Home » Archived » BIRT » Pie Chart Min Slice Legend
Pie Chart Min Slice Legend [message #130040] Tue, 14 February 2006 06:24 Go to next message
I am trying to use the Min Slice setting on a pie chart to reduce the
number of categories that appear in the legend (we have about 15, but
many only contain 1 or 2 items), however I cannot get it to work as
required. The slices are grouped correctly, but each of the categories
is listed in the legend. I had expected that only the categories that
exceeded the min slice size would appear in the legend along with an
item titled according to the Slice Label setting.
Have I misunderstood how this features works or is there another way to
accomplish this?
Jonathan
Re: Pie Chart Min Slice Legend [message #130052 is a reply to message #130040] Tue, 14 February 2006 06:46 Go to previous messageGo to next message
There is a bugzilla entry regarding this feature:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=116707 Please add yourself to
CC in the bug to track it.
David
"Jonathan Tweed" <j.tweed@visualfiles.com> wrote in message
news:dssekl$o1b$1@utils.eclipse.org...
> Hi
> number of categories that appear in the legend (we have about 15, but many
> only contain 1 or 2 items), however I cannot get it to work as required.
> The slices are grouped correctly, but each of the categories is listed in
> the legend. I had expected that only the categories that exceeded the min
> slice size would appear in the legend along with an item titled according
> accomplish this?
> Thanks
> Jonathan
Re: Pie Chart Min Slice Legend [message #130065 is a reply to message #130052] Tue, 14 February 2006 07:19 Go to previous messageGo to next message
Hi David
Thanks for your very quick response, I have added myself as a CC for
this bug.
As a possible workaround I tried turning off the legend and adding the
category name to the slice label, but the 'other' slice was named
according to the first category that appeared in the data. I assume that
this is caused by the same bug?
Have you any suggestions for workarounds? It sort of renders the whole
minimum slice feature pretty useless, which is a shame and potentially a
big issue for us.
Jonathan
Re: Pie Chart Min Slice Legend [message #130177 is a reply to message #130065] Tue, 14 February 2006 11:12 Go to previous messageGo to next message
Hi Jonathan,
Please add this other problem in the bug description to make sure it gets
resolved together. I apologize for this issue, I hope to have it fixed in
2.1.
For the slice label workaround, you can use scripting to change the slice
label. Look at the org.eclipse.birt.chart.examples plugin which contains lot
of scripting examples both in JavaScript and Java.
David
news:dsshsj$vu0$1@utils.eclipse.org...
>> to CC in the bug to track it.
> Hi David
> Thanks for your very quick response, I have added myself as a CC for this
> bug.
> big issue for us.
> Thanks
> Jonathan
Re: Pie Chart Min Slice Legend [message #130290 is a reply to message #130177] Tue, 14 February 2006 12:40 Go to previous messageGo to next message
Cheers David, I see you have already added this to Bugzilla.
Jonathan
> Hi Jonathan,
> 2.1.
> David
Re: Pie Chart Min Slice Legend [message #1463560 is a reply to message #130290] Thu, 06 November 2014 12:42 Go to previous message
In bugzilla this issue are fixed.
But I have the same problem on BIRT Framework 4.3.2.v20140211.
How can I hide entries of sliced pie in the legend of the barchart?
Mark
Previous Topic:Can not start the design engine.
Next Topic:Query Option not displayed in Edit-DataSet Option
Current Time: Tue Jul 15 03:30:10 EDT 2025
Powered by FUDForum. Page generated in 0.16613 seconds
