Home » Language IDEs » C / C++ IDE (CDT) » Install problems
Install problems [message #131663] Wed, 15 December 2004 15:46 Go to next message
Originally posted by: bryanmulvihill.rogers.com
I'm having some trouble install the CDT into Eclipse (v.3.0.0). I
downloaded the zip file for 2.1.0 RC7 and unzipped it to my eclipse
directory, but when I started Eclipse, I don't get the C++ perspective.
The status for the CDT says:
The feature is not configured properly.
Reason:
No plug-in: "org.eclipse.cdt.ui" included at runtime.
No plug-in: "org.eclipse.cdt" included at runtime.
No plug-in: "org.eclipse.cdt.debug.ui" included at runtime.
No plug-in: "org.eclipse.cdt.launch" included at runtime.
No plug-in: "org.eclipse.cdt.debug.mi.ui" included at runtime.
No plug-in: "org.eclipse.cdt.make.ui" included at runtime.
No plug-in: "org.eclipse.cdt.managedbuilder.ui" included at runtime.
I used the Software Update to get CDT 2.0.2 and had the same problem, but
only the first two plug-ins weren't included. Do I need to install a
previous version of the CDT?
Bryan
Re: Install problems [message #131853 is a reply to message #131663] Thu, 16 December 2004 02:48 Go to previous messageGo to next message
> Reason:
Sounds like you only installed the features but missed out the plugins,
In the eclipse folder you have 2 sub dirs called "features" and
"plugins", when you install a plugin like CDT it will put some feature
file into features and the actual plugins code into plugins. You can try
to remove anything that has CDT in its name (org.eclipse.cdt.XXXX) in
features and plugins and then re install it by unzipping the entire
contents into your eclipse folder, normally the zip file contains a
folder called eclipse so if you didn't change the name of your eclipse
folder you should just be able to unzip it in the directory where your
eclipse setup is, make sure eclipse is not running when you doing so.
Re: Install problems [message #131895 is a reply to message #131853] Thu, 16 December 2004 10:16 Go to previous messageGo to next message
>> Reason:
I did all that, enabled it in the Product Configuration, and got the same
problem. In my features dir is org.eclipse.cdt_2.1.0 and in my plugins
dir are the org.eclipse.cdt.*_2.1.0 dirs that it says its missing and more.
Re: Install problems [message #131901 is a reply to message #131895] Thu, 16 December 2004 13:40 Go to previous messageGo to next message
Bryan,
I have had similar problem when I unzipped a CDT distribution. You may
need to go to <eclipse_location>/configuration and delete the
directories called org.eclipse.*
These directories are recreated when you start Eclipse, so even if it
doesn't solve your problem, it's a no-risk thing to try.
Sean
>>> Reason:
>> plugins, In the eclipse folder you have 2 sub dirs called "features"
>> and "plugins", when you install a plugin like CDT it will put some
>> feature file into features and the actual plugins code into plugins.
>> You can try to remove anything that has CDT in its name
>> (org.eclipse.cdt.XXXX) in features and plugins and then re install it
>> by unzipping the entire contents into your eclipse folder, normally
>> the zip file contains a folder called eclipse so if you didn't change
>> the name of your eclipse folder you should just be able to unzip it in
>> the directory where your eclipse setup is, make sure eclipse is not
> same problem. In my features dir is org.eclipse.cdt_2.1.0 and in my
> plugins dir are the org.eclipse.cdt.*_2.1.0 dirs that it says its
> missing and more.
Re: Install problems [message #131916 is a reply to message #131895] Thu, 16 December 2004 13:42 Go to previous messageGo to next message
Bryan,
I have had a similar problem when I unzipped a CDT distribution. You may
Sean
>>> Reason:
> missing and more.
Re: Install problems [message #131933 is a reply to message #131916] Thu, 16 December 2004 15:32 Go to previous messageGo to next message
Sean Evoy wrote:
> Bryan,
> Sean
Sean,
I did not see a configuration directory. There is a .config directory but
it has no org.eclipse sub-dirs. The closest thing there is is a manifests
directory with all of the package manifests. Deleting those didn't solve
the problem though.
I'm using Windows XP if that makes any difference.
Re: Install problems [message #131965 is a reply to message #131933] Fri, 17 December 2004 02:55 Go to previous message
> but it has no org.eclipse sub-dirs. The closest thing there is is a
> manifests directory with all of the package manifests. Deleting those
> didn't solve the problem though.
> missing and more.
Well I'm out of idea then, It does sounds however that your eclipse
install is somohow not complete (missing configuration) I guess one
thing you could do is download Eclipse 3.1M3 and try it out. It works
for me.
Previous Topic:create lib/shared lib project with managed makefile?
Next Topic:How to set up makefile for use in CDT/Eclipse
Current Time: Sat Jun 21 03:35:25 EDT 2025
Powered by FUDForum. Page generated in 0.05875 seconds
