Home » Eclipse Projects » Nebula » cell events
cell events [message #11881] |
Thu, 21 September 2006 16:20  |
Originally posted by: alnospammajor.noboxspamspoon.com
is there a recommended way for the cell contents to fire events that
will get processed at the level of the viewer (actually the view that
contains the viewer)?
TIA,
al
Re: cell events [message #12578 is a reply to message #12519] |
Wed, 27 September 2006 08:07   |
> a) the user interacts with the GEF viewer in a column. this resets the
> view properties (VP) for that particular viewer. an event is fired when
> this happens.
I think a java bean PropertyChangeListener will be good for handling
this, and have thus added support for it to the CContainerCell class
(which, as you know, is the base class for CTableTreeCell).
Presently, the listeners will have to be added to each individual cell
because there are just too many different ways they may (or may not) be
used. Additionally, your custom cell classes will have to call
fireIndexedPropertyChange or firePropertyChange as, and when, appropriate.
Additionally, you need to call the setExclusions method once you have
created your GEF viewer to exclude it from the list of controls that are
managed by the container - in order for the CTableTree to show
selections and handle traversals and mouse events properly it registers
itself with every SWT control in every cell in two ways:
ColorManagedControls and EventManagedControls; if the user is to be able
to interact with controls, as your GEF viewer is, then it needs to be
removed from these lists; setExclusions(Control) should be the easiest
choice in your case.
Note that this is still under construction, so the javadoc is a bit light.
> b) the new VP have to be applied to all GEF viewers in the same column
> (with lazy propagation, maybe only the visible ones).
> in practice, the user can only interact with the visible cells. so the
> "minimal" listener registration would register/unregister the listener
> as the cell becomes visible/invisible. but doing register/unregister
> when the GEF viewer (and/or cell composite) is initialized/disposed
> might also be a reasonable option (and may be required in some other
> usage scenario).
> Jeremy Dowdall wrote:
>> one way to get a cell from the viewer:
>> viewer.getCTableTree().getItem(int).getCell(int)
>> there are other access methods, but I'm not sure which would be best in
>> your case.
>> going the other way:
>> cell.getItem().getContainer()
>> Adding Listeners to cells is being reworked, especially now with the
>> changes to the Title area's life cycle.
>> What type of listeners are you needing and to which contents are you
>> adding them?
>> Al Major wrote:
>>> let me clarify. i'm looking for the best way how to gain access to the
>>> viewer from the cell or vice versa. and the appropriate lifecycle
>>> methods to register and unregister the listeners.
>>>> TIA,
>>>> al
Re: cell events [message #12619 is a reply to message #12578] |
Thu, 28 September 2006 13:34   |
i think the proposed solution will work. one further question
what's the best place to register/unregister the listeners. there are
two cases i'm interested in:
a) register when the GEF viewer is created / unregister when the viewer
is destroyed in the cell.
b) register when the cell becomes visible / unregister when the cell
becomes invisible .
specifically, in which methods of CTableTreeViewer will the registration
/ unregistration code live?
al
>> this happens.
Re: cell events [message #14735 is a reply to message #12578] |
Fri, 20 October 2006 13:48  |
everything works as advertised. i've got the initial implementation
working in toto. sweet!
i'll try to summarize the lifecycle events required by my app in a
separate thread or in bugzilla.
al
>> this happens.
>> usage scenario).
>>> your case.
>>> adding them?
>>>>> TIA,
>>>>> al
Re: cell events [message #565455 is a reply to message #11881] |
Thu, 21 September 2006 16:22  |
> TIA,
> al
Re: cell events [message #565517 is a reply to message #11906] |
Fri, 22 September 2006 08:05  |
your case.
adding them?
>> TIA,
>> al
Re: cell events [message #565552 is a reply to message #12497] |
Fri, 22 September 2006 12:26  |
here's my use case for the listener:
this happens.
usage scenario).
> your case.
> adding them?
>>> TIA,
>>> al
Re: cell events [message #565573 is a reply to message #12519] |
Tue, 26 September 2006 04:06  |
At some point in time (in between 3.3M3) where we have a generic
JFace-Viewer for all Grid/Table like widgets you can vote for this
feature request:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=151377
Tom
> this happens.
> usage scenario).
>> your case.
>> adding them?
>>>> TIA,
>>>> al
Re: cell events [message #565598 is a reply to message #12538] |
Tue, 26 September 2006 14:03  |
tom, my use case seems to require quite a bit more than the feature that
you mention. although i guess the listener registration architecture
would be along similar lines. thx, al.
Tom Schindl wrote:
> feature request:
> Tom
>> this happens.
>> usage scenario).
>>> your case.
>>> adding them?
>>>>> TIA,
>>>>> al
Re: cell events [message #565623 is a reply to message #12519] |
> this happens.
> usage scenario).
>> your case.
>> adding them?
>>>> TIA,
>>>> al
Re: cell events [message #565702 is a reply to message #12578] |
becomes invisible .
al
>> this happens.
Re: cell events [message #565751 is a reply to message #12619] |
Thu, 28 September 2006 15:06  |
i think the answer to b) is to use a paintedItemListener on CContainer.
is that correct? or is there a better way?
i still need to figure out the right way to hook viewer creation / disposal.
thx,
al
> becomes invisible .
> al
Re: cell events [message #566375 is a reply to message #12578] |
Sun, 08 October 2006 13:10  |
thanks! works like a charm. the viewers are getting input mouse events
fine.
i'm still working on getting events out of the viewers.
al
Re: cell events [message #566978 is a reply to message #12578] |
al
>> this happens.
>> usage scenario).
>>> your case.
>>> adding them?
>>>>> TIA,
>>>>> al
Current Time: Sat Jul 12 15:09:22 EDT 2025
Powered by FUDForum. Page generated in 0.13054 seconds
