Home » Archived » Test and Performance Tools Platform (TPTP) » Agent Controller fails to start on linux
Agent Controller fails to start on linux [message #129848] Wed, 07 May 2008 12:01 Go to next message
Originally posted by: cvkmurthy.hotmail.com
Experts,
I am getting following error when I start Agent Controller on linux.
Configuration of the machine is as follows. Agent Controller version is
4.2.0.2. Please advice.
$ uname -a
Linux pnli6005 2.6.5-7.191-smp #1 SMP Tue Jun 28 14:58:56 UTC 2005 86_64
x86_64 x86_64 GNU/Linux
$ ./RAStart.sh
Starting Agent Controller
../RAStart.sh: line 44: ../bin/RAServer: cannot execute binary file
RAServer failed to start
Krishna
Re: Agent Controller fails to start on linux [message #129898 is a reply to message #129848] Thu, 08 May 2008 10:17 Go to previous messageGo to next message
Krishna,
it looks like the executable flag of the binary RAServer is not
set properly in your configuration.
Please execute the following commands in the root directory of your
Agent Controller installation:
pwd
ls -l bin/RAServer
whoami
groups
and post the output for further analysis or even try executing
chmod a+x bin/RAServer
to set the executable flag.
Refer to Manpages (e.g. man chmod) for more information.
Holger
P.S.: I'm no tptp member.
Krishna schrieb:
> Experts,
> $ uname -a
> $ ./RAStart.sh
> Krishna
Re: Agent Controller fails to start on linux [message #129911 is a reply to message #129848] Thu, 08 May 2008 12:48 Go to previous messageGo to next message
Originally posted by: dmohr.cs.unm.edu
Krishna wrote:
> Experts,
> $ uname -a
> $ ./RAStart.sh
> Krishna
Looks to me like you probably have a 32bit binary, which doesn't want to
run on your 64bit system.
~David
Re: Agent Controller fails to start on linux [message #129922 is a reply to message #129911] Fri, 09 May 2008 01:26 Go to previous messageGo to next message
David Mohr wrote:
> Krishna wrote:
>> Experts,
>> is 4.2.0.2. Please advice.
>> $ uname -a
>> 86_64 x86_64 x86_64 GNU/Linux
>> $ ./RAStart.sh
>> Regards,
>> Krishna
> ~David
As you can see below I am running 64 bit binary. Did any body get this
working on linux? If yes, can you please pass on the configurations of
the machine and version of Agent Controller?
$ file RAServer
RAServer: ELF 64-bit MSB executable, cisco 7500, version 1 (SYSV), for
GNU/Linux
2.4.19, dynamically linked (uses shared libs), not stripped
I have execute permissions for RAServer
$ ls -lrt
total 148
-rwxr-xr-x 1 chakrava iman 128 2006-06-19 05:07 SetConfig.sh*
-rwxr-xr-x 1 chakrava iman 133977 2006-06-19 05:24 RAServer*
-rwxr-xr-x 1 chakrava iman 685 2006-06-19 05:24 RAStop.sh*
-rwxr-xr-x 1 chakrava iman 1538 2006-06-19 05:24 RAStart.sh*
Krishna
Re: Agent Controller fails to start on linux [message #129934 is a reply to message #129922] Fri, 09 May 2008 12:19 Go to previous messageGo to next message
Krishna wrote:
> David Mohr wrote:
>> Krishna wrote:
>>> Experts,
>>> linux. Configuration of the machine is as follows. Agent Controller
>>> version is 4.2.0.2. Please advice.
>>> $ uname -a
>>> $ ./RAStart.sh
>>> Regards,
>>> Krishna
>> to run on your 64bit system.
>> ~David
> $ file RAServer
> GNU/Linux
You are not misinterpreting the output of file. Yes, it's 64bit, but
it's not x86 :-). Look at the cisco 7500, in place o that you should
have x86_64. So the correct output would be:
bin/RAServer: ELF 64-bit LSB executable, x86-64, version 1 (SYSV), for
GNU/Linux 2.4.0, dynamically linked (uses shared libs), not stripped
> $ ls -lrt
> total 148
> Krishna
~David
Re: Agent Controller fails to start on linux [message #130032 is a reply to message #129934] Wed, 14 May 2008 00:47 Go to previous message
David Mohr wrote:
> Krishna wrote:
>> David Mohr wrote:
>>> Krishna wrote:
>>>> Experts,
>>>> $ uname -a
>>>> $ ./RAStart.sh
>>>> Regards,
>>>> Krishna
>>> ~David
>> $ file RAServer
>> GNU/Linux
>> $ ls -lrt
>> total 148
>> Regards,
>> Krishna
> ~David
Does it means that I cannot run Agent Controller on my linux machine? Or
is there a different Agent Controller download available at TPTP site
for my machine configuration.
Krishna
Previous Topic:Examples on writing a log correlator?
Next Topic:TPTP and java compiler's "filtered resources"
Current Time: Tue Oct 21 07:15:00 EDT 2025
Powered by FUDForum. Page generated in 0.06186 seconds
