9kpjV/McbkdTWiYfqn04b1tD5pr5p/+YXEHb//qvFrY8/XBZ edeaR3/t1sL7
F/i2X9pn7D9//dpbKf9r79NtU2a3+7MNcq9q7rv7uZfr7u3P/zt54QfV1NtT p6uqkztB7cBz
LP0TzTNEsxknAnA7CcBEIkD2Gtb+ZpB+9CZPmSTPVl/zJ18MTprkLzfiNzWI 3HwL8XdOsvtf
/+sbgY988+w375s8a6a8LE2Z88b7dOvkm2cTfzux63RB0+VGdGLwRDdHf9cT 67/9N8s/rl27
PiSecurmnP/szivTPl44+2yf6c7OiBPnhJkJb7rl4Oz7v/eXl5Mcr/wu4kdt QvucHSELmoKc
bpl1zmuz571/k38fNnWTbPPmnus8c+/5bsGIhgW7oe2UvpPzBpffOsk9oHXt fEz7VY028A0O
nupxfz3to7qIU3fnT7KXbcr+nDaDf4Xdir+/viCrhDaP1n72mlBK0wOSY7/g dmHqrH/OnX6F
bzZfcHbg9Cu8B77+8N89+FbTCZp19as9uvUpV35xx4Gf/Pxf93J7LfODVGR6 gNi8BU2BxM0t
PVfuO3WBCIdJcZ4IO3VNvpVveU+Hq4U+7pfXM/aWQPHQK3Zfe9/l594tpEOs 3a0BquqcOpcT
gpxuB1S0f+VZs/YZotkMAMAE4dLljju/dMfAyn587JOZM4J5I6viTJ9aT/bX wu2G+VU1Ft7I
xUvnrOu/OunYP4mfg+gcF8gsehPqxx7JYffGfrpeP0fvJKc9QGd3xY6dbHvv lyIXvvzurJnC
k8ZBQYFfM33llZdfC+C7dQL8/ZyOoZqIuG32/LbZGq+I0UqffGThPLe7bP7/ qTMOhU4Xnqgm
0qAf98ycnb5s2sn0kL9Pl4yoLehaQ+e3upJUA4wCZ/19waz+t4F43Ed1kXvN Tz+WOm/BJ+ue
3NtG7oq4nStz/tKc6bPaaO0LZ0mlNE25rMkTpYLE/oXgAUeMR99qOkGrrv61 Z9r/Eg1y7/lR
HGvi3jy70i0BQQ0LgkSzirJSKcVWOwmQt9DX/fJ2xspPCbfd19x390S32l1n l7q6L9zOUvcD
yp0hr3g6QzwcAgDAxMDpnDzJf8Blheu+0zllyqQB2KGlZEYcZPpMEhxK/Fhc fLKT9YjrnE72
EI7OqXPYmUzRsfdT6thcgPxdI1UnOuf0m9koRYdrLAvfuRMgBdqFUbs32M9S 2Lt3NLRnZHj/
+XUpvf+1J2dHUw63/tbvg1NOkkDH0Hpg5H3rdPVY9IpP24DRe4YAAMYiFy5c vPnmWQMoRYjr
un/p8uWIxbefP3/JdwvTpgfRUnIj/3FhQUZoJ+npcuo4ZcJEhlPnerOs3Sm8 bt0ZwJQKm6mj
2z9wW0eY3Ig04I717KSlP3awrqH97PlRIQR7bz93biGZ8W5I0NUJdYb1XPvK mS+EV/7pph69
beaZceBbZ1fk5xdDps/6281ToE7GwBkCABhbOBz2a51f3DZvXr8ECpUmn586 NeOm2fxTt1QZ
TJ5M7l/25blzQ3w3cuZM+3uHPujuJn46FnSx9/ZOnkoef/T/bLhTmK/H6ccG tPLLfqxzx0Hv
knXcfbIfl+IguqJPAv/w+n92dxJ/8fViIXNmx0QvLy15lamT73537d8Pvnf6 zFkcaQAAAGCs
oONCDVevX/SYQccyuGLnIjNnhLCXNHCxDGrE4XBc77rcXyNBgTP8/AKEacA4 HXK1s98tmTZ1
ls5fJ6XfOnfOwzH3/+53O13P7DjtThxpAAAAYKzAd6AHTp7R34LdnV2DN+K0 E7v7zMZBU2b2
2wilV5QffsRffC6a/edwOv09PCcNAAAAADASOLj3m0jz7DCR4ud/ravb3n0N zgEAAADAyBMw
OZCqEWFZSp05c/rR99+Bd4B3dr/2euq3Hz03OsZQAwAAGDfErEqRltGhAwAA AIDRBdQJAAAA
AKBOAAAAAACgTgAAAAAAdQIAAAAAAHUCAAAAgLFPQJ85dr/2Otw0tkj99qNw AgAAgPGsTnC1
G1tATQIAABjroGcHAAAAAFAnAAAAAABQJwAAAACAOumLWrOOw1xLiLV01apS K44GAACAicSH
v1tCPyNZ49HmRvoZX+pkKDVErdnUWNLqdLaWND4nszmAKvpbBEoIAADAKOCD l5aYfvSx0zHS
9T740FdGv0C5QbET6/FGErnIQIghraoqzYCTdPxi25UcEhosfpJ32upyueWU XTZVnpw6tiZk
ED98IgAAjCsOv7Tkaz/5mC44b0Tto1+g9EOdlG5Ir65OD9PpVpXWlq7iemQY tWY+YZXZvErn
6qwhXJRCSFAEK2rNYenVpMCk3GiVVWFVFudiHqVml/m+i3C9R4J5tokuuucH w6xMdqYGL8u2
EFPRobaO9rbDhSZL9sskrdBEt1n21oryxHZgr4X+ZypMj7btSAlNLKaLDTR/ R3tDkYlsfVGm
YwAAYBxwaPvi2KcPOx3Xif26w+Gkq4rPUFXE9+PIPxc7WseEQAnwPWva9pKy DWQ7H+pYtFlX
WZtvNJLayoLNW5yG42XVjYtbnU4DJwlM5tXO1ZVhzVuczipeGWwojXXFSIz5 rSWNvCm2SarB
IKuCWnEvvp2Q6nSWlC9vlNciVWm0olVhxbVpGcc3lCW3ci2Q7wUYVupLsnnV kb9Oz9b1a3cf
JrtO6GMSTcRisVQcsK1bSzfYanlxkhCjtx2s4BYTV3AFiH7dngaSexCuBACM Hxq23vnIj99y
9l4hOhY3WbmlTkeXnHSZ3lo7+VjKX3515/KMj9VlQ0KD5av0Ls67NKESRJX8 FXkE5Z23/7Fk
caRm8U+tR+SrtxuWet+v5JS99EKsvu8/cOAPubm5GRv+fbhiJ24YV28uqKwl nDhZbWQp8cmx
BnETaTxee7xRio6EpVdXN/cvUmHVKh5fkmHsZxGmXhpNurCy5O3QIyNMXc1W IpcavEBZE030
xgQ+enKQC4rYWiyKbJasZaHBIak7bJxAyV2jhzMBAOODd39z5yPmN0nPJdJ7 gfRcdNIF9n2R
9F5y9rIFJ1u45LBrF5fLEe/ShKenu8v757777vEUQZHLkT6lCaVsT4KVGA1D IU0GoU4EeeIS
JxrEs2GvIvnG/tYwgOJaRQyLIvH3MMrQr0hwde7wIsaUYKQaRL+mkOv2kWkU NlQFHgMAjBO6
Ox2k54KTfS5yuoTXKBe4BbbMfV/o6vY4VpYXJb5IE0rn9St9frwU50WJL9JE U6AMWJr0X53I
QiDGjJJGk6lRHc6giiU+Oda4KLI6vbi2/y0SYh79Ke6tSK3ZRCxOS2T6Btc4 k/4GcsCQy5M1
WRlMf7ScIHX7ttGlzE1CgES/djc34qQ8UxIp2S9jXCwAYJwQbT725198m1ch TiF8wuuSC5xq
uSh87N6M+ChNfFEnR5paPPXs+B410RQog5EmpF/jToghbctmnUlXEF/CjeAw xCbHx5NYUSSx
oabp3NJmi5P1onBjPnQ6Karhy1APeRWK4tv7X6RqUbGOaROqn4yWSl2YeZEz 36jYCzB8f4Rx
mWTbVk6CELFvxrZz1wnWuUOiV24kxdu27ssjxTR5Y1w0t7kuL4fk5LHlqLz2 try6vOAkql2O
ttpINHp3AADjg4e3HCv/VXjSD37l1BF6wSoveJr9x4aduPIYn24ZfEVUdqh7 bdpOfnz/A8LQ
k89OXvQuTQYGFSjJKSQ3N2zA0qSf6oQNZ5UNSq0tTifJrdL1XX21N6RVOdM8 SYqqKrcFYdWt
CmVxKY/nVimL5DudskxaewGGj6j0QtPWbMvWpNTwQ7vZwNi6vHuyScVamXah AoUuZwjihLI1
KfRIYUMZGy0rhFVIxqZ1kCYAgPEEFR9/+kX4N3/wE7rscJCv/aRlmCryIj6G SZpIAmWQFgb+
vhPuYR0EH4AXWDdN+UZpBElw0rbM8hxRiETFZQhLmSujxHBLTkUGsWQv5990 IjxanBsFTwIA
xhtUkZQV/NzJPVE88rUPqzQZEgIGXNKYz3pMBKRYCADuROd0tOdob8lt68j1 KREAAMYhK//v
8defWQRpMsTqBAAAAACDIe5nx0e4xtGvS/qhTna/9jrOIQAAAACMFnWS+u1H 4SYAAAAAjBh+
cAEAAAAAoE4AAAAAAKBOAAAAAAB1AgAAAAAAdQIAAAAAqBMAAAAAAKgTAAAA AIxj8K5YMBD2
7d8PJwAAAIA6AaMIvKMPAADA0JJX8BLUCRgU586ehxMAAAAMExh3AgAAAICJ qU6spat0EqtK
rfA8AAAAAG6sOqHEl7Q6OVqTy8LMtfA9AAAAAG6wOpEwLIqUll0xFSGgokxw rXOChq5KkRd+
mfsuNYsZSK1ZJyugsg8AAAAAqBMVtZUF8YsNvJIIa94iBVQ2MKmxIT3SwiVY IputLIOw3lrS
aPIUcKlOb15Ns+QbmRgxEb48W1fZxwEHAAAAJog62f3a616+JQ0Rxkcxnlvc WpXG1In1eCMp
MPGJYenV1c1WFlahKUyGGPPzjTRDfEmGkZU2xCbHF1RqyxMxD7HuLyPisqZ9 HHAAAABggqgT
/u0Xnr4lDdHKxUDi5SpBGozCBzuoJmELqyulrpxBorQPAAAAgImhTtxiJN4x pFVZCB8dYQNQ
qtOL5RrEWmpm3S9Uo1AV03icuDJY95dVb17N5IUobliK0nhsMpEZVNsHAAAA wKhnaN7G1r83
hxrzW0tWhelWlbRW8Us6Pj2eJiwi6WG6dHHNYCCuDJstTipOjNvFhPjNm+PV 2me7yyAtoLLP
9SgBAAAAYBSjm6O/Ky39sXff+/Dkqbaj7+8bmJXdr72OV5tPEPhjjXfFAgAA GFpiVqXMnxf6
wP13l5a8OpTjTgAAAAAABs+IjzsBAAAAABgBdYLYCfCJ+pyQ0GDhk1c3jBXZ dqSk7rDJFwZW
HAAAwNhVJ4idgL6v+LuSQ5JIeVtHO/cpJzV1I1Crft2e3ev08D4AAExAdYLY CeiTA3tJYUNe
tLgancMt23akCNGUnDoiBC125gnxldx6rRS3Usk7hRBHXW6olMe205xlsWQt Cw1OyctxBVG8
VyTTUa7iu+p2pkpbaRXJO+tpwZzc1L7aw1Kktg2VvtOommk+vmrlbnK1u3Yz p45tyhEVId0X
0Q+e8uOUBQAgdgLGPXstSw3KIEZd7vKsiHIWSjlUeCSJ7+uxZLXEcfGV8szi F7krrjKFlmrZ
xMdgGhL3mmmKbWdqIikXojK5Ufq1+UUmU9Ghto4968P7UZEYb3EVXxO9dlNm MR/lqa8p3pi1
lu6C5Uh4vlgwiV7F1e0ZNhRV23Y8lb2UD0eVL2k5odkSYTfzovXrNm3cuo+X U2xf4qK958cp
