Home » Language IDEs » AspectJ » announcement: ajdt v0.6.0 beta
announcement: ajdt v0.6.0 beta [message #11903] Wed, 04 December 2002 13:44 Go to next message
Originally posted by: Mik.Kersten.parc.com
Version 0.6.0 of AJDT is available for download from the AJDT Eclipse
project (http://eclipse.org/ajdt). This is a beta release of the AJDT
plugin that supports the new AspectJ v1.1 compiler. The beta compiler does
not yet produce crosscutting structure (for anything but method executions)
so there are no gutter annotations and you only see a declaration tree
without crosscutting links in the structure views. Incremental building and
bytecode weaving are not available in the AJDE tools in the beta release,
but will be in a future release.
Before switching from AJDT 0.5.2 please read through the AspectJ 1.1 beta
release notes:
http://aspectj.org/doc/readme11/index.html
Thanks and stay in touch,
The AJDT Team
Re: announcement: ajdt v0.6.0 beta [message #13490 is a reply to message #11903] Thu, 05 December 2002 02:28 Go to previous messageGo to next message
hi mik!
thank you for your note and the clarifications on features included in
this release!
i just noticed that beta 0.6 doesn't work with the latest 2.1
integration builds anymore. i'm aware of the fact that the aspectj
plugin was tested and released for the 2.0 GA driver.
however i wanted to go ahead and make it work on the 2.1 drivers
as well since this is the environment i work in.
i was just wondering where i could fine the source code for beta 0.6
for the aspectj eclipse plugin?
zip file or cvs access would be fine.
thanks,
markus
> release notes:
> The AJDT Team
Re: announcement: ajdt v0.6.0 beta [message #13510 is a reply to message #13490] Thu, 05 December 2002 22:46 Go to previous message
Hi Markus,
Sounds great! I hope that we can incorporate your updates for the upcoming
0.6.1 release.
The necessary changes should be localized to the org.eclipse.ajdt.ui plugin,
whose sources you can get by anonymous CVS to:
dev.eclipse.org:/home/technolgy
You may also need the sources for the AspectJ tools (org.aspectj.ajde)
plug-in which you can download along with the plugin.xml at:
http://aspectj.org/download/distribution-1.1/aspectj-jdt-src -1.1b1.zip
http://aspectj.org/download/distribution-1.1/aspectj-eclipse Plugin-1.1b1.zip
Happy hacking,
Mik
"Markus Weyerhaeuser" <m.weyerhaeuser@hookipaa.com> wrote in message
news:asmv19$a81$1@rogue.oti.com...
> hi mik!
> this release!
> thanks,
> markus
does
executions)
and
release,
beta
> > release notes:
> > The AJDT Team
Re: announcement: ajdt v0.6.0 beta [message #563439 is a reply to message #11903] Thu, 05 December 2002 02:28 Go to previous message
hi mik!
this release!
thanks,
markus
> release notes:
> The AJDT Team
Re: announcement: ajdt v0.6.0 beta [message #563464 is a reply to message #13490] Thu, 05 December 2002 22:46 Go to previous message
Hi Markus,
0.6.1 release.
Happy hacking,
Mik
> hi mik!
> this release!
> thanks,
> markus
does
executions)
and
release,
beta
> > release notes:
> > The AJDT Team
Previous Topic:New Aspect Wizard does not allow to create an Aspect
Next Topic:Constant "plugin activation failed" errors
Current Time: Sat Jul 26 16:52:27 EDT 2025
Powered by FUDForum. Page generated in 0.04636 seconds
