Home » Language IDEs » C / C++ IDE (CDT) » Work around to enable changing the C++ linker
Work around to enable changing the C++ linker [message #127706] Thu, 18 November 2004 08:16 Go to next message
Using latest release (3.0.1 & CDT 2.0.2) on Linux (Suse) and a Managed Build
Project, I want to change the linker from g++ to mingw32-g++. However there
appears to be a bug (which I've reported) that crashes eclipse when you
select "C++ Build">"GCC C++ Linker" from Project>Preferences.
Has anyone else experienced this problem, do you have a work around?
I've tried editing .cdtproject to use mingw32-g++ but cdt just ignores the
change and if I change any other Linker options from Projects>Preferences
it changes it back to g++.
Tim
Re: Work around to enable changing the C++ linker [message #127835 is a reply to message #127706] Fri, 19 November 2004 03:15 Go to previous message
A work around involves editing .cdtbuild to contain something like:
<toolReference id="cdt.managedbuild.tool.gnu.cpp.linker"
command="mingw32-g++" outputPrefix="" outputFlag="-o" outputs="">
</toolReference>
Saving it, closing and opening the project.
> Build Project, I want to change the linker from g++ to mingw32-g++.
> However there appears to be a bug (which I've reported) that crashes
> eclipse when you select "C++ Build">"GCC C++ Linker" from
> Tim
Previous Topic:content assist disabled
Next Topic:Output isn't flushed
Current Time: Fri Nov 21 20:26:59 EST 2025
Powered by FUDForum. Page generated in 0.05349 seconds
