Home » Eclipse Projects » Remote Application Platform (RAP) » ProgressIndicator Problem
ProgressIndicator Problem [message #128917] Mon, 20 April 2009 10:43 Go to next message
I have a background Job that is created using a
IWorkbenchSiteProgressService for a view. When the job is run, it shows
the running animation and job name in the ProgressIndicator. When it
completes, the animation goes away and the text remains, sometimes showing
100%, sometimes showing a different percentage. It appears as though it's
not completing a final update of some sort.
Does anyone have a workaround or some other suggestion?
An example snippet is as follows:
IWorkbenchSiteProgressService ps = (IWorkbenchSiteProgressService)
getViewSite()
.getAdapter(IWorkbenchSiteProgressService.class);
Job job = new Job("Retrieving info from server") {
protected IStatus run(IProgressMonitor monitor) {
monitor.beginTask("Retrieving records", 100);
for (int i = 0; i < 100; i++)
monitor.worked(1);
try {
// Simulate work being done
Thread.sleep(500);
} catch (InterruptedException e) {
e.printStackTrace();
monitor.done();
return Status.OK_STATUS;
ps.schedule(job, 0, true);
Vaughn
Re: ProgressIndicator Problem [message #129126 is a reply to message #128917] Tue, 21 April 2009 07:06 Go to previous messageGo to next message
Hi Vaughn,
this sounds like a bug to me. Could you open up a bug report and include
your snippet and maybe a screenshot of the remaining text?
http://wiki.eclipse.org/RAP_Bug_Reporting_Howto
Thanks, Ralf
> showing 100%, sometimes showing a different percentage. It appears as
> though it's not completing a final update of some sort.
> getViewSite()
> monitor.worked(1);
> try {
> Thread.sleep(500);
> monitor.done();
> Vaughn
Re: ProgressIndicator Problem [message #129374 is a reply to message #129126] Wed, 22 April 2009 08:46 Go to previous message
Done - Bug 273243 created
Previous Topic:Anyone at JAX
Next Topic:Text widget and native browser Copy/Paste menu
Current Time: Wed Nov 05 23:47:33 EST 2025
Powered by FUDForum. Page generated in 0.04873 seconds
