| changing the upload URL [message #11887] |
Wed, 15 July 2009 03:07  |
Hello, i am trying to utilize UDC to see if i can get it working
internally for my users. I have set up everything including the database
and php with an apache server. I started eclipse with the
" -Dorg.eclipse.epp.usagedata.recording.upload-url=path-to-int ernal-apache2 "
I got an message in the consolelog saying:
!SESSION 2009-07-14 15:53:07.483
eclipse.buildId=I20090611-1540
java.version=1.6.0_12
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=sv_SE
Framework arguments:
-Dorg.eclipse.epp.usagedata.recording.upload-url=http://internalmachine:8080/upload.php
Command-line arguments: -os win32 -ws win32 -arch x86 -consolelog
all is good right! i then tried to run the upload from within preferences
and i got an error from the consolelog saying:
!ENTRY org.eclipse.epp.usagedata.recording 2 0 2009-07-15 08:54:50.577
!MESSAGE The usage data upload server at http://udc.eclipse.org/upload.php
could not be found.
!STACK 0
java.net.UnknownHostException: udc.eclipse.org
at java.net.PlainSocketImpl.connect(Unknown Source)
at java.net.SocksSocketImpl.connect(Unknown Source)
at java.net.Socket.connect(Unknown Source)
at java.net.Socket.<init>(Unknown Source)
Didn't the property change? i can see in the apache if an log request has
come but it haven't even attempted to get upload.php. Which leads me to
think there is something other that still pushes the eclipse client
towards udc.eclipse.org/upload.php. Has anyone else tested this and found
that you needed to edit the source to be able to use the udc features?
thanks for any hints, and this cool feature :-)
| Re: changing the upload URL [message #12253 is a reply to message #12243] |
Thu, 16 July 2009 06:38   |
ok, source downloaded and debugged, infact i got it working in the debug
session. It populated my database nicely, no idea what changed. Closed the
debug and got back to my normal eclipse window, and tried to upload and
got another stacktrace:
-Dorg.eclipse.epp.usagedata.recording.upload-url=http://udc.eclipse.org:8080/upload.php
-data C:\WS\Eclipse_test\eclipse3.5.classic.FINAL3_SFCCSCM\001 -consolelog
Warning
Thu Jul 16 10:54:01 CEST 2009
An exception occurred while trying to upload usage data.
java.net.SocketException: Software caused connection abort: socket write
error
at java.net.SocketOutputStream.socketWrite0(Native Method)
at java.net.SocketOutputStream.socketWrite(Unknown Source)
at java.net.SocketOutputStream.write(Unknown Source)
at java.io.BufferedOutputStream.flushBuffer(Unknown Source)
at java.io.BufferedOutputStream.flush(Unknown Source)
org.apache.commons.httpclient.ChunkedOutputStream.flush(Chun kedOutputStream.java:191)
at sun.nio.cs.StreamEncoder.implFlush(Unknown Source)
at sun.nio.cs.StreamEncoder.flush(Unknown Source)
at java.io.OutputStreamWriter.flush(Unknown Source)
at java.io.BufferedWriter.flush(Unknown Source)
org.eclipse.epp.usagedata.internal.recording.uploading.Basic Uploader$FilteredFilePart.sendData(BasicUploader.java:350)
at org.apache.commons.httpclient.methods.multipart.Part.send(Pa rt.java:312)
org.apache.commons.httpclient.methods.multipart.Part.sendPar ts(Part.java:385)
org.apache.commons.httpclient.methods.multipart.MultipartReq uestEntity.writeRequest(MultipartRequestEntity.java:164)
org.apache.commons.httpclient.methods.EntityEnclosingMethod. writeRequestBody(EntityEnclosingMethod.java:499)
org.apache.commons.httpclient.HttpMethodBase.writeRequest(Ht tpMethodBase.java:2114)
org.apache.commons.httpclient.HttpMethodBase.execute(HttpMet hodBase.java:1096)
org.apache.commons.httpclient.HttpMethodDirector.executeWith Retry(HttpMethodDirector.java:398)
org.apache.commons.httpclient.HttpMethodDirector.executeMeth od(HttpMethodDirector.java:171)
org.apache.commons.httpclient.HttpClient.executeMethod(HttpC lient.java:397)
org.apache.commons.httpclient.HttpClient.executeMethod(HttpC lient.java:323)
org.eclipse.epp.usagedata.internal.recording.uploading.Basic Uploader.doUpload(BasicUploader.java:206)
org.eclipse.epp.usagedata.internal.recording.uploading.Basic Uploader.upload(BasicUploader.java:129)
org.eclipse.epp.usagedata.internal.recording.uploading.Basic Uploader$1.run(BasicUploader.java:105)
I have just changed so that udc.eclipse.org points internally instead to
my apache server. So it works while debugging but not when using my fat
client with all of the galileo release installed, i build internal
updatesites, hence i need all installed.