CwBA7MSFfJ4/TylgLGIKX6gMBrQ2mYrSojhFEJNo2sapADGF6MNNQkH3FFqK bE3i7/iXZ1ks
LSdstXuJmEc76uBbRZpExWVw+etqtmbEcZdsU+IKvbiJHLHWq9pDuB6ltrK1 Q96lpKiahEWw
qlmcg8WibFotMbk8Ex0nKK26miOF66NJX/kBAGC8x05ccwV7fkc9VMi4JsJS cWCoogpcYKNd
+Az3XX70ShZyqNu3LXNl1Ghoj1vbclmNcfukHivvLYlKLzxK5UndvqOiyrlh LQcAgFESO5Gm
vGktaXxOS4UY0qrwLtfxS1ohyV7uGs1Ql5dTpw+LsGSV8uMnDlZYNsb5dHWU lRJTjAnEPYXC
RwJURXytSFY8en1RU1JiU2G6slR9TbEpcUWUqj1keMadqKsmO3J32TiNcrjQ xIVS1C1x992K
hCP78mqaEox6TU8CAMDEip24xUiaqyMXGeSREn5ZETuRwi1h6dXKAAyXj8tf ahZiMYqNYLSh
X1PGxnyIY1eTCJUI0bkN9MLPVpdlLy3P8fHW3VVKHA3KRopIKWy4KDfGgtaV 8nKLoohPFUnF
d9kE9WMyJcSI/TTcgFlWVxIpZw8EqdszbCiq1oeR7Hu4eu/Zm1C4Vt93S/Qx iU3byKY1eg+e
BACAUcHQvMneB0VSukoSGfyEN6R01QaynQ+WWLnl7WSD9F21qFhnIhZuWmF+ K0upXM3PMyzl
D0uPlPKENW/hFmvNZpKP6YiHi4n4Jvv6nJAXww/xTybbdqSYyQs35CnlG1g1 AAAMP0P/Jns+
duLp26VJhJ6d5LINfYU3rMcb40syjO4ppMAkRVP4mYqlPIZFkWwrC6IYIU3A kMLGw26CJgAA
gJFjKMedePpWQpUEry36i6RvGAoJYsxniasrPQ+6BWBgROd05ErjYW/g693w ZjkAANRJv+jf
uJPayoL4xQa6IGoU6/6yag0FU7bfKtvKUtKLPekOa6mZhWOoRmktiW88bsWR BQAAACa2OvHp
mZ3q9DC+X8ZELFVpBkPa9pJGvqdmQ3NkvDK3Md8SyRcQtxrzW8UC6qGvhkVE MB9WlrwdT/4A
AAAAY5eAIbHCj5T0lsOQVuVM6zOtqsr1zfXV5HsvIOTUzg0AAACAMQnm2QEA AADAeFQnmGcH
AAAAAKNLnSB2AgAAAIDRpU68x07+mLNSp9MN1TeOGQAAADC+GYl3xVJJ8Z28 obEca392qEyB
ASvRgb0rNiV1h+s9p3jtKQAAAHeG612xnvjDz2KHqumPP7Mfxw8AAAAY34zE uJMhlBRDKHTA
aMC2K9ltCjo2tS8/KR03wS9dTd2xM4+ucpMbD/fEv2PIXUr/iNMfuvlQdJoy j21nqpiZ1OVS
U/U0T05uKp+BbfVuTTgC4rLyIAIAwChRJ77GTu6+iy4Ln9RQErro+YxFBmHb 9NSMB2kaSxTz
PB87ffiEDhgFF9sdT2UvLW/raG/rKF/ScoJeKZe3bOJW2xsS95q5S50lqyWO puRFw13cPM/t
vH/Kl2a/zNSC6B+akln8IvUY9WFWRDlLYTNC52nm0a/dlFlcw22qrynemLVW T/McCc/nMiRl
k3yv1vo4iAAAMKZiJ4bYB//wDVLyzP7HuU8JmRPT1naIhDwYymUKDV1G2t9p C81+MuTQS3ye
xtMh0xA7GdcX27AIsjWJuymPzsmLtrU2sVXuLnx5lsXCXepMRWnyOW7aytZO 5LEqUiQjaSs5
2mqT+0cfbmIZWpvEFH1Momkbp0EUeShRcRncJjbBYRwn/EyJK/RcBmnBkzXv BxFnNQBgTMVO
pj+4mFS99NFBMfHgbrp85Z1msiySC5CEBpHmNitbunqyjc/SVri7DbGTcU10 LrvnjtsndRyY
ig7xsYE2xEu0pMnyioQGPrZUZBqc51du3Lqvvm7ftsyVUUN9EAEAYMzETkJD lwVLssOFtf1q
KBcgiYmYc7r9ClUkDZ/MSef7fTwKHTAmibBUHBBHJdgOVliWhOltO3J32bjL 2+FC0xErCYuw
ZJXWe48cTOhxJ0KEg3egZga9y4csz8Y4Twoven1RU1JiU2G6Nwmoac0idN8I bVAcRAw8AQCM
ttiJp29BUnRc0/jh+vDs4TvmxJDp84PPNnzIx1S4bp2mOX/Q0iiInYxdchsS 9y4XxmYu25t4
KCeaXvxI9j1cyj17EwrX6qNzG+glMxhDLD1ohXWblmQt45zz1LGlJk+RDNGH y7KXlud41h56
Y4LJlBCj7yMuorCmX/dC4ZEkeRuUBxHHCQAwBIzY+04+yv5Z2OmX3lH11ZCY 1AfnN7Uvi7jy
Q+W20OyfzWl4xtUZRPC+k1HAgN93AkYX9TkhL4YfwitnAACjhhvyvpO28rfI qifvinGJEmH5
YNPVVd8wnG7ipEnooueleEno9FtV4RbETgAYEth42E2QJgCAUUrAkFjpc9zJ d/J+ZN3/Tg55
MO9nsel86ieNj/MLH549/A3Cd+uQtrZDwV/5w88iuZWrVS+9Y9UQOgCAwRKd 04FBxwCAca5O
+Gi/p61UUvARDypQHteIfbQVPiP16VzZXbx/dx9CB0cNAAAAGM/gXbEAAAAA GI/qBPPsAAAA
AGB0qZM+Yyex9mf/mLNy8N+InQAAAADjnqF5otj7uBMwnsATxQAAAIaDoX+i GNIEAAAAAEPF
SIw7AQAMMbYdKcPxLt1hMgsAADdEnYxo7MRaumpVqRWHbqzhdtnz/SqI6+W4 kT4AAOAzA3/f
ScXBxneaPlOnPxixIDEm0pOuCEuv5pfjS1qr0gw4AACMOvTr9uyGFwAAN5KB x06oNHn2ya+r
P5qSRZAmZcmtTp7W5Ob9VrgfsGmH+Wn/cur4hF3JslkAbTvNWRYLm/ouZRdu 5mXuWp5lUTqQ
m72ZrQqeJKQu17Wsdrg02zPNJsy8mHtQzEOdz75zclPFTfXqo6NpzfPB5czu zJOthmLGRwDA
UKsTit3e63Cwj06no8t2e0/n9Sse8tYWp5OS7VK0xJCWzy1TzaLjMddKKsZj ik4n79NxpaOn
ZyxgEebXlV1c63KXZ0WUd7S3dRwqPJKUV0evWE9lLy1vYynlS1pOEP3a/CKT qehQW8eeNZgT
xuWu9oYik5DSsqmNT0nca95h06/btHHrPk5JkPqa4o1x0UoL7vmp/ktNJLzN to7cGMUhOxKe
z20qzyxOyqlTHh21Ne3WCgeXOwda4mhKXrTGvgAAwBCpk56ebo4uuky/r165 dL79tHZW6/HG
+ORYg1KymMPSIy1cLKWk0cTUiLcUmhTvVrZ5ixiIKdsAfTLq4URGe5vsgmRr bTIVpUWxjfqY
RNO2mjp9WATZmsTdW0fn5GEiGPdQhMtdrhTmLlHwWahiINFxmcU1TArU1Rwp XB+ttKDIb6vd
S9xtuh2yxBW8JoyKyyBHrMT96GjVrtla4eBy54BQl3pfAABgqNSJw9EbGDgt MHA6XQ4Kmj5z
Vkh3dye/iX+KR+tZHjHisarUyiRLSYaRi6XEJscXVNZ6TVHKHVJg4kMnYenV 1c1QJ+OC6Fwm
X+L2yfp6gK+ar43Tc1HphUepFKjbd1TUFt7zD+boDNiarcWCYwcAGCZ1Yrfb L14819HB4iVn
22w268e9Pd38Jv4pHtezPIZFkdVl3EgTQ1qVIgriFWtztadN8SXiKBZKvhEH c8yhD4uwZJXy
AxoOVlg2xkXbduSy8SX0Kni40HTEyncVKG7KJ7S7Kg7YRHe5O1Ceb0XCkX15 NU0JRkGcSINR
1Pn1xgSitqCivqbYlLiCuB8dolW7Vl3CwZVni4rLEPcFAACGWJ1cvtB+7oyt /RQbBksXLpw7
feXyBQ95jRklJF3R/8IkS3pxLSdC9pdVb15tVKcYV28WZI07spxgDEdKGoqa kljXwLLspeU5
0fSSRrLv4cam3LM3oXCtnj0/smkj6z7AqFjmrvKl2cuZu546ttTk7kD52FJ9 TGLTNrJJY6SO
Oj8b2SOlCKNiJaShQkmkfPc6vfLoaNfu8eB62BfXCF8AABAZ+Jvsf/TSm2uW B1E50tvd7SRO
muJ0Ov39Ayo/nfbsk1/XjoOonyh2JW228PEPdUqtWWcqcMVLtpMNG8h2WhgP KN8I8Cb7iYJt
R4qZvEBFyXBXVJ8TUhPXnoNRRgBMdORvsh/4+04ejFiwq+EzQqZwH7d0T0VY p05aX0nqFGO+
05lPeJlSuchgMFZVeTIHABgb1OUFJ23jFzPL2yBNAABuDFydJMZEenrr2tAi C51stjiNOGYA
jATD/E626JyO9hx4GQCgzRiYZ4eFTjD0FQAAAIA66ReYoxgAAAAAo0udYI5i AAAAAIwudYLY
CQAAAABGlzpB7AQAAAAAo0udjN7YibV0lWKKQHXKIA0CAAAAYBSqE99iJ7IZ dgavOXQuxLmM
ByQj3ExpW4IoAWOP+hzh9a99vqXetiNF+ZpXAAAYF+rEt9hJP2fY8Y40yU5r SeNzWrqB1ubj
22MlUxZiggQZNlJCxVee+zi9H66aaoe4fOhddtTlJh0pbGCT8+VG9cc+HA4A GE/qZADjTmQx
C04RsHUpdFFr5paVebQNNVdHLjLIYxv8siLaIdmSXn6vhs3p02zVqNdauiG9 ujo9jK4XN9P1
/eY+gy1AhTSfbTlJwlVwkD7kprDxKFBsrU1kqUEPfwEAJrY6GcC4Ey6Qwkcs Itlsfoa0LZsL
KvmLfW1lwebVRnUeOZxWYJgaSzKMfdVWaw5Lj7QIsZZ4j4LpuYL4xQaNeg1p 20viuRBLVcZi
WnXzan7r5oLnEGvpP2x+Wm7aYVcwgIumcPfuO/P4VdtOc5aFm4WOzf/Hcibv hKKR0K/bQwXK
i5zIc7mRd1FdLptXj02dGJK6o25Xcoh8qzxA4hYscXc4AACMm9iJp+8+giem AtJ43MpFLnh5
UlspCg5VHheunp3ksg19SQTr8cZ4zxpGFDphZcnCVIJe6uWqFkwZFsfjDOo/ tl1FxabwhdxF
NKKcRQIOFR5JyuN6eyxZLXE0JS+amzvXxIUK9qxBEEBToIRFMJFH3diySQio JO41U7XBJgfm
Xde+e130mrJ2IWS1NPtlL11qcDgAYJzGTjx9a0sTpgXcgxnGjJJGKk+oOEmO NXjIoxGEWRTJ
dccMHEnoSNLEl3pBf+Huy+lN/LK9iYd2r9PbWptMRWncqAh9TKJpWw27coop GqGCtrK1uGhq
aL3WJj5MQj/Lsyx8UMotgxhZSdpKjrYiKgIAmHCxE5+wNgvDPuI5CUIT9peJ A0EMscmNlWZB
nHjIo6K2ku+OIaJG0cjMFEzZfmtfplx6RaveQWogII2ZoNIE3hgSXcJCUDLH tvFhJ3dpsrwi
