Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » Support of EJB3/JPA OR mapping by TENEO
Support of EJB3/JPA OR mapping by TENEO [message #131543] Tue, 09 December 2008 05:32 Go to next message
Myself Sanjeev Kumar from Lufthansa System. This regarding the support of
EJB3/JPA by TENEO. I am doing some proof of concept(POC) with
TENEO,EJB3/JPA and hibernate. The restriction from my side is that I
cannot annotate the model with OR mapping due to power desinger
limitation. I did the following POCs:
1. I generated the hibernate OR mapping file using power designer, and
configured the teneo to lookup this mapping file instead of generating it
own in memory (by using PersistenceOptions.USE_MAPPING_FILE, as "true"). I
am able to save and retreive domains object using this strategy.
2. In the second test, instead of using the hibernate mapping file, I have
generated the OR mapping file (EJB3/JPA compliance) using power designer.
As mentioned above, I cann't annote the model itself due to tool
limitation. I am exploring the teneo to configure it to use this OR
mapping file. I am not sure wthether this can be possible with TENEO or
not.
Request you to please let me know, does TENEO can be configures to work in
this way.
Thanks & Regards,
Sanjeev
Re: Support of EJB3/JPA OR mapping by TENEO [message #131588 is a reply to message #131543] Tue, 09 December 2008 09:16 Go to previous messageGo to next message
Hi Sanjeev,
There are probably some differences in the mapping. I would generate the same mapping file through
Teneo and then do a comparison. Then if you specific differences post them here (or better in the
EMF newsgroup) and I can give more background info.
gr. Martin
Sanjeev wrote:
> of EJB3/JPA by TENEO. I am doing some proof of concept(POC) with
> it own in memory (by using PersistenceOptions.USE_MAPPING_FILE, as
> "true"). I am able to save and retreive domains object using this strategy.
> have generated the OR mapping file (EJB3/JPA compliance) using power
> designer. As mentioned above, I cann't annote the model itself due to
> tool limitation. I am exploring the teneo to configure it to use this OR
> not.
> in this way.
> Thanks & Regards,
> Sanjeev
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: Support of EJB3/JPA OR mapping by TENEO [message #131601 is a reply to message #131588] Tue, 09 December 2008 12:03 Go to previous messageGo to next message
Many thanks Martin for the quick reply.
Please correct me If I am wrong, I suppose the schema used by TENEO for
the EJB3/JPA compliance OR mapping file is different from the schema used
by EJB3/JPA standards.
e.g. TENEO uses the following knid of OR mapping XML.
<persistence-mapping xmlns="http://www.eclipse.org/emft/teneo"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
<epackage
namespace-uri=" http://www.eclipse.org/emf/teneo/samples/emf/annotations/inh eritancemapping">
<eclass name="ContentList">
<property name="name">
<id/>
</property>
</eclass>
<eclass name="Price">
<table name="myprice"/>
<inheritance>SINGLE_TABLE</inheritance>
</eclass>
</epackage>
</persistence-mapping>
where as EJB3/JPA standards uses following kind of OR mapping XML:
<entity-mappings xmlns="http://java.sun.com/xml/ns/persistence/orm"
xsi:schemaLocation="http://java.sun.com/xml/ns/persistence/orm
orm_1_0.xsd"
version="1.0">
<entity class="CustomerImpl" name="Customer" access="PROPERTY"
metadata-complete="true">
<description>Generated class mapping for abbreviation</description>
<table name="Customer">
<attributes>
<id name="customerId">
<column name="customerId" nullable="false" insertable="true"
updatable="true"/>
</id>
</attributes>
</entity>
</entity-mappings>
These two OR mapping XMLs seems to use different schemas.
Please guide me if my understanding is incorrect.
Many thanks in advance.
Warm Regards,
Sanjeev
Re: Support of EJB3/JPA OR mapping by TENEO [message #131614 is a reply to message #131601] Tue, 09 December 2008 14:16 Go to previous message
Hi Sanjeev,
Correct the xml of Teneo is aimed at offering a possibility to annotate the model not to follow the
orm EJB3/JPA spec. Now I also understand what you mean, I thought that you were generating a
Hibernate hbm file and not an orm file.
So I am afraid that currently the answer to your question is that this is not possible (generate an
orm file and use that as input to Teneo).
gr. Martin
Sanjeev wrote:
> Many thanks Martin for the quick reply. Please correct me If I am wrong,
> I suppose the schema used by TENEO for the EJB3/JPA compliance OR
> mapping file is different from the schema used by EJB3/JPA standards.
> <epackage
> <id/>
> </property>
> </eclass>
> </eclass>
> </epackage>
> orm_1_0.xsd" version="1.0">
> <attributes>
> updatable="true"/>
> </id>
> </attributes>
> </entity>
> </entity-mappings>
> Warm Regards,
> Sanjeev
The Netherlands
Re: Support of EJB3/JPA OR mapping by TENEO [message #620530 is a reply to message #131543] Tue, 09 December 2008 09:16 Go to previous message
Hi Sanjeev,
gr. Martin
Sanjeev wrote:
> not.
> in this way.
> Thanks & Regards,
> Sanjeev
The Netherlands
Re: Support of EJB3/JPA OR mapping by TENEO [message #620531 is a reply to message #131588] Tue, 09 December 2008 12:03 Go to previous message
<epackage
<id/>
</property>
</eclass>
</eclass>
</epackage>
orm_1_0.xsd"
version="1.0">
<attributes>
updatable="true"/>
</id>
</attributes>
</entity>
</entity-mappings>
Warm Regards,
Sanjeev
Re: Support of EJB3/JPA OR mapping by TENEO [message #620532 is a reply to message #131601] Tue, 09 December 2008 14:16 Go to previous message
Hi Sanjeev,
gr. Martin
> <epackage
> <id/>
> </property>
> </eclass>
> </eclass>
> </epackage>
> <attributes>
> updatable="true"/>
> </id>
> </attributes>
> </entity>
> </entity-mappings>
> Warm Regards,
> Sanjeev
The Netherlands
Previous Topic:New Project Proposal : EEF
Next Topic:CD Server initialization issue with HibernateStore
Current Time: Fri Nov 21 10:26:36 EST 2025
Powered by FUDForum. Page generated in 0.04727 seconds
