Home » Archived » Visual Editor (VE) » Getting UnsupportedclassversionError when using different JRE
Getting UnsupportedclassversionError when using different JRE [message #129866] Mon, 14 August 2006 10:28 Go to next message
This problem only happens when I use different JRE than the Eclipse's
one. The problem is this, I have installed this Lotus toolkit, and it
automatically sets the JRE and Target Platform to whatever their default
are. Apparently, their JRE is not the same as the one used by Eclipse
at startup time. Is this the reason why JVE throws this
UnsupportedclassversionError? Which JRE is used by JVE? Thanks.
Re: Getting UnsupportedclassversionError when using different JRE [message #129882 is a reply to message #129866] Mon, 14 August 2006 10:51 Go to previous message
Originally posted by: richkulp.us.NO_SPAM.ibm.com
This occurs when a class compiled under JDK 1.5 is executed with the 1.4
JDT. So it all depends on the class that is getting the error and who
compiled it.
The VE uses whatever the project's JRE is set to.
Hung Lam wrote:
> Hello,
Rich Kulp
Re: Getting UnsupportedclassversionError when using different JRE [message #613771 is a reply to message #129866] Mon, 14 August 2006 10:51 Go to previous message
compiled it.
Hung Lam wrote:
> Hello,
Rich Kulp
Previous Topic:Getting UnsupportedclassversionError when using different JRE
Next Topic:Properties Viewer
Current Time: Wed Sep 17 23:48:49 EDT 2025
Powered by FUDForum. Page generated in 0.03540 seconds