oUEYqmKC0wAAEzB24pVaszRMZHuawZC2JVLoT9nQHCnFJ5g8KSBb+EdtPOQR tYI07oRYqpjB
7SWNJk+ZiTHfItjS2qqQMlr1csNiTOKoWDAEsI6JrFJuXKftYIVlY1y0RrhF jARg3IkSrl9s
0zq9zI0eRGHiCr3oZHevulLUDgcAgBtKwFDFTvoSKGym4Xwv66IIqHL2lUfI ltZnWlWV69uj
LfbgcV9t9ZSoVRb4DBsekbI8OIQtZ5a3RRNbq7t8WbdpY3BS6FZT4eE9MXAX rx6yloVm8aKj
sKGD6+qSu5GLo8hDU9SHS4L5IqaNmSYu5YXC5GWhwa4UTYdj6AkA4Iaim6O/ Ky39sXff+/Dk
qbaj7++DR4AvSvTc2fNwBQAAgCEkZlXK/HmhD9x/d2nJq5hnBwAAAACjC8xR DAAAAIDxqE4Q
OwEAAADA6FIniJ0AAAAAYHSpE8ROAAAAADC61MkYiJ0oJgUchQYBAAAAwDHw 951UHGx8p+kz
dfqDEQsSYyI9XM+5CYLjS4TpbAZJrZnNg8Oz2eLMNw6B4BBnMBbaSFM2kO1D 0loAAAAADLc6
odLk2Se/rk7/0UtvelAn3PvSuOv94OGEBJt12CgIFXMtMQ5OntSauel1qgy8 PSttMM4PAAAA
YOQZVM+O3d7rcLCPTqejy3Z7T+f1K77LC50A10HC1qnCEIUCt6zMIyu9v4yU tLqiJcZ8btlV
QDQlpYhBEVkedcdM5CKD3J61dEN6NffK/FWltbL20ebJynozCMY1th0pqTts qBcAAEaVOunp
6eboosv0++qVS+fbT/tYlgVSeCyR6cW1/EQ2lfzlv7ayYPNqozqPXJxUS0pC HvzgwilsauFG
E5MSrhRxtmGa0ryFt9maXLZBLieMq7mZdFwaibDJe+K5GYyr0oyu9rHmbRE7 e7wYBG4IM+Wy
z5DOmCNdMkfs2nmjL9K2gxUkwagf8d3UqBd6BQAwCtWJw9EbGDgtMHA6XQ4K mj5zVkh3dye/
iX+Kx9uzPFLIwVRAGo9beXXAXf5rKxtLMoyaeVzw8xK7GTzeGC+UM8Qmx1Nb shRXHlJgkqIp
7tMOs5l0KKsrdW4aRa5eWPtE7dS3QeCGNJVuQ+Le5Tl1Q2VWv27PBJv0+MQx khCjnzj1AgCg
TvqH3W6/ePFcRweLl5xts9msH/f2dPOb+Kd4PD7Lw4aNsEEesqgGvfxnlDTS yz8VJ8mxBg95
hKDGosjqsv0DEwJcLEREayQtEykWKY6jkidu4sQng0CpJ8Ii5Dff8oAKuxfP yU0Voiy59Yo8
gqax7UoWwjD0xl24fbftNGdZ2CR5wSm7bMoiXJ6defyqbWeqaJnU5coDOVq1 u+oScsoqermF
rh/Ic2/tsFO3b9tSg55vvFj1Lrq/kuCj6WxZ7SXRAxouVaW4+1Oql7h7UpkH AABGgTq5fKH9
3Blb+yn25A5duHDu9JXLF/ooY20Wxn/EcxKE76URRUdscmOlWRAnHvJIQoak h7niG2xULJMs
Qv8Py08lhEzECBZkeTQEk2SPBV3E2IwsHMLkk8nUKA/HeDEIPFFfU2wKX8hf R5e3bJICKmau
j8ByJDyfSynPLE6il0CaJyuinKUcKjySlEeviTueyl5azpUqX9JyQpQ8a/OL TFx4Zs+aE8oi
zGxWSxxNyYumOTdlFtfUCS3ZmLVWHg5Q1k70a8ra+RaWL81+uc6tovXholku /4sj0sfB2hwX
zTRWIuH2kX5y16zbtHHrvnpZBrWXXB5QuVQjRe5Pvaxed08q8gAAwGhQJ+fb T5091Xr2ZOuB
6tfaT5+gq57VSa1Z6KNpLNmeZjCkbYlko00pG5ojpbgIkycFRBjT4SGPkDOt ig0uEQfNmshq
IzHmi0lstAmLYhjzLYIJ0YIrj3IYK6tb3BBWlrydawQ3GsYkZWQ9RvGSdiLe DQIF3E02uzt/
MfwQ3xdja20iW5P4xOX0Lpy7iJoSV/BXuqi4DHLEWt/aZCpKi+IESEyiaVtN HQu90FJMOkTn
5EWrK7KpijCzQopgmUusq9maEeduQFG7TRZUSNpKjrYq9YdkVh9uGpnICd9m W+1eItsj6oo4
QXLV1RwpXB9N1F6Smqr2j6bHNOtVeBIAAIaHgT9R/GDEgl0NnxEyhfu4pWtl Z/0l+V7WJdHh
7CuPPG9aX0lqExrFvG1wM1BbnE6SWw1i9irvBoHyQs5ECb3YL2cqRC9PdAmL HS/2bSg6t60j
l+vXSCKZ5Q3h/W9K9MqNifvq48i2zJU5XjPS1iZVJDR07NFzy+Yb7kSb9agp fL3Wlqj0whdL
qKrYdzQxTT8kXvKtXgAAGFWxk8SYyGef/Lr64+FlJ+MBt4d1wMDQr9tTTvh7 enZ/b8kq9TRc
g3UAJa6IcuWxHaywcH0WuWyUA736Hi40ceENV3iGi77oVUXU8mR9UVNSYlNh ejTxWrveFU1h
phQV3QBxUruXcO3RGxOIwnX6FQlH9uXVNPGP1Xjxkto/njwm7aZUr5ob5QoA AGInfbL7tdcn
wkSAxnzh5W9gUETlHSpMXhaaXNhQlttQlLI8OESKo+TzHUBZ3HpmeRsLq8jy 0BTuupl9T0g2
V6Lw8B49vXAKumfTxuCk0K0sUVHE1qoSScYEk4mon0BR1b5pSTCfYtqYaVJU tDGTkPCR9Bz3
TG8h12g25kNyXUZ5R24U65Rpym7Z1MZvD9P2EqfN1C7VcLLMny8QqV6l1nT5 HENPAABDh26O
/q609Mfefe/Dk6fajr6/Dx4BvijRc2fPD8/ll/WevDACTwjX57iGv4x87QOl Li94XxwTIhOk
XgDAhCJmVcr8eaEP3H93acmrmKMYTETYGM9NY+4tKXX7tmWujJo49QIAJi5D 07MzEbp1wEjA
Xq02EvVE53RE37jaB9zq3LboiVQvAGDigtgJAAAAAMajOhknsRNr6Sq8sAQA AAC40Qy8Z6fi
YOM7TZ+p0x+MWODhoWL2ano2U3B8SWvVUDyXW2tm8+/wbLYM6iXytGkbyPbt OB8AAACAsaxO
qDR59smvq9N/9NKbHtQJ99oyTgcMHk7psOmHjYJQMdcS48DlCf9qNWspTggA AADghjPIWQB7
HQ720el0dNlu7+m8fsV3eeH2+ne2Ls1zU2vmlpV5ZKX3l5GSVle0xJjPLbsK cKZYT43ZvIpf
F7YJdsV0WYqsBpcdsW2rSkvNmjMXAwAAAGA0qZOenm6OLrpMv69euXS+/bTv 0QphWl9LJJtG
j5vRRpgXWJwGWJlHLk6qIxcZFCZrzXw4hU1p3GjihUR14+Lt3JTDpg2EX3iO UyF8upPfpNAc
1E7zFr7e1uSyDXz+9ObVmIIYAAAAGPXqxOHoDQycFhg4nS4HBU2fOSuku7uT 38Q/xePtWR4p
PmEqII3HqQIwrhbkSW2lOA2wKo8LaQ5hl8HjjfFCOTZbH2+Ln7PPsDheWhCK i3P50VoVpqkd
UiDM6xeWXs3PURwvn5gYjBS2HSmpWhP/ekoHQ+5q7MXwNYbN4pSZOMgG87X0 d8eH21H4C/Xd
D6Pt2I0PdWK32y9ePNfRweIlZ9tsNuvHvT3d/Cb+KR6Pz/KwYSNlya18fKJE UAzGjJJGKimo
OOGkg2YeIfCyKLK6bL912LwSX9LqlEC8ZGhgM/3muea+rcsLDsHvF67uQ1o1 96Z/o36MtJ+1
NvaOKTeksSPjqDF+Oo2KFk5gnTcodXL5Qvu5M7b2U+zJHbpw4dzpK5cv9FHG 2lztHr1gvTSi
6IhNbqw0C+LEQx5JyJD0MFePDBsVyySL0P/D8nN9Q31TW1kgxVFc0setHwkM DabMjKNFO23C
n9yLR00m+GS0wd5Hd4NeoTsUVZ84RhJi9GPFday1X7n5hjR2hBw1xk+nif4n OabVyfn2U2dP
tZ492Xqg+rX20yfoqmd1UmsW+mgaS7anGQxpWyLTw7iEDc2RUlyEyZMCIkwD 7CGPkDOtig0u
EQfNmgjVIsZ8MYmNP/Ee8qgWLNOSFuXjzS47GuNxwcAJX5lA9h5k8qTu5ayI hETXzUFocAj7
5NQpUpZnWRR3D4o7CVfZZEn3pEjL4zK2IfcV542debJVYatWXErtK1KXK+bP PShzL/vOyU0V
N/FzF+9KdrOsYc3XukIUPRHyvgnXHrmqVp0hzFTKLpvqcNft27bUoO+rqXKn sU3iWcfMKtyo
yq/YS3lF0h4pzl6PvuJaO5cutJSmKqtTe8ajT6RaPNSl9IbMUTidvJ5OWkd5 AKeT9i7Ydpqz
LGzO0eCUl1s0zwGXzb7PK9/cOHHUyYMRC3Y1XNv7yZQ3rTdVWWfQT/WJmZWf TqPpWtmN+UJH
iaAFXOv5+VWSPmDjYOVP4mjlkQkUZfeLK4lbZ88Jc6XUC66+G1lOeTbJsjwd DI6Fa7Iiskvq
WOCkKC1G/BtenhVR3tHe1nGo8EgS6/pxpbQ3FHmNr9CcLZva+JyJe83jPv6p 9hWbVLkljqbk
RffhN7WvbDtTEwmfv60jN8Y9u+VIeD63qTyzOIn9RD6VvbScy1m+pOVEH573 Wlcfx1TaI67q
F2lZ9V6zOZYJPZHYT3xFQkPZWv7Wsr6meGNctC9NlZzG5ljeuq9eVtx7fvdL pntFymMk7qkH
XwnVuVx9qJBkezqHPfvE3Z+qujQb6dpTnE6eTyfto9zf08nTLrA5xk2mokNt HXvWh2ucA8pT
TvO88u1MG7MM/H0niTGRHt5rAoAnolduTExaTjLKO/RkB/fH39pkKnqBm2FO H5Noyq6pWx8u
pfQVSGhtIluLQ7eK65n0x1evX7enbd04DZxo+IqYitKilFt98pWN7CWe85sS V/C/0VFxGaTI
SuIiSFZSKCmnP5c5eaxjTu15b8clrMWSudLHOYykPdKHmzT3OieaXgZeKExe FnqPqfDwHrFi
NrNjXB5tR19NlTmNnpFxmUk1dblR0XU1RwrXs/xNXvPTO+ll2eze1VRYEkG2 ulekdRQ0z1Kp
taRVcjW3dy2suv74pI+jrHc/cHJH0T3F6eT5dBI7VsIGdTrR4+v5HFD7x3UO yGwST+eVb2fa
BO3ZkRhj8+wgFnID5cl6KvOHbsJb7uajXfjkTeip6mwtlmH0VXQuKxW3T4qH e7c2/MdFb1iq
2H/rUVO4vv9NjUovPFpTR+r2HRWvoF7z69eU8Zv2rElSVtQPz0utHWqUdam8 4WPVE/10GmhT
1afTMO2C5gEaX7+HmGcHjCwstiH7s6G3JpasUr4r+mCFZWNcNEupOGATU4Tw rBCUdqW4l5VH
YsftuBO1r9x+FuMyRL+5e4P7SVX7Sm9MICrvqamvKaY3dmRHLuuYp7/UhwtN R6zEk+c91EUW
hpvEiLeE5jH1da/rcpPo7WxFRHa2ON6odi/hrgc2H5rqXsGKhCP78mqa+GdY 9H3md+2vW0U2
