How to disable a built-in constraint [message #11860] |
Sat, 17 March 2007 13:04  |
Originally posted by: maiera.de.ibm.com
in the work on the UML Profile for CIM, we are encountering a built-in
constraint of Error severity which we would like to get rid of, or disable:
Redefining element '<<cIM_Property, property_Constraints>> <Property>
PropUint8 : PropUint8_Enum' is not consistent with redefined element
'<<property_Constraints, cIM_Property>> <Property> PropUint8 : uint8'.
The situation is that in CIM, it is possible to add the ValueMap
qualifier to a redefined property that previously did not have one.
Since we are now using UML Enumerations to map properties qualified with
the CIM ValueMap qualifier, adding this qualifier in a subclass changes
an integer type in the superclass to an enumeration type in the subclass.
This understandably causes the built-in constraint to fire.
My question is:
- Is it possible to disable this particular built-in constraint ?
Andy
Re: How to disable a built-in constraint [message #13474 is a reply to message #11860] |
Sun, 18 March 2007 09:24   |
Hi, Andy,
This is one of the constraints defined by the UML specification. Is that
what you mean by "built-in"? IIRC, you are using RSA, in which case this
constraint can be disabled in the "Modeling / Model Validation" preference
page (I think that's the path). You should also be able to disable it
using the Quick-fix in the Problems view. I don't think there's a means
to disable it for elements with your stereotype only.
Christian
Andreas Maier wrote:
> My question is:
> Andy
Re: How to disable a built-in constraint [message #13537 is a reply to message #13474] |
Sun, 18 March 2007 14:05  |
Hi Christian,
it works, thanks!
Andy
Christian W. Damus wrote:
> Hi, Andy,
> that what you mean by "built-in"? IIRC, you are using RSA, in which
> case this constraint can be disabled in the "Modeling / Model
> Validation" preference page (I think that's the path). You should also
> be able to disable it using the Quick-fix in the Problems view. I don't
> think there's a means to disable it for elements with your stereotype only.
> Cheers,
> Christian
>> disable:
>> with the CIM ValueMap qualifier, adding this qualifier in a subclass
>> changes an integer type in the superclass to an enumeration type in
>> the subclass.
>> My question is:
>> Andy
FUDForum. Page generated in 0.02562 seconds
