Home » Eclipse Projects » Eclipse Platform » CTRL+C doesn't copy in text editor
CTRL+C doesn't copy in text editor [message #130077] Tue, 16 September 2003 06:29 Go to next message
Originally posted by: eclipse.leroy.demon.co.uk
The key mapping of CTRL+C to edit >> copy doesn't seem to work in the text
editor or java editor.
It seems to be correctly mapped in the "workbench >> preferences >> keys"
dialog, but when I press it the selected text isn't copied and the status
bar at the bottom of the IDE says "ctrl+c" as though it doesn't recognise
the command.
I can map other combinations to copy happily (eg CTRL+d) but I'm quite
attached to CTRL+C ... so it would be nice to enable it.
I have tried mapping CTRL+C under as many combinations of scope and
configuration as I could think of.
Does anyone know how I can fix this?
many thanks
Eclipse Version:
Version: 2.1.1
Build id: 200306271545
Java:
J2SDK 1.4.2_01
OS:
Windows XP Pro (SP1)
Re: CTRL+C doesn't copy in text editor [message #133171 is a reply to message #130077] Fri, 19 September 2003 13:22 Go to previous message
> the command.
This is not normal, obviously. Perhaps you're experiencing this
intermittent bug:
<https://bugs.eclipse.org/bugs/show_bug.cgi?id=16011>
<https://bugs.eclipse.org/bugs/show_bug.cgi?id=20874>
Eric Rizzo
Software Architect
Jibe, Inc.
http://www.jibeinc.com
Previous Topic:Utility for building a Composite object?
Next Topic:Error when running applet in Browser Widget in Eclipse 3.0 M3
Current Time: Sun Jul 13 13:21:57 EDT 2025
Powered by FUDForum. Page generated in 0.03532 seconds