qbXuZ6/2WSq2Vp4m7V2fntH8G9GsS91IqWqcTt5OJ7H2QZ5OXn6pZG3WOAf6 POLqA+T7qTtG
CBgSK7tfex0CBQwsmJLbUJSyPDiELWeWt7E/zNzympDlwdn0TmBjpokTNFzc NZhIKRplufuG
cT64XeUrW6vbVtFvvDc8lxV8tTbflZJR6J6fjdfLIkJF1Kt1JPueEM40F/3W E2+e76Mu1jaP
x9SXM6QuN5QNO6BL0WyXcwxteQvZI7KFvLzoo6n5ql/+mMSm7JZNbXrtxud7 vM65V0Sv+m5H
QdwvDW8QqbVyV7NNbJ988Iy6Fk+eVzSS2HZJVeN08ng6RXs8yv09nTz/UrFB KsFJoVtpg4ll
q9s54HYgPB1x9QEab7+Hujn6u9LSH3v3vQ9Pnmo7+v4+XC2BL0r03NnzcMXo pT4npCauPWeg
kV1642gmLwzTT9vwGK/LC94X15EbNTaOzw1s7UCqnnin08T6ex9NxKxKmT8v 9IH77y4teXVC
jjsBYDxSJz45GZJEynMm1CCcun3bhm4w03hubT+qnsCnE/7eRwXjMXbCTYO8 HeNehwfETgAA
AAwH8tjJwMedVBxsfKfpM3X6gxELPDxpzF5Nn17NvWtkkNJBtCSiZVHSKBAr AAAAwJhi4OqE
SpNnn/y6Ov1HL73pQZ2wd5ylcVphCOhT4rDHhnF8AQAAgLHHIGcB7HU42Een 09Flu72n8/oV
H8tK0w8L74pn69K8ObVmblmZx0eLfFiFrrJC1tIN6dXce+v5NdEiVxeXp9Qs rgIAAABgrKuT
np5uji66TL+vXrl0vv20j2VdL4u3RLI59wxpWzYXVPIaobaygJvDT5lHjjRR jiBdas1sch31
hMaGtO0l8dx766vSrFIeNpEOL0iq05tXYyJiAAAAYLyoE4ejNzBwWmDgdLoc FDR95qyQ7u5O
fhP/FI+3Z3mkMIapgDQetxJiXC3Ik9rKxpIMo2YeF66JcripcKzHG+OFQp5r dOUxxCbH85X1
WQoAAAAAY0id2O32ixfPdXSweMnZNpvN+nFvTze/iX85m8dXtLFhrWXJre6h DmNGSSNVDFSc
JMcaPOQBAAAAANSJFy5faD93xtZ+ij25QxcunDt95fKFPspYm4VnbeI5CUIT 9peJT98YYpMb
K82COPGQxwOGRZHVZfutHjJXN1uFPEIHEcvDdR4BAAAAYFypk/Ptp86eaj17 svVA9Wvtp0/Q
Vc/qpNYs9NE0lmxPMxjStkQKA0c2NEdKcREmTwrIFv5ZHA95RMEhG3fCBp4Y 8y1CbmVmbkSL
iWUy5LPxJvzA2UgLhpqMLMKLg8RPyi4bfNI/bDtSUmWzovOrbEIQuWOlOYZs O1ODQ6T87tly
6+FNAMCoZuBPFD8YsWBXw2eETOE+bula2Y35Tme+l3VRSVQ5+8ojZEtTJSpz S08Uy+y4F8RT
xyNIe1sHXjs9LGhOqMEme8vMIBUHbOvW6t2z0aOwPDi3fMy89x0AAHXSDxJj Ij281wQA32IB
u5KXZfPziZoKG8rW6vkLZ5ZFftFlKRUJ/Fbgu2+5eeZWHrvnxYO2tWvcfadf t6eBpJh32KIg
EwEAoxTMswNuGPo1Ze1tHexTvjT75To2WejyrIhyLqWhyAQHqWFzvYodNJKM kycKXTm2A3tJ
Qow+Oi7TsrdWowuNTbaunL0dAABGDwFDYsXjszkAeLvBl0dKwm020mQqekHR 3UBv9NvWwVUC
8k4crptMmShsqt1LEl+gSfq4jKQi1rkD1wEAxhSInYAbKE0qEhpkkRJbiwVu GRLXHqywCAGV
xGJi2XtQFT2xtTaZwhfCUwCA8a1OEDsBA4oEJK7Qi1dT+l9UXIal4oBNJWJc z6EAn8TJgb2W
DL6DjPWaqTt3uB60TRh0AgAY7+oEsRPQb/TrNi0RBkw8dWwpN8okOrd8afZy 90EVoE/k406o
kquv3UuK0qQOMknzubIVhTfggR0AwKhGN0d/V1r6Y+++9+HJU21H3983ZhrO zXW83fs0xWAY
oEo09duPnjt7fnirqc8JqYlrz4mGwwEAYIIQsypl/rzQB+6/u7Tk1ZGMnYiz 5vgw3/CwqJnB
1ysZGRJrQEVdnhgDSCLlkCYAADBRGclndrh3qHExjzEPXuM2PETndLTnwA0A ADDRuWHjTqTp
h4VYCls31woba83csjKPvFhYerXSkLy4MslrC7QLqmq3lm5Ir+beoL/KbHYF UeRGuJhKqdmH
2gEAAAAwrOpkAM/ssEAKjyWSTc3HzYZTyV/OaysLuCn6lHmoemAT5MhnLXal sCl0BEljIhah
nOe5dPouqKrdkLa9JD6+pNXprMpY7MEImwCoeTVfanPBc+j9AQAAAG5o7MTT dx+hC1MBaTxO
r+LG1YI8qa1sLMkwauSxHm+MF7aIRlwphtjkeFreur+MuOfRrt2HgqoW9m2E LkktNCyOx/kF
AAAA3NjYiadvbWkSVpbcKo+CUHmSUdJIL/BUnCTHGjzkGTFubO0AAAAA1Mkg 6ce4E2uzMF4k
npMgNGF/mZDCAhCNlWZBnGjkMSyKrC7bb1WkcL0ufMrm1UZqgwgp3vCloEYL CalutnoxghMK
AAAAGCXqxIdxJ+KAU1NjyfY0gyFtSyQbXkrZ0BwpRSaYPCkgW/iXmGjkMeZb hCRXChvxwQ+T
jbSwYSZsdAifohyXWi1Y45L7KmjVaiE3OIZmWVXcTLRrBwAAAMBgGZq3sfFv 6II3JwIj9DY2
AAAAE4yhfxsbpAkAAAAAhgrMswMAAACA8ahOEDsBAAAAwOhSJ4idAAAAAGB0 qRPETgAAAAAw
utQJYicAAAAAGF3qZCCxE27CPOto9s3obyEAAAAwHgkYcMmKg43vNH2mTn8w YkFiTKTGlV6a
VZhstjgH+uYyamcD2V7Fv6/NQwZXRYOpaWRlkPedAgAAAKBOfIFKk2ef/Lo6 /UcvvamhTgib
Hq+VvwDXmnWrSlu3D6hWQ1pVVV95pIqYUtGZx4RAAQAAAIDIoHp27PZeh4N9 dDodXbbbezqv
X+m7mHH1Zmm2GnnvibQsTQ5MUfSt8Hm471Kz1uvqFVKmtaTxOYVNziJblcpR ucQtK/LIK5VX
xWo3m+VJshRzrZBbsK6uV9lya+mG9GruLfvoRwIAAAAGq056ero5uugy/b56 5dL59tN9lrKW
PlcQv9jgcXutmU1a09fkwNXpzau5PJbNBc95vqqzifqoEqI2m7c4eZvJZRtK rdyMOZW8gKit
LGAT+KnyqNrDJtXhRUd14+LtYu18Ep/CVjeQ7VKrtGwqW87m94mPL2l1OtG3 AwAAAAxWnTgc
vYGB0wIDp9PloKDpM2eFdHd38pv4p3jcnuURJ+ELK0tu9TZw5HhjfEmGUSFo hACEOP0e674R
8hgWx/ctiI43kgJhgr+w9GoucmNcLciT2spGZksrj6I9htjkeL6MOH0xs0Ia j1vFFNoYacFD
vf1rOQAAAAB10i/sdvvFi+c6Oli85GybzWb9uLenm9/EP8Xj9iwPFx5geA8R WJur1RGQtCqh
aMbi/jWRaQsuTiPVzuAGohgzShqp1KDiRJQa6jyDZzhsAgAAAFAnnrh8of3c GVv7KfbkDl24
cO70lcsX+m1FjFJY95dV89GI6rL91iHZO65TZkuagfXvpBfXKjVPbHJjpVkU J9p53NJZC1kf
kLyGygIpjkK8lfXRCQAAAAAYlDo5337q7KnWsydbD1S/1n76BF3ttzphgy4a +b6PDc2RXE+H
Md8SKXYCpVcPoFliF5JO99ziViFOkt8qViMb88rkSQHZIoRytPPI09n4Ez78 IVVhIhZvoSBP
NpVO2LKZdQBhVCwAAABA0c3R35WW/ti773148lTb0ff3+V6yf+87GWjsQ1e5 etT1h0zs15Ps
fu311G8/eu7sefzxAAAAGEJiVqXMnxf6wP13l5a8OvD3nVAJMmQqRKVJTAX8 4maL04gDNj64
93u/8SXbP3/77/AVAABMcAKGxAp/Pz1UbTLmO535o9hnvrwRDmhR/x/r+AWd zo/H39+f+2Lf
dHXJdwrhJQAAAJijGIw0nqQJZcjqsO1ISd1hG47MY4IxtEcj3NTxd6wBgDrx AuYoBoORJvf8
eRmfJs+ZEhoc4vrk1I3+i81ou/INrD0+lhrHkg4KBoBRwND07CB2AgYjTZhM 5sInbrlNRYd2
r9PDawNGv27P7rFpfBz7DQDgG4idgBE82zii/vqwQprwm3Q6Xd93t0IoJXkn d5O705xlsWQt
Cw1O2UXX63LFWEvuQZb9QJ64Wu9uZldyiJsdSktpqluKK490Py0vwt1e73Sz r2iMus1c+MdV
UBYN0rCmXaPYEr6sbWeqe0hJKrI8yyLFABQ1Kn1I3PxW774XXhrv1h6vrlNH JlTtP+DDvu/U
PJryOIdrf3NyUz0Y5D2jcQ7Idjwvx91vmg1z3zsAwOhUJ2M+diKfjBAMpzqh ooQu3F/5oFya
NKce1XFxFbfc3KVC1rNTl7u8ZVNbRzv9NCTuNdNrg35tfpHJVHSorWPPGrIz NZGUc1vbOnJj
WPGWOG61PLP4RbcLiX5NGZ+tvXxp9svc9dFyJDyfpRwqJNlmdmV6KntpOZen fEnLCY2q1fbl
jZEiPrRgVkQ5b/lIUh5fF18wL9p9Z92tqWrUh0VYaEuI7WBFxEayj10sT7SQ 8IUuE6662huK
TBrGaY3qHbG5+S1KvhcnfGi8yqDSdZLTPbe/z30n3o6mBuLRZJmT+DNH6RnV OSDb8fXhng+K
Bw8DAMZq7EQ+7bDnSYUHqBg85uRqHZjsgF4ZBvh4Cb+slib0yy03d6kQLiH0 cmhrbSJbk6Q7
YIvsysduamv3kqK0KLfiwqo+3OQpBpO0lRxtZZc6U+IKTlHoYxJN1DK9lLK6 2J19dI6Hqr3Y
d1XU2iRmY5a31dTJCxLPrdWoMXrlxiNWGzlxbOnK9eFN1BLNsyRMr1WXR+Nq s2q/9avxaoMK
17myem5/3/vum7dd+yscTRIVl0GOWOu1PKM+B4gPB8WThwEAYzh2Is04YyEm Xy787MHdwb3x
zLq/jGzeTAb0XvzB1w40YiesQ+fwNw5JKXJp0nfPjkKvDKwR9LK0vCKhwfsd cHQuqyJun9Sp
MSRV9wtVjQu/RFpsdfuOhi/UGxOO1tTZWiLiogdvdqjbqXKdSD/aP9ze9ukc UJdqseBvGIDx
FjuRw2bSabZywYlSsxhKcQVXuNVas+vV765NkqjhN/O5raUb0qu5V8srNA8T J8kZqyPFaXsU
NcqN7Gfr+82yFvCxE1a1FOmh+RVNFSrUaCDwHDuhWqQx+UO1NOlDnbCugazS elU6f29NL3hE
