Home » Language IDEs » Java Development Tools (JDT) » M6 - unable to open Java perspective
M6 - unable to open Java perspective [message #129035] Mon, 22 December 2003 04:43 Go to next message
Hi!
Just download and start linux version
(eclipse-SDK-3.0M6-linux-gtk.zip) on newly workspace. There are
no external plugins, configurations etc.
After starting eclipse console contains message
"Ignore /opt/eclipse/plugins/org.eclipse.jdt.ui_3.0.0/jdt.jar"
When I try to open Java Perspective:
log:
java.lang.ClassNotFoundException: org.eclipse.jdt.internal.ui.JavaPlugin
at org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:365)
at org.eclipse.osgi.framework.adaptor.BundleClassLoader.loadCla ss(BundleClassLoader.java:123)
at org.eclipse.osgi.framework.internal.core.BundleLoader.loadCl ass(BundleLoader.java:268)
at org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:382)
at org.eclipse.osgi.framework.internal.core.Bundle.loadClass(Bu ndle.java:1451)
at org.eclipse.core.internal.plugins.PluginDescriptor.internalD oPluginActivation(PluginDescriptor.java:468)
at org.eclipse.core.internal.plugins.PluginDescriptor.doPluginA ctivation(PluginDescriptor.java:435)
at org.eclipse.core.internal.plugins.PluginDescriptor.getPlugin (PluginDescriptor.java:403)
at org.eclipse.core.internal.compatibility.PluginActivator.star t(PluginActivator.java:48)
at org.eclipse.osgi.framework.internal.core.BundleContext$1.run (BundleContext.java:1185)
at org.eclipse.osgi.framework.internal.core.BundleContext.start Activator(BundleContext.java:1178)
at org.eclipse.osgi.framework.internal.core.BundleContext.start (BundleContext.java:1110)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:458)
at org.eclipse.osgi.framework.internal.core.Bundle.start(Bundle .java:328)
at org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:133)
at org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:125)
at org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:114)
at org.eclipse.ui.internal.WorkbenchPlugin$1.run(WorkbenchPlugi n.java:160)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:84)
at org.eclipse.ui.internal.WorkbenchPlugin.createExtension(Work benchPlugin.java:157)
at org.eclipse.ui.internal.registry.PerspectiveDescriptor.creat eFactory(PerspectiveDescriptor.java:115)
at org.eclipse.ui.internal.Perspective.loadPredefinedPersp(Pers pective.java:659)
at org.eclipse.ui.internal.Perspective.createPresentation(Persp ective.java:290)
at org.eclipse.ui.internal.Perspective.<init>(Perspective.java:177)
at org.eclipse.ui.internal.WorkbenchPage.createPerspective(Work benchPage.java:1041)
at org.eclipse.ui.internal.WorkbenchPage.busySetPerspective(Wor kbenchPage.java:677)
at org.eclipse.ui.internal.WorkbenchPage.access$8(WorkbenchPage .java:669)
at org.eclipse.ui.internal.WorkbenchPage$12.run(WorkbenchPage.j ava:2712)
at org.eclipse.ui.internal.WorkbenchPage.setPerspective(Workben chPage.java:2710)
at org.eclipse.ui.internal.ChangeToPerspectiveMenu.run(ChangeTo PerspectiveMenu.java:63)
at org.eclipse.ui.actions.PerspectiveMenu.run(PerspectiveMenu.j ava:303)
at org.eclipse.ui.actions.PerspectiveMenu$3.widgetSelected(Pers pectiveMenu.java:119)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:89)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :82)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:967)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:1845)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :1625)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1506)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1482)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:246)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:139)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:47)
at org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:85)
at sun.reflect.NativeMethodAccess
Please help!
Re: M6 - unable to open Java perspective [message #129062 is a reply to message #129035] Mon, 22 December 2003 05:14 Go to previous messageGo to next message
What JRE are you using?
-tom
Andrew Utkin wrote:
> Hi!
> log:
> at java.security.AccessController.doPrivileged(Native Method)
> Please help!
Re: M6 - unable to open Java perspective [message #129075 is a reply to message #129062] Mon, 22 December 2003 06:07 Go to previous messageGo to next message
> -tom
From System Summary window:
java.class.path=/opt/eclipse/startup.jar
java.class.version=48.0
java.endorsed.dirs=/opt/j2sdk1.4.2_01/jre/lib/endorsed
java.ext.dirs=/opt/j2sdk1.4.2_01/jre/lib/ext
java.home=/opt/j2sdk1.4.2_01/jre
java.io.tmpdir=/tmp
java.library.path=/opt/j2sdk1.4.2_01/jre/lib/i386/client:/op t/j2sdk1.4.2_01/jre/lib/i386:/opt/j2sdk1.4.2_01/jre/../lib/i 386
java.runtime.name=Java(TM) 2 Runtime Environment, Standard Edition
java.runtime.version=1.4.2_01-b06
java.specification.name=Java Platform API Specification
java.specification.vendor=Sun Microsystems Inc.
java.specification.version=1.4
java.util.prefs.PreferencesFactory=java.util.prefs.FileSyste mPreferencesFactory
java.vendor.url=http://java.sun.com/
java.vendor.url.bug=http://java.sun.com/cgi-bin/bugreport.cgi
java.version=1.4.2_01
java.vm.info=mixed mode
java.vm.name=Java HotSpot(TM) Client VM
java.vm.specification.name=Java Virtual Machine Specification
java.vm.specification.vendor=Sun Microsystems Inc.
java.vm.specification.version=1.0
java.vm.vendor=Sun Microsystems Inc.
java.vm.version=1.4.2_01-b06
From .log:
!SESSION п╢п╣п╨ 22, 2003 12:25:49.805 ---------------------------------------------
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=ru_RU
Command-line arguments: -os linux -ws gtk -arch x86
!ENTRY org.eclipse.core.runtime 4 2 п╢п╣п╨ 22, 2003 12:25:49.806
> Andrew Utkin wrote:
>> Hi!
>> Just download and start linux version (eclipse-SDK-3.0M6-linux-gtk.zip)
>> on newly workspace. There are no external plugins, configurations etc.
>> After starting eclipse console contains message "Ignore
>> log:
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at java.security.AccessController.doPrivileged(Native Method) at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at org.eclipse.ui.internal.Perspective.<init>(Perspective.java:177) at
>> at
>> at
>> at
>> at
>> at
>> at
>> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :82) at
>> org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:967) at
>> org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:1845) at
>> org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :1625) at
>> org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1506) at
>> org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1482) at
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at
>> Please help!
Re: M6 - unable to open Java perspective [message #129085 is a reply to message #129075] Mon, 22 December 2003 07:00 Go to previous messageGo to next message
Hm, no clue. Works fine here on rh 9 using the same vm. The ususal suspects:
- verify download integrity
- extract with unzip, not konqueror
plus, have you tried to run with LANG=en_US?
No more ideas, tom
Re: M6 - unable to open Java perspective [message #129097 is a reply to message #129085] Mon, 22 December 2003 07:13 Go to previous message
eclipse/plugins/org.eclipse.jdt.ui_3.0.0/jdt.jar bad CRC bfdd7799
(should be cb72822e)
Thanks a lot! Sorry for disturbance.
> No more ideas, tom
Previous Topic:which linux version?
Next Topic:Using JDT code formatting from an ant script
Current Time: Fri Nov 07 18:50:27 EST 2025
Powered by FUDForum. Page generated in 0.12629 seconds
