Home » Archived » Visual Editor (VE) » Does the ve support custom data type?
Does the ve support custom data type? [message #128008] Sat, 08 July 2006 10:18 Go to next message
Originally posted by: xubin.wei.ellingtonpcb.com
Hi Rich:
background:
when i add a control to ve, but the control has a custom data type(not
primitive types).
eg:
MyControl contrl = new MyControl();
MyDataType mdt = MyDataType();
mdt.setName("ABC");
contrl.setMyDataType(mdt);
How to do the ve can generate the code like that?
Is there has any example?
Thanks a lot!
gdufo
Re: Does the ve support custom data type? [message #128187 is a reply to message #128008] Mon, 10 July 2006 10:31 Go to previous message
Originally posted by: richkulp.us.NO_SPAM.ibm.com
The property sheet should allow you to do that. There should be
myDataType property on your MyControl. The propertysheet should have a
"..." button on it for the myDataType property. This will allow you to
create a MyDataType instance. Once that is done, the property sheet
should allow you to now set the name property.
gdufo wrote:
> Hi Rich:
> background:
> primitive types).
> eg:
> mdt.setName("ABC");
> Thanks a lot!
> gdufo
Rich Kulp
Re: Does the ve support custom data type? [message #613496 is a reply to message #128008] Mon, 10 July 2006 10:31 Go to previous message
gdufo wrote:
> Hi Rich:
> background:
> primitive types).
> eg:
> mdt.setName("ABC");
> Thanks a lot!
> gdufo
Rich Kulp
Previous Topic:Best way to incorporate an existing visual class in another window
Next Topic:VE & setSize on JPanel class
Current Time: Sun Nov 09 19:11:25 EST 2025
Powered by FUDForum. Page generated in 0.02893 seconds