a6vXe2vbwQrF9YalbIyLtu3IZWNH6IX2cKHpiJV4qJp4aIxWmwXLPnpKa2f1 MYnkxaKmBKOe
6FckkH01JFyvKFJxwKa9Xx7NavpNcKkPjVcbVLjO5nP7+zzQfflcY6/ra4rp sY7S8ozmOaA4
fAqi4jJEOwCAcRQ7kURD6XMF/LzB1enNq/mZe7np+iwssMLmpaEawJhPl+J5 TRDWvIUPurQm
l22gl38qBkzEIk37y6bqiecCM+7BDk6cxBrcZhV01ehuJFba5HRaNhc8J4oM bgacSl6e1FYW
sCkAVe1h6ohvu9MSicn8+oid+IlP7fRPmvDxjIaipiT3MYn6dZs2sl6AlF1k bb5rKz8q1sOF
f92mJcKIlqeOLRXum8UxLsv2Jh7KiaYXSJJ9D2fqnr0JhWv1WlVrWhYaY1O3 eVn20vIc36MA
mjsbRiwkIYZdVPUGUnw0fIXevUj50uzl7vvVt1m9m9/q5Xux0IfGqwwqXecm O7y23+u+ez6a
LxQeSfJwNEOSSDl77EvlGc1zQNrxl1s8HhTRjjS6FgAwTAx8nh1F7IQKFE/f QnhBmtKPKgmq
I+Sz1SiW2eU/38gnbicb3OYC3GxpXfycYpobzYlvXIm1ZjYdYFUa8VCjugF8 vXyKONdPrXnV
8QzOiKI9ztWV7M37dGG0TQg0LAx4np17v/ebo3/M5qUJ/4SOWprov5mHN9mD QWHbkWImLwz3
s+j1OSE1ce050fA3AEPI0Myzo46dePomclEyAOuKgtbS53yJ0Owvq66uDtOl Czb2W9NiB7Rv
xoyS54prCalsTM6gjbBq7IiRvXmf9ROZJoxGGRj9elE9vUNVpLS3dcCH4AZS lxectI1fzCxv
gzQBYBgZHfPsGBZFVpuKa9NYjwtVFZu3VGltElNik0mYWwqlmnWpGNzFiUsp sOjJfqtcnWga
8dC42OTGYjPhxYlGe6yl5v2x+WmsL2rxqg3HrcRowHmlQX+DItAiYCAM57vU onM62nPgYgBG
glHyvhNjPhtvwiL8bPyJm2RwbRKHnbKBJlIKG6fKjQ4xyceksjEnJRmSGbex J4LmcDOyvy95
UkC2COESVXsMiwgbksvaXpa8Hc/5AAAAAINkKMedDHHTxOEiuNyPKgY87gQA AADwgnzcyeh8
Vyz3rK+psQSRCAAAAGDiMTrn2THms+dzETYBAAAAoE4GCuYoBgAAAMDoUieY oxgAAAAAo0ud
IHYCAAAAgKFidLzvBEwA7v3eb3zJhnfFAgAAGMp3xY5Vas3sTfQE73kdfk/n /yu/IM224+8f
wP4FBPATBC594j/gJQAAACM17sQ1ja80RTDpu4iPU/6qc7pV591KrdnUyKYQ dEKajNQ550Ga
0KTBmrbtSFFMGqdOGQ681NJnA3xsYX2Oa6K+oWobAACMb3XiU+wkntcATqeF mHyRHYa0qsE8
UyxV15pcFuZZD1mPN5LIRQacCTdemtBvec6UUHGWWvZJ3jkaLrD9v9LbDlaQ BKPed8vaVdTl
Jh0pbOhob+vIjRp+wTR8boFUAgCMrtiJHPZe+WYrF/AoNYuhFFe0g1vl3scm RD1cmyRRw2/m
c1tLN6RXV7OXyWtrHsOiSI2YCp+31swmHGZvwWcJiq0eW6jYKg8HyRum0XKN XYE0EaWJMnZi
KjrUxq7H3KdsrX5M7vKJYyQhxoems9lhPE+ra2ttIksNQ+UB73WNBoMAAKiT kYuduBTCcwXx
i1m0ojq9eTXfo8JUQqSFi3SUNJrohZ3NqVcSz1/vw5q3SFGQDfSiTi/xJmLh k2hhNmNOPBcp
0Q611FYK1WmYYpPm8GWdVYuKlVsVLfS01em0bC54Tt0wVRGmo/i9dFoimyeq OvEoTfro2eFu
u3fmBcs7OGy7klXBlZbSVK1wCy0e6iFdClqE5tRxSTtT2YLKuG2nOctiyVoW Gpyyy8biGWJo
J/cgK3bAvW18zGPfNk5VqGuXUpZnWVzNUFQhBk5Ynq1JNDPN4zLFtdblFr7x wl657Lzcomyb
uMuuHZTHM9jWnNxUZX5XFYoG8F1OLh8qnCzzUr3m3gEAwDDHTjx9C1S75soT Zs+JFyfqsx5v
FJcNscnxBZW1Li1zvJGPbXAzBFazoIv7DH+eEKtzTdajNuUmmrS2ylvoZath MRNSioapi7Ao
Dk1hURVj/kQc5eJdmijVCXcZc7t8WrJa4rhQSnlm8YssRb+mTAiulC/Nfpm7 OluOhOezlEOF
JNssXXTpBb5lE5+zIXGvWXYx1odFWFpOcF0wERvJPiYsTrSQ8IUaxvVr84tM XERnzxqyMzWR
lAuhndwYjbYx6muKN8ZFa9TOBEcEX7yhyCSLQsiqkIIR0bkNQmL77rBSseCh wiNJefwu81Xn
RWvaWR+u3Tbbjqeyl5ZzrSpfwjwg87zgQ5Y/iZMgripcLRcaEJUn7oJ6N21u XorS3DsAABjm
2ImnbwFpIEh/R5NIBfs1dJUv1VoSL1ch3k0NZqtPLeff0L+60vehweML79LE W88O33FgKkrj
R13ow02KiEjSVnK0lV13TYkruAufPibRZBEvuqxnhIs98LEKi/xiHL1y4xGr jZw4tnTl+vCm
mjqWeUmYXtO4K8BQu5eIjRFbq2wbvVzXbM2g4kRdO00xuRf3EVlBtoPbaurk VXtCq21MlrFW
MfERnSNXNi4fkqi4DMKc47Kg2QBPTlZ7CQAARj52MnAMiyKr04u5y7V1f1n1 5tVGrU1iSmwy
cU9hkRIPHSWGtCoL4cMVGqY8tKHfWzUbpi5iLTWzHiG+16rxuHUCqhNv0kSn 6+fZSNXD8oqE
BnUEQvsKLRvF4nYxXvgl0mKr23c0fKHemHC0ps7WEsEkRX+Me2if9agpXN9H 7TeO6FzWmLh9
oYpeoUEwGncTADDhYyeDgI3/aDTxfSCRFrfAhGuTOJiUDTSRUpjuMKRt2cz6 ULRHmgoG6Ea1
KeK1It+3ilLIrWGqIoZFxNW7NRHnX/YuTahf+n85FO7ybQcrLAppQFNYr4oY J7BklXp4Flcf
k0heLGpiT9boVySQfTVElBRaxvm4C9UxxKNBWXyFs6CunaVUHLBpt5xY3PtZ iKKgYMptBzXx
YofTdrls8AfVKIcLTVyARE19TbEUR+mzARq7qeUl760CAAD+ejFUsZM+BAp7 PNhrCl39/+zd
DXwU1b3w8dmAgtYWWwgp4EIiEXn1oV55i0GyxVxDSYX0IoKCt5p8qgFEeDRw lY8K9to+GmzA
C9p7m8DTikoRRXxEsIRnw4tYFZVHAwSFZGkUGhAtXJGwLzPPmZndzb7Mvmaz WZLf9zMfmMye
OXPOmdmd/56ZnaMU+yWw1W2TBhu/FLREvWRSHjJzn+RGWW0NmW34EvqtuNUw TeAqAcXshH0n
MYQm6n0nC7xhSMWmKUGn6tnzh/TU01jmzLMErCW+x69Xr6q4+wn2rZh+Q890 71d839+YmLMk
q3RrubrAnCmtfiP7I3XWKHOxxTk9izJWWSr2byhvyXBuxQqDs7/6W+IKc4it L920Pf2Gngt9
Mw/ehMHNGb5ZzdvU5K2gZNA4ej5z5klStmGgIy0cmb5Qb9z9G8yGLS82Mdvc +EK4Ahi/5K7m
LN9W2nR6aU742gGAm6m3eURxyZ3vf/DJl8ebDn1YnRql0p/eWlDZsLUTdjCk OD0S/erk17Gu
+JP7/uPA/34gfGhi/sWyDvMk+z3LelbnR/14ktTR+ML0MumZmH4hvPfx9Gez P+JHxQBaZ/yk
6f36ZowedV1V5YupOc5OXifvY+ioYnpQfXpGz4Alp5pOX0TBSfVz825+vMPv 0j1LM6asliwV
+5YRmgBIIMbZQZLE2ilyUcUiwXKXNl2cd4Wqj1aLqZqnl3JwA0i01PjNDgAA QGKjE/pOAABA
akUn9J0AAIDUik6S0XeijbpnS2xKAADQUaOTyH0nLYPzxjk+rzqIzfC60pZM 2vJR8D6lDVlW
3xjIO09gBABAikQnUfWdeAedaZi2MSvm0MJWJ02bPNgnE/UxrG0ToNSUqQMV KvGMJaw+lo1H
tAAAkALRSWz3nahD9eoRR1D3g/ZvVVlw70jNluXDB2b6xwEiQHnK02MR2NNR t3qSz5JQ/Rwh
e3O82/KMJRy4CVtVack2bRjkSVU1LfNlZSFrEbQ5g1IDAID2ue9ERBoFg0N2 MGwrqZusd1s8
tPwpz2lbrOI7NKA3ylEH/6spy6pb7O2VKdVW2VY7+Hm9h0UqKTU894u1SoZb 3d0wBX4v5U3W
Ru3xCY6CN6EOqVOgdeRsLc5rmZ87OEQtgjanhjfuBTH2zwAAQHQSdd9JqH+9 J2x9BDzTU4PD
PaG+oHKuHoZkDi7wiWeCgxM329Faabl7rL2skm36YMUF0yZqG8icOK3AcPhi sZZ3Q0HUR9UK
k7e4uz4MNxFeQC2CN6d2IC3Xr015+mcAAECi+05C/es9YTfoPQfbYu0qUM/t Bp0t3sXem1FU
0Z3p1SEGI1GDFOtDy7fUxLeJCJvTQyBvBAQAABIancRw30lm8Var1HI/qydS se3YGDJcUH+u
4+4L8aFdK1lcnKle3ylZXRNy1W16r0vAhvImP7Rt4w7DKMlWNckbLegBUKhN +IZZ4UOu4M3Z
qsrUK04iRhHxWu1RG4ciAAAJjU5iu+8kr1z7wc2kKqn4eXVGVVo3vCCa4MR7 eUi9PqR3Yriz
87vD1JNM/fGNSJQZvKG8cutwT6ISv8Aoc+I0b3Zi/eeLMw03kVm8WLs9ZZJ2 F4p7fnVdyDoH
bC5zoNRSxuf5nQ8AAF6m3uYRxSV3vv/BJ18ebzr0YXXcfSdt90C2mjLTlslK G96a0eYbaNfN
JZq+r786+TVvHgBAAo2fNL1f34zRo66rqnwx9Z8VG+6O2FYGCW4Wydr2sUKS NwcAwMUr9cfZ
yStvm34G9w9z4rvLNeU3BwBAZ49OGKMYAACkVnTCGMUAACC1ohP6TgAAQGpF J/SdAACA1IpO
2qTvxHfoPgAA0Gl0jXvNzbtr/3rwb8HLxw7tP2X88KBAI+CRZ+qj4bfG9wwy v8ziz8Y451Lp
eZGfd4YDBACAiyg6EaHJb+/9WfDyh//zraDoJLN4q1Lse/pvZam9MYkaqZQN TNRvdEUxt3JI
AADQzlp1ZcflcsqyOplMJjHvcjmaz38b/eoitPB/OLzPEt9rOuqDzEJc41FH +g3OTkusXhgq
K/Msco+c05ImaIFYyX0tyVZVWrJNexa+/pffKlqaqjL34MXiNc+YPKKUXIgC AKC9oxOHw665
IObFv+e+PfP1qRMxdVW4n09mHa4OsqdGBcOt7gWeQfVEAGCRrEqI/paaLcvd oxfXlGXVLdZz
