Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » Support of EJB3/JPA OR mapping by TENEO
| Support of EJB3/JPA OR mapping by TENEO [message #131543] |
Tue, 09 December 2008 05:32  |
Myself Sanjeev Kumar from Lufthansa System. This regarding the support of
EJB3/JPA by TENEO. I am doing some proof of concept(POC) with
TENEO,EJB3/JPA and hibernate. The restriction from my side is that I
cannot annotate the model with OR mapping due to power desinger
limitation. I did the following POCs:
1. I generated the hibernate OR mapping file using power designer, and
configured the teneo to lookup this mapping file instead of generating it
own in memory (by using PersistenceOptions.USE_MAPPING_FILE, as "true"). I
am able to save and retreive domains object using this strategy.
2. In the second test, instead of using the hibernate mapping file, I have
generated the OR mapping file (EJB3/JPA compliance) using power designer.
As mentioned above, I cann't annote the model itself due to tool
limitation. I am exploring the teneo to configure it to use this OR
mapping file. I am not sure wthether this can be possible with TENEO or
not.
Request you to please let me know, does TENEO can be configures to work in
this way.
Thanks & Regards,
Sanjeev
| Re: Support of EJB3/JPA OR mapping by TENEO [message #131588 is a reply to message #131543] |
Tue, 09 December 2008 09:16   |
Hi Sanjeev,
There are probably some differences in the mapping. I would generate the same mapping file through
Teneo and then do a comparison. Then if you specific differences post them here (or better in the
EMF newsgroup) and I can give more background info.
gr. Martin
Sanjeev wrote:
> of EJB3/JPA by TENEO. I am doing some proof of concept(POC) with
> it own in memory (by using PersistenceOptions.USE_MAPPING_FILE, as
> "true"). I am able to save and retreive domains object using this strategy.
> have generated the OR mapping file (EJB3/JPA compliance) using power
> designer. As mentioned above, I cann't annote the model itself due to
> tool limitation. I am exploring the teneo to configure it to use this OR
> not.
> in this way.
> Thanks & Regards,
> Sanjeev
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
| Re: Support of EJB3/JPA OR mapping by TENEO [message #131614 is a reply to message #131601] |
Tue, 09 December 2008 14:16  |
Hi Sanjeev,
Correct the xml of Teneo is aimed at offering a possibility to annotate the model not to follow the
orm EJB3/JPA spec. Now I also understand what you mean, I thought that you were generating a
Hibernate hbm file and not an orm file.
So I am afraid that currently the answer to your question is that this is not possible (generate an
orm file and use that as input to Teneo).
gr. Martin
Sanjeev wrote:
> Many thanks Martin for the quick reply. Please correct me If I am wrong,
> I suppose the schema used by TENEO for the EJB3/JPA compliance OR
> mapping file is different from the schema used by EJB3/JPA standards.
> e.g. TENEO uses the following knid of OR mapping XML.
> <persistence-mapping xmlns="http://www.eclipse.org/emft/teneo"
> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
> <epackage
> namespace-uri=" http://www.eclipse.org/emf/teneo/samples/emf/annotations/inh eritancemapping">
> <eclass name="ContentList">
> <property name="name">
> <id/>
> </property>
> </eclass>
> <eclass name="Price">
> <table name="myprice"/>
> <inheritance>SINGLE_TABLE</inheritance>
> </eclass>
> </epackage>
> </persistence-mapping>
> where as EJB3/JPA standards uses following kind of OR mapping XML:
> <entity-mappings xmlns="http://java.sun.com/xml/ns/persistence/orm"
> xsi:schemaLocation="http://java.sun.com/xml/ns/persistence/orm
> orm_1_0.xsd" version="1.0">
> <entity class="CustomerImpl" name="Customer" access="PROPERTY"
> metadata-complete="true">
> <description>Generated class mapping for abbreviation</description>
> <table name="Customer">
> <attributes>
> <id name="customerId">
> <column name="customerId" nullable="false" insertable="true"
> updatable="true"/>
> </id>
> </attributes>
> </entity>
> </entity-mappings>
> These two OR mapping XMLs seems to use different schemas.
> Please guide me if my understanding is incorrect.
> Many thanks in advance.
> Warm Regards,
> Sanjeev
The Netherlands
| Re: Support of EJB3/JPA OR mapping by TENEO [message #620530 is a reply to message #131543] |
Hi Sanjeev,
gr. Martin
Sanjeev wrote:
> not.
> in this way.
> Thanks & Regards,
> Sanjeev
The Netherlands
| Re: Support of EJB3/JPA OR mapping by TENEO [message #620532 is a reply to message #131601] |
Hi Sanjeev,
gr. Martin
> <epackage
> <id/>
> </property>
> </eclass>
> </eclass>
> </epackage>
> <attributes>
> updatable="true"/>
> </id>
> </attributes>
> </entity>
> </entity-mappings>
> Warm Regards,
> Sanjeev
The Netherlands
Current Time: Mon Nov 03 18:24:34 EST 2025
Powered by FUDForum. Page generated in 0.04922 seconds
