Home » Archived » Higgins » Which spider graphing tool are you using?
Which spider graphing tool are you using? [message #996] Fri, 23 December 2005 22:39 Go to next message
Originally posted by: ndefreitas.comcast.net
I'm assuming that the linking tool you're going to use is some sort of a
spidergraph.
Mind sharing which one you're using?
I wrote the dude that owns touchgraph (http://www.touchgraph.com/) but he
hasn't responded as yet.
The reason I need it is to create my own database for applications at my
company. I need to show which applications reuse (override or uses default
base) which framework methods.
Thaks
Re: Which spider graphing tool are you using? [message #1026 is a reply to message #996] Fri, 30 December 2005 17:58 Go to previous message
Originally posted by: mary.socialphysics.org
Hi Nigel,
We started using JUNG (http://jung.sourceforge.net/index.html) for the
visualization before we became an Eclipse project. Danyel Fisher and his
team have created a very powerful package. We are looking into the issues
of using JUNG with Eclipse. The Ariadne project
http://awareness.ics.uci.edu/~ariadne/index.html has used JUNG with
Eclipse for the purpose of plotting relationships between engineers and
code modules. Is this logically similar to what you want to do with
applications and framework methods?
By the way, Higgins keeps track of relationships within itself. We were
just using JUNG for the display.
Re: Which spider graphing tool are you using? [message #561131 is a reply to message #996] Fri, 30 December 2005 17:58 Go to previous message
Hi Nigel,
Previous Topic:Which spider graphing tool are you using?
Next Topic:Security "Short Talks" at EclipseCon
Current Time: Thu Oct 30 03:54:47 EDT 2025
Powered by FUDForum. Page generated in 0.07018 seconds