a5i2sVQfbad28PN6dg8tt4goQhs4UNuAOmxOWYgtaqPyFGiDEm8ttgWuomZb UjdZf6iaNr6O
Noax9kjbxVwKAgCgnaMTWXZedtn3LrvsCjF/+eVX9Lgy3W5v1l/Sf8UT4bc8 3m4Jy3Kp9qhN
7QhZrg9fnFeuXazZVpKlxhxBF268YwE+NdhziedorbquZ5g9fcTgAs/ggXmT HxIbqDlaW1A5
V8src+K0AhFWBG8xsIRBq6jZupe4c9YWttXz9gEAIDqJicvl+sc/vjp9Wu0v OdnU2Gg77HTY
9Zf0X/GE+y2PesvIxmkNem9HpXvcYPWPyVu8l1EKKq3eHgtfWseGutY2b4eH Z2FsT4sP2mLM
9PCE4AQAgNSITs5+c+qrvzeeOq7+ckfMfPPViW/PfhPD+p6+DduOjdu0eKVM vSAjIgYRd9Qe
1eKOzOKtVslifEOH/poeVWQOHL5NvTpkTL0ANG1iXksadYsinDDaopse92QG rRIcnswVAZSl
1qc/BQAAtEbX1qz89anjIhxx2u07t7186sQxRVG6dBEZfi+qlTOLFw83ZZlK 1CjloYcKtFBA
KtEXaD/Kydyx0d2/Yd1iypokGf10OK+8oXJSlmmSSK7PmdxxT2XD8/oFIC07 6SGroq7sk0Ys
0cIJoy1q95OYLKbl6sKAVWxHgyoycVpBgTQxk4MJAICEMPU2jyguufP9Dz75 8njToQ+ro18z
luedtIekPbOkpqzl9pdOYP3Lr8yYedtXJ7/mzQMASKDxk6b365sxetR1VZUv xt93IkKQlIhC
2pv2Yx0lk4YAACBBOu44O+qj1ZLRn5FXnqiHwQEAgMRFJ4xRDAAAUis6YYxi AACQWtEJfScA
ACC1ohP6TgAAQGpFJ23Sd+Iekw8AABCdxC5S34nPaMQmg0GIY4xZEpUVAADo uNFJpL4Tz2jE
De6xfxVFiffXvgnMCgAAdNzoJL77Tny6QdzdHy1LfPtDasoi9o8EZ+XXyaIt M84cAAB0yOgk
vvtOPN0gimIdrg61Z6sqLRludS/wDD4sYgqLZI3UPxKYlYhosjx56QMgG2YO AAA6anSi952E
+jckb2+GZblUe9SWOXC4tFwfczivXHv+6raSrKy6xdE8izUgK9vR2gL/UYOD MwcAAB04OtH7
TkL9GzKeyNo4rcGne0N9KLwweYsaZahhhFRQaa2stWizEUKTgKxsddsCEwVl DgAAOnB0EqeC
aRMztehix8ZtWpBRpt4QIsIIEWLUHrWpL2UWb7VKlsg3igRklTf5oW0bd9j8 IpjgzAEAANGJ
j8zixcNLsrSrMaV1w9UOj8yBkntB1sZpz3tvNMkrt4qE4QKU4KzcK+mZlWwL nTkAAOjc0Yn/
uMH6tRb1J8Hl5dpy7wLtJtiWxOrywNtiI2Tls8j6kDR8YGDm6LQaX5g+44XG i2JzSS6qr72P
p2f0FNPSvalUqs58IFGpztxKSdti8IZi2nSYz41Uj06SSP0Zsvs+WcnKXbAp IN17iIvDPWPa
uo79Edgun/IJ2+iepUUHKvadPtV0emlOFJknvLLRZ2iYsk0bPwXP394itW/Z ElWMgNVTp8Hj
fgtcFDFf3IVsWdHoc6MVunbUs4PaVVJOSJBCNg1ZULV3tjhq96xZIFXsn2Wm SRLNPHvD+oR8
TjUclIbdbE76dtsuQ/Z7Zy5Pu1f5omgQvZCNL8Rf91g/Nzpt3wlSTe49Kw4+ +0Jj4wvPPjdv
/h1md9CtdQOmZzy+JyB4Nwjk9yx1J1a7DRtfmpbu/lPrhtHSr1vWM0S/os+6 u9W/d/qnjCq3
ltL2TPd+R/Rdy+f0vq5sgdW64PqMntPXHAneXOgVfUriqX7URX18j95oURbe 96uP714QbXXD
Aqu0qsgvZdgaeXZWcOE9u/LxpTMC07vLHFwAvXM4ZAv7HgY+pXqp0aDxxcLA 2hk1dVQ7XV89
xj0bUFOfY9uo+t5V/JvLoBj+Te1u/7AV99to47oZ3veIaE+jjkyDdgv7BvTd +rLHpwfuvoAy
xNX5H+rjQl3u2TszQjSpXy1CNXvQnpKiflNHfguEfjWGhgq94+I4bIyPIuFI 1QyjT6dQn1ru
FQ0/N4hOcJF8vZg/ZMGDZZuHblqW6zkLDt2kdgN+VHGgaNme8J9M62ZMkbTE ereh+Y6N+vyp
TcMWrtHWtS44kq8vmbf6Wd+3h/+64w1SRpFbS2lP7VthcZf/yHx9rX1T3ijz 3aJ5VvkKi2XF
R02nN9yTbZRViBUbX3hw4bBN2kubhhw5JsVUVL1VpegK7xO3Be6F3KX73IU/ tX62OaoahSh8
S3kOZJd70hdpH5QtZQ4qQM6y0C0ccBj4lOoOs0Hj33EszDEW0073rB77ng3e O4HVD14loLmC
imHc1JEq3rJR86z581Zv1xbu3b56zoKgjszgikd8A/q3TKg3eMg3qT8tCHCf ONVznlFu5qyh
VrXujbs3D50jVavn42NHpOwBwU0qPnnmrKrWT9hqffNzo99T0b6pI70Fwr0a fUOF3XGxHjah
yuPJ56MKaWHLp1OYjzv310+jzw2iE1w83SeSNKU4x9MNaFmhz5vHT7E8tz1c eNJY84bkThwY
yBetkg41qG8VT26SOdsSft3glBFz8ymtz+UP7YuC/gFqDfowCrW5MCuKD1z1 JfX8nfu49ikZ
U1HDbDE4jRT7XgjTgIaFb0k/ZYL+cZWTP1c6YGv0ySFMAYIbKnhXRrxEFaZ2 sex048aJZs8a
trxv9Q1W8W+uvUHFCNPUYSruWxKRs7Zwz/ZVc/NzI68ezRswpjIEvEmD2uej Jnck5A5VDXLL
vXmOeiwd+3zYzfdkHxQLRJohWWajJs3Nd5/U92w/UHFPbgx7KlFvgTCvxtRQ YXZcrIdNqPJ4
8lHX8n46Rf9xlzhEJ7gIiU/GGzbfus+wM6Btcms8Yg3/GRryK1ekD1+/FXOX qkvyqzNC9DDH
V3HDwrdB8Bmh8HGIu4WTfAi1psDx1LH1TS1O7auq9+6pfm7ezTkp03oxGnCN dKRxT/Wh7AHm
vFsPiRDqyFD9hB3cpDklFSKBJBJ7TuFtcmiF3y8JeYO0ZscFFCDG8rTdm5Ho BCl2oSdrqHVB
lX4vxe7N1jna54onJFeX+CXOu1VyJw4I8ANTGmwoaF2DN16k3MTXEevmnY3G 5Q/ROx3i60WY
FRtfWKrePyE+NfZXWLQ+hjiKGk3hw++FWGsUfeH3bl/t/YYXsQDBDWW4Kw1L pS8MX7uILRlq
9Tj2bBTvgpDNlRNUjDBNHU3FPR2ZB4umHKwoyY2m4lG+AQM6AqM5tPxuCont 40J8uZeeXXHw
1jyzZJ5wq1S9Xco2h2pSkeBA9bLtWuJo9pR6h4fPzUyJeAuEejWm92D4HRfT YbM3whvWrzBx
HNut1mF/s4OUp16nnH5Dz3R1ft6mJvEuyH2mYtr1GT3Vj7458/y/kKkXfT2J pbmbTs8f0vP6
jAVGKQ0+2PzWrVgR9PrsKHLLXbppe/oNPRd6vkb4l1/7YuF7tVW91N2zKGOV yFCSskNX3H9F
c5a0cGS6tg1Lxf4N5po34ilqNIUPsxdCtWKYGhkW3vczfYFeZm0Ts81+vwsI UwCDhgo4DJbm
eEoltui99cTsszBU5lHu9ODVY9qz5TG9CzyrBDSXJBkUw/A4CVPxxgaDqN1i kcabo6x45Ddg
YMsEZRJchlZ9XGiHnFW6tVyLNzKl1W9kf2QO+f4SoczBhUfmN5mj21PHjlgt es6JeQuEezXG
hgq142I9bHKOLS0yOoq8+ahN5y1M2I+7tmHqbR5RXHLn+x988uXxpkMfVnPO RHjrX35lxszb
vjr5dedtgr2Pp2/PP/V4LoWPivhyXCY9E9NnmSjks9lJ+PhLRXE0V9xHQqdt 5Iv6PW6445J2
2LSx8ZOm9+ubMXrUdVWVL9J3AkRlz7KeRc9JUsQ+BgrfupIuzZiyWnyX27eM s2bbNvT2VXPn
n6aRjUNE24G5+cvYce2LvhPEhr4TAEBb8O074a5YAACQWohOkHQdeAytWMv1 0rT0ZXv2LDP6
dUCSGyR0E4UupPq7hvRley7WnZKyxyFD8bVpm6sPI+7o43wRnQAdIESItthx lD/SKubMYZL6
2AbL0ExzytYiVCEbX1q4cMjmmO8cvNhPvXGMUEhQkvxxCsNsKGeZ+nzbMuK/ VMddsUCUZ+nY
h/KKYhXLNQPaoRYxjvVlVMg9VQulin25HBeJPGBoiuTIKal4dqQ+KClSFn0n SJI4B8aLMDZb
ywhexuOBBX+jSubYZhFH/8pZtuEOs/mOjdqnpF9JjLbiHuVLHf1uhu/wY4Gj f0VVi+jH+vIr
pIfvc9ViGOwtYeMjGo3hZ9Q+YfMMWwDDgdOMxh0MdfgFD85nWOUUbJlUHqcw 1gPeuM3NE261
HLTRe0J0AmhPc4pnYDxJipw45HhggV/322dss/Bjg3lPTn4lMdyKNjqXOsTX QqncZ1tBY+xF
UYu4x/ryFNd2wKI/djO2BknY+IhGY/gZtk+sh1b48faMxh2McPhFMXpc6rZM So5TGOsBb9Tm
5sxh1s+P8bFMdAL4i35gvKgShxgPLPCM2k5jm0Ucs00KGqrQeCtaX4XYhHfG 3T5BY+xFrIWU
uLG+WjfYW/zjIxqM4WfUPrEeWrGOt6eK7vAz3GLqt0wKjlMY6wFvPGJftiXU WwNEJ4DvJ0gM
Q0wFJQ45HlhM2mpsszYYHq/tapH0sb6i27p/G8ZUx1bVKKp9l5jDL2VbJsXH KYx7aMxQESSI
TtDpJGT4NKPExuOBhV6xzcc28//0jDw8XkBJ4tiK5HMvSMRa+JYurrG+1I7x N2oa4ytqQsZH
jHI0xHgPrXDj7QWVP/LhF+WI8ynYMqk5TmErDnh3s9kOuO/1jnIYQiQdv9lB ssQ3MJ7h17Lg
xMbjgYVZMYljm4UfG8yTKHB8u+i3EjT6VxS1aPVYXzn5c4tW7GycPcsc6xhm iRgfMcecuT3K
0RDjPrQMx9sT/xuOO2h0+DVGU+XUb5nUG6cwvgPePzjZ+YZ16Hy6TlIaT7JH bHiSfWppv9G/
Gl+adv3nCy7W0RCR+odc2w13xwiIqYon2QNodV/YHRUVh6bE/6xYICxtuLs2 CCBEaFJ0oKKc
0CTVcWUHuKhjhHZ8zpV51vrTs9gFHHJtI/fx07ltsfWcZaea2IsXAfpOAAAA 0QkAAADRCQAA
IDoBAACIB3fFIlmBcJc0wX7hW5oiFJNkuqTb92TBJdMaAIhOgLaPTtLS3n7v 8MbqfZ/Vn3bJ
Cg0S1D6m/v16zJ489pYx1xKdACA6AZLBceHcS2+9NyI764n7p8uyZKJFfChq dCK9uPmvoony