I cant recreate this error in a debug session, there it works all the
time. Even if i load all plugins from the host platform.
I tested with an fresh vanilla eclipse 3.5 classic and it worked directly.
I could start my platform in remote debugging mode and see whats happening
but that's a lot of work, i don't even remember the settings i need to do
that, i probably need a lot of google time :-)
| Re: changing the upload URL [message #12263 is a reply to message #12253] |
Thu, 16 July 2009 11:45   |
I should have thought of this earlier (drat).
The -D properties are "vm properties" and have to appear after -vmargs.
Try that.
Wayne
> the debug and got back to my normal eclipse window, and tried to upload
> and got another stacktrace:
> Warning
> error
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
> directly. I could start my platform in remote debugging mode and see
> whats happening but that's a lot of work, i don't even remember the
> settings i need to do that, i probably need a lot of google time :-)
| Re: changing the upload URL [message #12314 is a reply to message #12303] |
Wed, 22 July 2009 11:36  |
Most of the properties are stored in the preferences, but can be
overridden with -D system properties.
Take a look at UsageDataRecordingSettings#getPeriodBetweenUploads(), for
example.
Wayne
| Re: changing the upload URL [message #579347 is a reply to message #11887] |
Wed, 15 July 2009 20:14  |
That should work. I am investigating.
Wayne
> preferences and i got an error from the consolelog saying:
> http://udc.eclipse.org/upload.php could not be found.
> !STACK 0
> has come but it haven't even attempted to get upload.php. Which leads me
> to think there is something other that still pushes the eclipse client
> found that you needed to edit the source to be able to use the udc
> features?
| Re: changing the upload URL [message #579366 is a reply to message #12243] |
Warning
error
| Re: changing the upload URL [message #579388 is a reply to message #12253] |
Try that.
Wayne
> Warning
> error
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
| Re: changing the upload URL [message #579436 is a reply to message #12263] |
Wed, 22 July 2009 03:06  |
> Try that.
> Wayne
I wonder, why isn't the UDC not using OSGi Preferences Service when its
running as an OSGi service itself?
Other than that I am gonna try to use it in my RCP. Lets see how much
bundles it drags in.
Phil
| Re: changing the upload URL [message #579465 is a reply to message #12283] |
Wed, 22 July 2009 09:28  |
The UDC isn't using the OSGi preferences service because I used the
preferences support that I was familiar with when I built it. I
recommend that you open a bug if you believe that we need to revisit
that decision.
FWIW, the UsageDataService is a pretty poor example of an OSGi Service.
We don't do anything particularly "servicy" with it.
Wayne
| Re: changing the upload URL [message #579481 is a reply to message #12293] |
Wed, 22 July 2009 11:03  |
> that decision.
Thats true :) But it could use preferences anyway. Otherwise there are
so many places where you can put configuration values. For UDC it has to
be a system property for other parts of Eclipse its preferences. Just
hard to remember. I will open a bug to at least consider the preference
value as the default that can be overwritten using a command line
property (aka System property). What you think?
Phil
| Re: changing the upload URL [message #579496 is a reply to message #12303] |
example.
Wayne
FUDForum. Page generated in 0.08315 seconds
