Home » Language IDEs » ServerTools (WTP) » Strange error message
Strange error message [message #131582] Wed, 10 August 2005 10:35 Go to next message
I have set up the web tools for the very first time - so apologies if
this is a dumb question.
I created a new "Dynamic Web Project" (using Tomcat 5.5 as the
applicatiopn server) and almost immediately got the warning below.
What am I missing and why?
IWAE0010E Run-time exception java.lang.NoSuchMethodError occurred during
validation. The validator being run was XML Validator and the message
thrown was
org.apache.xerces.xni.XMLResourceIdentifier.getNamespace()Lj ava/lang/String;.
Re: Strange error message [message #131827 is a reply to message #131582] Wed, 10 August 2005 14:33 Go to previous messageGo to next message
Hi Alan,
Please open a bug report. We can follow up there. Please include your OS
and your Java runtime information.
Lawrence
Re: Strange error message [message #132153 is a reply to message #131582] Fri, 12 August 2005 00:23 Go to previous messageGo to next message
> IWAE0010E Run-time exception java.lang.NoSuchMethodError occurred duri=
ng
> thrown was
> org.apache.xerces.xni.XMLResourceIdentifier.getNamespace()Lj ava/lang/S=
tring;.
AFAIK, this is not a frequent problem (that I've heard), so besides Lawr=
ence's suggestion to
open a bugzilla giving detailed configuration information, I'll also sug=
gest
that you check if you have your own version of xerces installed in the
your java's "endorced library" directory. Its a long shot, but I've seen=
one or two
cases where people did that, following some directions the received from=
somewhere ...
but they didn't really need to. [we include a xerces plugin with WTP, it=
s version 2.7.0,
and as far as we can tell is compatible with 1.4 and 1.5 versions of Jav=
a].
Re: Strange error message [message #132226 is a reply to message #132153] Fri, 12 August 2005 04:11 Go to previous messageGo to next message
Originally posted by: alan.chandler.logicacmg.com
On Fri, 12 Aug 2005 00:23:02 -0400, "David Williams"
>> thrown was
>AFAIK, this is not a frequent problem (that I've heard), so besides Lawrence's suggestion to
>open a bugzilla giving detailed configuration information, I'll also suggest
>your java's "endorced library" directory. Its a long shot, but I've seen one or two
>cases where people did that, following some directions the received from somewhere ...
>but they didn't really need to. [we include a xerces plugin with WTP, its version 2.7.0,
>and as far as we can tell is compatible with 1.4 and 1.5 versions of Java].
Searched all over in the various subdirectories under my Tomcat
installation and can't find anything.
Re: Strange error message [message #132563 is a reply to message #132226] Fri, 12 August 2005 22:16 Go to previous messageGo to next message
Back to bug reporting I suppose ... I'd suggest to include the whole
contents of config info as an attachment to the bug, -- obtainable
from Help->About.
Good luck!
Re: Strange error message [message #146828 is a reply to message #131582] Fri, 11 November 2005 06:47 Go to previous message
Originally posted by: hcukurtepe.gmail.com
i don't know whether it is solution or not but i had the same errors and i got rid of it by running validation while connected to internet.
Previous Topic:Dependencies between multiple dynamic web projects
Next Topic:Eclipse 3.2M3 + latest WTP I build -- .wtpmodule gone the way of the dodo bird?
Current Time: Fri Nov 28 12:02:33 EST 2025
Powered by FUDForum. Page generated in 0.25733 seconds
