Home » Eclipse Projects » DSDP - Target Management » ssh shell never shows commands
ssh shell never shows commands [message #11952] |
Thu, 21 June 2007 08:47  |
I am using eclipse 3.3 with latest RSE. I have opened a SSH connection
to another server and logged in OK. However, whatever i type in the
command box, there is never any output shown. Nothing. If i export the
output to a text file, it is empty.
Re: ssh shell never shows commands [message #12131 is a reply to message #12092] |
Thu, 12 July 2007 09:45  |
Hm,
I have seen this effect before but I thought it was fixed. At that time,
it was a problem with Refresh Events not being sent in RSE for the data
that was received.
I do not think that this issue is Cygwin related, it's more likely that
it's specific to timing on your machine. Are you running a Dualcore or
Hyperthreaded PC?
At any rate, please file a bug in bugzilla and give all the information
you have about your environment (host OS, JVM version, processor, RSE
version). You can also attach the output from Eclipse Help > About >
Show Configuration Details and Help > About > View Error Log, it should
have all the information we need.
Martin Oberhuber
Target Management Project Lead, DSDP PMC Member
http://www.eclipse.org/dsdp/tm
teknokrat wrote:
> Martin Oberhuber wrote:
>> Did you try a simple command like "echo hello"?
>> Does the ssh file subsystem work properly?
>> How do you know you logged in OK if you do not see any output?
>> Are any errors or exceptions logged (Window > Show View > PDE Runtime
>> > Error Log)?
> I tried lots of commands and there is no output. I can login into the
> server using command line ssh easily. There are no errors on any logs.
> When I start a shell I get a Last Login: message and thats it -
> sometimes the view is disabled, i.e. I cannot type anything in the box.
> Could this be a problem with cygwin? The ssh demon I am running is set
> up by cygwin.
>> Thanks,
>> Martin Oberhuber
>>> connection to another server and logged in OK. However, whatever i
>>> type in the command box, there is never any output shown. Nothing. If
>>> i export the output to a text file, it is empty.
Re: ssh shell never shows commands [message #568492 is a reply to message #11952] |
Tue, 26 June 2007 15:16  |
Are any errors or exceptions logged (Window > Show View > PDE Runtime >
Error Log)?
Martin Oberhuber
Re: ssh shell never shows commands [message #568700 is a reply to message #11978] |
Mon, 09 July 2007 14:53  |
> Error Log)?
up by cygwin.
> Martin Oberhuber
Re: ssh shell never shows commands [message #568777 is a reply to message #12092] |
Hm,
that was received.
Hyperthreaded PC?
Martin Oberhuber
>> > Error Log)?
> up by cygwin.
>> Thanks,
>> Martin Oberhuber
Current Time: Mon Jul 14 05:07:28 EDT 2025
Powered by FUDForum. Page generated in 0.13365 seconds
