Home » Archived » BIRT » Date parameters problem
Date parameters problem [message #129424] Mon, 13 February 2006 14:17
I have an hyperlink image in my report pointing to the same report in
order to render it into PDF. I have two date parameters. In the the value
column of the mapping table I write :
new java.text.SimpleDateFormat("EEE, dd MMM yyyy HH:mm:ss
zzzz").parse(params["my date parameter"])
When I preview the report, I have this error :
Unparseable date: "Sat Jan 01 00:00:00 CET 2005"
If I write only params["my date parameter"], BIRT says that parameters are
not compatible !
Anybody has an idea ?
Ludovic
Previous Topic:Client-Side scripting support
Next Topic:JDBC connection properties in a properties file.
Current Time: Thu Nov 06 09:46:39 EST 2025
Powered by FUDForum. Page generated in 0.03289 seconds