R2VxyRUA0QmQJMe++MfKJZY+PS83cfINDlBkqeR2y9TSj9PS0mQX7QGA6ARI RveAIitKc7Oz
S5rU7KA9AnW/RBKNI5pIvf9E4soXAKIToO2ZtIs5DpeIUaTLL+XsG8gpm0Tj uJuK6AQA0QmQ
NC5ZDU9kE2ffQIqsNg7tAABEJ0h6D4FTVi9eKCGik2Nrfl4qrXrrngHJLFO7 bDSIrKiNwxEC
ABI/DUCyoxOXS1EUEaK4J+ui7l27uqdFVqd6a4rs8r7aRpOtstCz0cJKW8wb FatPqqxPdKnU
ZnHRdwIARCdIOhGciBOxS5tsVZOvyFfebL5wRpveVN6qcak3XHgTtM2085Hs V6cc1je6fejh
BlesG73q7lf/z939El0wtQAuLngBANEJ2iE60fpOnLLTaat+VVpx8Dfj1Hl1 Gvfr34xTb0pR
qhd369FdnZZY1eUNVYX6nz26F66tl531a6YWrlnrn0Zd6E7TrUfhmga/Jdpa zpZJlob176fP
5z7+61xnbBtdXKPNN0RZjKgn0Swu+k4AgOgEyXfe7nI4XE6X7LTt2Fw9dICI Elw+k6xI1aWf
5Z9rOnOu6c0HVi1f2+CS+8x6Xf1TXTJ0we93GqXZ+ejQ0iFvaktqn7Ool0jE krr5+lq1RZvv
V/PxbCV34vwVU664rOcjO+Pa6JNjZfW+meiKIUc/iWYRjcMRAgASd8UiyZqb HXan06lIkl2W
Ldf0sct235fVhavuGiPbxdK+10yQZadI0PjHWdfP26knsFzTYJcC0xw9csCy 6il9ichBltQl
0srneqz05Du/3i5neP644dH/bnxUkvYsyehRIM19q7E4xo3qm4imGAG1C0s2 yc08BwYAiE6Q
fE6Xev/p6bN26Qf9Mq3Pbj1we9FVPi+fdThc0jdnmrt75w9U/s+8N/JrTq0U yb5YN+cxxzdn
pcA0B4/sdGX7LRFpbqrYumZWH2/OZ5pPBxRlxKP7j1gqsre8fVt2PBuNphj6 fHR6/eBSJ8Pr
AICGKztIcnQighPl/AXn+Qtjpz6hLMt77B11Xp3eefKxdxyyeL1ZX6LPi39v LByZri5p2LV5
r74kIM1Pfnrnrs27GnyWpPfP2rVw3W53zn5Tw5/ufXKXZ76+7sare8a30WiK oW8u21PHUPPa
JJqF3+wAAH0naAcOh3qPhd2uXsL40c//tME5e/owTwfHXX/eaT+mKJLD7lAv iNhd6nyvGTMH
9i8a9qBYMPque0crLvFaYBr7qF/94doJ+X1+q+eT87S6ZMvTZZP7jPMs2bB6 hvvKTq9xEw7n
jBum/zFh0ZYXfmRfH9dGoymGwy5ekuSWZIbz7ritm2gcjhAAEEy9zSOKS+58 /4NPvjzedOjD
aloE4a1/+ZUZM2/76uTXsa6oyBcmllY+WFyUO7Jvw4kzbVW+D3+b/45l+/yx 7dxMsRcjq0+P
PfuPP1O1adea+52EKQA6n/GTpvfrmzF61HVVlS/Sd4KkcqrP9pC/a1a7DKbc NDg4weZddXFk
W/v84CUv67P3PLnrej3/5GtNMbTHwfG8EwBQEZ0gudGJ+sAxxe5Qr+y8suPT 4AT6S7EaVPLp
KyWePxwOezvVrnXFULTG0QZLBACiEyAZTKY0k0lSpG+/ExGIk/YIIJpFNI7a RCbiEwBEJ0CS
ghNT7/Qr3v34ULM9mxNwsJPf/P3jA0d+nPF92gYAiE6QrEPtksuKi27c8Jd9 azdslRVusDCI
3sz9rrx7So4sE54AIDoBkkKW5VvGXFswdpA4DXP6DY5N9P+1URL5wQ4AohMg OdGJS5Z5FioA
IAo8KxYAABCdAAAAEJ0AAACiEwAAAKITAABAdAIAAEB0AgAAiE4AAACITgAA ANEJAAAA0QkA
AADRCQAAIDoBAAAgOgEAAEQnAAAARCcAAIDoBAAAgOgEAAAQnQAAABCdAAAA EJ0AAACiEwAA
AKITAABAdAIAAEB0AgAAiE4AAACITgAAANEJAAAA0QkAACA6AQAAIDoBAAAg OgEAAEQnAAAA
RCcAAIDoBAAAgOgEAAAQnQAAABCdAAAAohMAAACiEwAAAKITAABAdAIAAEB0 AgAAiE4AAACI
TgAAANEJAAAA0QkAACA6AQAAIDoBAABEJwAAAEQnAAAARCcAAIDoBAAAIBZd aQIAQFK/FndJ
E+wXvqUpBJNkuqTb92TBJXeSVgpVZaITAED7RSdpaW+/d3hj9b7P6k+7ZKVz N4Wpf78esyeP
vWXMtYHRSQdtpTBVJjoBALQbx4VzL7313ojsrCfuny7L4pt0J6Wop2rpxc1/ Fa2RPyor4F6L
DtlK4atMdAIAaE/HvvjHyiWWPj0vN3Xuux8VWSq53TK19OO0tDTZ1SlaKXyV iU4AAO31BVqR
FaW52dklTWp2dOqm6H6JJNpBtIZ6M4akdIZWClNlohMAQLsxaZcpHC5x9pUu v7RT33filE2i
Hdyt4n+q7qitFKbKRCcAgHbmktUTr2zq1NGJIqvt0KlaKWKVdTzvBADQHt+h nbKsKK6LaLIu
uqRLFzEtskZKaav62aSq+ijyFC0g2iEVWynqKsQ6Rawy0QkAoP2iE5c4VSni 5Ou0VRZ27drd
PU2qssnqwmgmseKkyno56vSGObRsuutia5jE1sU3f7L6iP1bu/3XN0XKVj0F y64oSqi2gMsV
VSu1arJVTeraPaa28lYh0VPEKhOdAADajTjtilOVS0wuScn/fW3zhTNiOvwv r2UvrtGXR5xc
6m0LcpSJQ+XQsunf1+Zf+og1RMqGo7XS8AFXxViwSCXU0ihRtVJrpobq16SF 86VXdzTE0jKt
bNt4q0x0AgBox+hE6xVwyk6Xu7dfnfplDZEUlz5fv2Zq92491Klwbb26pKGq sIe+pHBNg9O2
du59O7bfN7x7t6lVNp/Ei2v0dQvXrF3s86d/Vu7Jb9P/uuHg85+Wi5yD09cs ufa+HVJFobbp
Gm8x9Fe1bTV4yyzm3dn6ldC/8O4CiBZwhe1IaGmlVkwN1a/KU++bOHT7a9U2 TyEXLynUq9Bt
idVoibcKhdqfTq0RAlovrililYlOAADt5rzd5XC4nC5ZnLAktbdfVqeat1ZN HNRPnd/56NC6
+WfONYmptmjz/WsbbGsXzh26SVuyaWhdg+uqmSues0x8bt+Zc+tnNTw6tHTI m+pL+/6jdsoj
O9U8q0s/yxdLnhwbnJW+rYBNu7TYqFrkHJw+99Fa97aaXr1r7KzXm/RX3xy6 4Pc7/TLR591L
fEo4YYd/4d1bFC0g2iGqVop/sllfU26dcNXY/Aesr+1o0AtZXTtwhV6FB1ZN +rddhkv0Kix4
YNXWne5dM//Bmf3k1hUmcpV1/GYHANAOmpsddqfTqUiSXZZ3zLuhxxx1qWXV XzfMzrDL9sYj
B6SVz/VY6Uk+vz6jYJA0p6iHsuHUk+Me/Xexll2sKEtOPbFl1VNjxBIp48ap E+5/a+cvB8mW
VXdpS6TgrOxyhj7rzcH9kuySFMdRo/S+KRv/OOv6eTv1Fy3XNNillpfcyTxL vGtlZAYWXt+e
SW4O+zCTllaKW+OO1+WpT2WIMtxy747fWY/OniFKZ5k6LkNrnDG33Cv97sjn 1xgs0Usu/ix8
a+ejN0pbV95787+LGrVyv0esMtEJAKDdiK/RLlk+fdYunXU4bqrYumZWny/W zck7VHumubt4
2bvQu8IZadCRU6XSnor070+X5lYeWXqDSOOSvhHpvTP6ipLrbMCSwKyaT+sz vsmELw5/elPW
VMP03pRqId/Irzm18iqRft2cxxzfnJX8tiXmvUta8h9VGlB4LeNeP7jU6ZKj aqV4ndj26k6r
dWz6PP3PnG2f5+f41vpCs+T69lyYJaNGlfxsy9sWafXc8QubT59p7X6PWGUd V3YAAO0SnYjT
rnL+gvO8QxazzWImfcYza+WS7MfeUef7Z+1auG63U02gTw1/Kn/Jdv7C2PsO fPDwjQeONmgr
7vqs3j9xw67Ne+/+6TBvnoZZeSffZBd2lectzLp7xpWG6b0pxcyNhSPTPdsS C73F8F3iTay/
FFx4Lb1ogYi/2XG3UpyTbdcW651rT7x7QJvWlu7dYm3wrfXuv/xRVCcj3JJh tz9TN6uo7olf
Dou/GC1TxCrTdwIAaDcOh3oXgt3ukOwuRZEcdofaPzDy4Q2PzZ4+bMaiLS/8 asvTZZP7jHN/
5X96w+oB8mOjxj2m/jX6sb3lvUT622be1X/usOfVP1sS37vi41H240db8pRG BWU1w3Nlx6W8
s6ho2IPaHxMWbfnb5L4Ou90ovbeQvW6bObC/vsrou+4drbgcvWY8qJa5T8sS u9SS2F3Cpwc+
4V94ux58dBPtEFUrxee4dYfy9EMj3ZuTRubNfOe5d22TfWotmuu2Hx1fb7DE 24C9xk3ImSD9
U0b8xfCLtyJUWWfqbR5RXHLn+x988uXxpkMfVvOGQXjrX35lxszbvjr5NU0B ID6KfGFiaeWD
xUW5I/s2nDjTmZsiq0+PPfuPP1O1adea+53+5+w2bKUTf37kf0kPrLw9I8wS Xx/+Nv9PV68L
9Wriqjx+0vR+fTNGj7quqvJF+k4AAO3AqT79Qv6u2d6+xZhy0+DghZt31SVn 69rjzpQ2bSXD
Cl4/+t/PN9u/8/59Qf2Rr98SH7W7/lA0o+77IV5NeJV1RCcAgPaITtRHcil2 RzsPv/vKjk+D
FyaxVIrWDtqIf23TSoYVVDkcLSFPzykP/9Z/iY9BJZ8OUi/yJKnKRCcAgPZg MqWZTJIiffud
OO06O3NLiBYQ7aC2hsnUSVopXJWJTgAA7RecmHqnX/Hux4ea7dnhT1Ed3slv /v7xgSM/zvi+
UXDSMVspTJWJTgAA7abrJZcVF9244S/71m7YKitKZ24KEYKY+11595QcWTZ1 klYKU2WiEwBA
u5Fl+ZYx1xaMHSROVJ2658RTe22oP7lTtFLYKhOdAADaLzpxybJLph1opTB4 ViwAACA6AQAA
IDoBAABEJwAAAPHwuyt2/cuv0CKIiOMEAJC86GTGzNtoEQAAkHzLlv+ncXTC wLMAAKDdcd8J
AAAgOgEAACA6AQAARCcAAABEJwAAgOgEAACA6AQAABCdAAAAEJ0AAACiEwAA gPbXlSYAAKTi
t+cuaYL9wrcdr2omyXRJt+/Jgkvu5FUmOgEAXFTRSVra2+8dfnLt8Q5ZuyV3 971lzLWB0YlW
5Y3V+z6rP+2SlQ60K039+/WYPXlscJWJTgAAFxPHhXMiNBk1uMtV48d8/5KO U6//dkhf7H7v
pbfeyx+VFXB/haiyWD4iO+uJ+6fLsmTqEPVV1OhEenHzXw2rTHQCALj49Bg4 6Br5O+lCx6nR
