Home » Archived » M2M (model-to-model transformation) » Problem with clause "using" in called rule
Problem with clause "using" in called rule [message #11967] |
Mon, 22 January 2007 06:58  |
Originally posted by: jairson.gmail.com
Hello All,
I´ve read in the manual that called rules allow us to use the clause
"using" to declare local variables. But I am having an error message
"unexpected token: using" with the excerpt below:
rule simpagation2simpagation (r : CHR!Simpagation,v :
Sequence(CHR!VariableSymbol))
using {
co : Sequence(CHR!ConstantSymbol) =
thisModule.allConstantSymbols(r.keep->union(r.remove));
to
ro : CHR!Simpagation (
Can anyone help?
regards,
Jairson Vitorino
Re: Problem with clause "using" in called rule [message #11993 is a reply to message #11981] |
Mon, 22 January 2007 10:14   |
Mikaël
Thanks for the answer. I am using ATL 2004! That´s what I found it strange.
here is the whole rule:
using {
to
name <- r.name,
keep <- r.keep,
remove <- r.remove,
guard <- r.guard->union(co->iterate(c; acc : CHR!Bic = Sequence{} |
acc->including(thisModule.newBic(c,thisModule.newVariables- >at(co->indexOf(c)))))),
disjunctiveBody <- r.disjunctiveBody
I still have the same error.
Jairson
Mikaël Barbero wrote:
> Hi Jairson,
> Which ATL compiler version do you have ? ATL 2006 or ATL 2004 ? If it's
> 2006, try it with 2004 and report us if it is working. This would mean
> that ATL 2006 doesn't support "using" in called rules.
> Mikael
> Jairson a écrit :
>> Hello All,
>> using {
>> to
>> Can anyone help?
>> regards,
>> Jairson Vitorino
Re: Problem with clause "using" in called rule [message #12019 is a reply to message #11993] |
Mon, 22 January 2007 10:13   |
Your rule parses ok with the latest version of ATL.
Can you please try to update?
The problem may also be a syntax error earlier in the file. If there is
one, the parser may not have succeeded in resynchronizing. Correcting
any previous error should then make this one disappear.
Frédéric Jouault
Jairson wrote:
> Mikaël
> using {
> to
> name <- r.name,
> keep <- r.keep,
> remove <- r.remove,
> = Sequence{} |
> Jairson
>> Hi Jairson,
>> it's 2006, try it with 2004 and report us if it is working. This would
>> mean that ATL 2006 doesn't support "using" in called rules.
>> Regards,
>> Mikael
>> Jairson a écrit :
>>> Hello All,
>>> using {
>>> to
>>> Can anyone help?
>>> regards,
>>> Jairson Vitorino
Re: Problem with clause "using" in called rule [message #12032 is a reply to message #12019] |
Mon, 22 January 2007 13:16  |
Thanks. I´ll update then.
Frédéric Jouault wrote:
> Hello,
> Frédéric Jouault
> Jairson wrote:
>> Mikaël
>> strange.
>> using {
>> to
>> name <- r.name,
>> keep <- r.keep,
>> remove <- r.remove,
>> Jairson
>>> Hi Jairson,
>>> would mean that ATL 2006 doesn't support "using" in called rules.
>>> Regards,
>>> Mikael
>>> Jairson a écrit :
>>>> Hello All,
>>>> using {
>>>> to
>>>> Can anyone help?
>>>> regards,
>>>> Jairson Vitorino
Current Time: Thu Jul 10 08:03:59 EDT 2025
Powered by FUDForum. Page generated in 0.06389 seconds
