| How does the Eclipse project test it's GUI? [message #131499] |
Fri, 20 June 2008 03:27  |
I just want to verify that I understood it, how Eclipse itself tests the
GUI of its product.
I've downloaded the plugin tests of Eclipse 3.2.2 and run some of them in
Eclipse. Then dialogs pop up, close etc.
When I looked into the code for the plugin tests
"org.eclipse.jdt.ui.tests", it seems that it is a kind of white box GUI
testing because the dialogs are created in the classes directly
(JavaProjectHelper.createJavaProject(...)) and methods of the GUI objects
are called, for example setSomething(...).
For this approach one needs to know a lot of the GUI classes. It seems
that it also relies on additional manual testing, since there can't be
automated everything by using this approach.
It is not a black box testing, since a generic technique ("click on a
button named OK in the dialog", "enter text into box by keypress events")
is not used as it seems.
Did I understand it right?
| Re: How does the Eclipse project test it's GUI? [message #131818 is a reply to message #131499] |
Thu, 26 June 2008 09:12   |
Hi Hans,
Since your question is specific to the Eclipse Platform Project, please
post your question to their news group
( http://www.eclipse.org/newsportal/thread.php?group=eclipse.p latform).
FYI, the Eclipse Platform Project uses JUnit and JUnit Plug-in test
suites to test their code. The test suites are executed using the JDT JUnit
runner. TPTP provides the same support (JUnit and JUnit Plug-in test
suites), with the addition of remote test execution, test log, BIRT-based
test reports, and automated test execution/results reporting via Ant:
http://help.eclipse.org/ganymede/topic/org.eclipse.hyades.te st.doc.user/concepts/ccommontestingtasksandconcepts.htm
Paul
"Hans Schwaebli" <hans_schwaebli@yahoo.com> wrote in message
news:4f69b763d0ef2d1d8f4bdf591e6a42f3$1@www.eclipse.org...
>GUI of its product.
FUDForum. Page generated in 0.03571 seconds