j0WAMnDQB1tcaWlpsivw1WNf/GPlEkufnpebOtB9oYosldxumVr6sWGVEx+d NDQeOnzs/P87
VG9rbBJ/Zpoz/seQq68dcFmWeQjvKABA675zq5c2uqSZuqZJheMHdJh6vbn7 mKiUNmvSehb8
qiwrSnOzs0ua1OzoOLuy+yWSqJSoWnCVEx+dvFf7+Tbr/jE/GTz7F/lZ5gyx UdsXTZ8cqn/h
9f0FeV1Hj7iGtxYAIG4m7cqGLCt2l3T5pR3nJgxRHdl9T0ngqVqvssMlYpQO VWWnbBKVMqxy
gqOTv376ef2xEw/de5u5X+9P6+o3/+VdsfDm8dffWTRx/OgRm/+yV2x8DAEK AKB1xBdup0v/
2t1BuCJVxyWr4Yls6jhVVmS1UjGtEk900tB46O2a/Q9qocnv/mtj9e4PM3r9 UCxf91r1wl9N
yx//T7f+c84z//lK7yudXOIBALQqOpEVp9Pl6kDRicPpksP+HsfplNXwJaWq fGzNz0ulVW/d
E98FNlFdUamYVonnrptDtvOjfzJYhCZHj50QocmIIVevqVi05neLRIzyX+ve FM0pXhr1k8Ei
Ge8rAECrohNFjU7E+TrhU33lpO5du+pTYaVNXWirLJxUWa8nsC4SyxdbE79d NToJG3lowZgS
/ya0krunRdbEFFu9H0Z2xbu6Wh1X2/edfHKofta/5ItQKGtAn6rfLVKPHkn6 7rtm0dhXXH6Z
3uTXDb563Wvbfzb+et5aAIC4idOiOK8l/OEfjWsLh7/2L7XNb5rVv3Y92j17 ivL5az9V74kQ
J1PXsbW/yP/0Pw5fuGuA4pITXCM19pAjJBBlkCUlznqVDn+z+cJ47c/dD/9b jXzT+AQU2tMy
ca2dpu7E2KoTT9/JsS+azFdlKFpfTe9ePxTT0WMn7vmfT5377nzxnYV6d1R/ c8Yx7Yc8AAC0
ru9EkBM61fy+VFqx8l/7uP/Mffzg8/Kr1Q3q/R6Ks37N1Gtf/fnBN+7oJyd6 u+oU+b4Tve8k
nsxt1a9KKw7+Zpxnybhfq/MNVYU9unfTpsK19bJawcI1axfrS7otsbrbZEl3 nyUije8qesvE
W2VRHVcS+k70VtWbVtF6TZb85r/E/JOP/Orq/n1kqeVVAABaw+mSz9ldzsT2 YDQePTCx6Jci
+PCeMftlDane2iBfKymvLRwq3Vq7eabvqwl17oKoTrgHrZ23uxwOl9MUe5Ub d2yuHjo/qOR9
Zr3eNEvvS3kk4/c7Z/5KkarnfLbgXNMT2pLla3+ZY9n9i1vkN881ubtZdj7a o27+mXPr1Tz/
OOP+tbkr1fO62AvOOHvA1Eq1eXQywJxh+1vTsMFZ6h8m6eix4+e+a55ZdHOm Hppov2cWCfqb
M3hfAQBaFZ045fPn7XZ7QqMTuyzLktMu2336aFyS4hDLd0iFFUMX3r923IZ/ 7dc2NRLVcTrD
XbhobnaIFE4lrnpZrunjVy89avnjrOvn7dTnLdc02CXZsuquMbJdpOt7zQRZ dh7d8bq86il9
iZr+yAFp5XM9VnrWn19vHxTUYrF0gJnk5hif3xJPdDJ88NWf1tW7oxNFSu/1 wxlFNw8dnOV+
zor4R5FEApGM9xUAoDVkRXE45dNnmhOZ6Q/6ZVqf3Xrg9qKrPEu+OPzpTVlT zzocN00e/vNZ
W89PH/twv/3/lttG8Vaku2LV+09Pn7UnoF5q1dbNyXsjv+bUyqu0+ccc35yV HC7pmzPN3cWr
ospi3neJvvCmiq1rZvXxycQvQYx6/eDSWHu/4rnvZHjWZfv21x378qSs3Q9b s+ej9Zuqaw81
KJL72X7ipQ/214lkvK8AAK2KTsQ3e6fr/AVnQqexU59Qli35U4P7z13leQtd N+de6ZBdLrn5
gvPKKU8/fKjo3pdsid6uOmm/KJbDRifqT47jr1feY+94lrzz5GPviErdWDgy Xf2zYdfmvaKC
nmqqafT59NwJroXrdnvySe+ftcvnT2+yeKus/iw8CfedZJmH3HTD6S3b907O zzH37T3pn298
eVN13vjrRWAi2vuL4yfFSxNuMPOwEwBAq6MTxe5w2e0Jfq77j37+pw3O2UXD HtT/nPmHvz19
g2Q/rj5XxWF32KWMglV/tv1k1APOveV+HREJIKojdw3Xd+JwyCKAia/Ker2m D/P0etz15529
xs0c2F+v6ei77h2tuET1PNVUn1yrzWcUPPJ02eQ+4zytcd+Wlj+lnKc3LPFZ JY7uIlc3Uak2
j06En47L/b/v7nn2D6/808jBw6+9+o+rHxULa+saag/Xf7i/ToQmIgFvKgBA a6MT7ckfdocz
4Tn/sHDt9sKWE6gaDKRPe3KF+rg07Rw86p7367VgIsGbVrtOuoR/VqysxWTO RNRLLf+wefXb
5/mlaammt8pi5v1pLa0h+f7pv0pcIaZLTkp0ogcoWVcd+rTh/PrXt/9N+/Fw f3PG8MFX/3Lq
SHpNAAAJik4kp6J812zvMDUS1Qn/9Bandi7vSFXWHuMW212+rRqjWEQhWWbp 1pt45BoAoG2i
E1lxOBW7o+OM2Cuqo1/ZCfWrYqf64LIOVWVRHa1Skik50QkAAG3FpJ7L/nb4 ePfLTW+/d9Lu
6AgP0rr0EtOJ/3acPXbcW8GAKqeJhYr07XciOHF2mD0pqiMqpVbNFG18QnQC AEjN4EQ9k6WZ
0sQ3789PfNuRqtY1LU19CIhBcGLqnX7Fux8farZnR38iT30nv/n7xweO/Djj +9HXiegEAJCS
p/BLLltyd98n1x6Xzna8yimiarJsCq5ycdGNG/6yb+2GrXIHGpZZRF3mflfe PSUnuMpEJwCA
i4ksy7eMubZg7CCTqQN1I3iqog31J1NlohMAwEUVnbhkOeEDBFPli0QaTQAA AIhOAAAAiE4A
AADRCQAAANEJAAAgOgEAACA6AQAARCcAAABEJwAAgOgEAACg3fk9yX78pOm0 CAAASJXopF/f
DJoDAACkSnQyetR1tAUAAEgFpt7mEbQCAABIHf9fgAEAUgdnBbUbmDcAAAAA SUVORK5CYII=
--------------010701060306000009050702--
Re: How to run the Equinox OSGi framework from within usual java code?!? [message #131985 is a reply to message #131699] Thu, 28 May 2009 18:33 Go to previous messageGo to next message
I'm trying to do more or less the same but running into an issue which I
don't know can be overcome, at least with the current implementation. My
app runs in a restrictive container which does not allow class loaders to
be created unless they are of a particular type (defined by the container
stack). There are several classloaders created during framework
initialization, the one I stumbled upon is the "boot classloader" created
in SecureAction, I'm getting a permissions exception from my container
during Framework construction. Am I pushing Equinox too far?
Re: How to run the Equinox OSGi framework from within usual java code?!? [message #131998 is a reply to message #131985] Thu, 28 May 2009 23:52 Go to previous messageGo to next message
re: Am I pushing Equinox too far?
Maybe. Being able to create class loaders is fairly funadamental to Equinox.
If you want to run under a security manager like what you describe you have
to grant the classes that bootstraps the platform All Permissions or you're
going to run into problems. I've done this in the past so can confirm it
works however it's something to be aware of.
-Simon
"Vladimir Grishchenko" <vladgri@hotmail.com> wrote in message
news:fa3204a7f26a290a091ffbc0074b3592$1@www.eclipse.org...
Re: How to run the Equinox OSGi framework from within usual java code?!? [message #132021 is a reply to message #131998] Fri, 29 May 2009 01:25 Go to previous message
> -Simon
Unfortunately granting permissions is not an option. Ironically, the
environment I'm referring is based on a spec from the embedded software
domain, and OSGI was originally designed to be run as embedded framework.
As I mentioned classloaders are allowed but only of a particular type, so
in theory it should be possible to delegate classloader instantiation to
outside the framework in some way so that a proper type can be used.
Hacking Equinox is an option of course, but I'm going to look into other
OSGI implementations first.
-Vladimir
Previous Topic:Running Equinox on Application
Next Topic:Communicating between plugins using webservices
Current Time: Tue Nov 18 09:14:10 EST 2025
Powered by FUDForum. Page generated in 0.05468 seconds
