Home » Modeling » GMF (Graphical Modeling Framework) » Changing anchor location and z-order of connections
Changing anchor location and z-order of connections [message #11688] |
Wed, 09 August 2006 06:59  |
Originally posted by: gorillas.paradise.net.nz
I've just started using GMF, and I have worked my way through the
tutorial and am now starting on my own editor.
I have a diagram containing nodes and connections. The node figures are
ellipses with a solid white background and a 2-px width outline. The
connections are solid, 9-px width black lines. I want the connections to
anchor to the centre of the nodes, and for the nodes to be above the
connections in the z-order.
In other words, something like this:
(like on the London Tube map the way that the stations are on top of
continuous lines :-)
What I actually see is something like this:
Depending on the angle that the connection comes into the node at, there
can be quite a big gap between the end of the connection and the node. I
also don't want the user to be able to move the anchor point around -
there should just be the one anchor point in the centre of the node, so
I don't think connection decorations would do the trick.
I also want the z-order of the connection point to be lower than all the
other items in the diagram - there are different types of nodes that the
connections won't be connected, but I want the connections to appear
behind those nodes, not in front.
Is it possible to do these things with GMF?
TIA
Colin Sharples
Wellington, New Zealand
Re: Changing anchor location and z-order of connections [message #65378 is a reply to message #11725] |
Wed, 18 October 2006 10:32   |
Sorry, but it was not clear to me where to add the anchor.
i have a similar situation, and i want to connections to be placed only
at the left and right (the A's on the "figure" below) anchors of a figure.
----A A----
Can you help me on this?
thank you in advance!
Ugo
Dmitry Stadnik wrote:
> Hello!
> 1. Connection anchors (see org.eclipse.draw2d.ConnectionAnchor) are
> used to place connection ends so you may write your own anchor if none
> of the existing ones do what you need. Standard EllipseAnchor places
> connection ends on ellipse edge.
> 2. Nodes and connections are placed on different layers - you may
> swap the layers so connections will always be above nodes (see
> DiagramRootEditPart#createPrintableLayers()).
>> are ellipses with a solid white background and a 2-px width outline.
>> The connections are solid, 9-px width black lines. I want the
>> connections to anchor to the centre of the nodes, and for the nodes to
>> be above the connections in the z-order.
>> there can be quite a big gap between the end of the connection and the
>> node. I also don't want the user to be able to move the anchor point
>> around - there should just be the one anchor point in the centre of
>> the node, so I don't think connection decorations would do the trick.
>> the other items in the diagram - there are different types of nodes
>> that the connections won't be connected, but I want the connections to
>> appear behind those nodes, not in front.
>> TIA
Re: Changing anchor location and z-order of connections [message #71497 is a reply to message #65378] |
Mon, 30 October 2006 07:56   |
Originally posted by: julias.frb.br
You just get the FixedConnectionAnchor from Logic Example and put this
on your XXXEditPart:
* @generated NOT
public ConnectionAnchor getSourceConnectionAnchor(ConnectionEditPart
arg0) {
FixedConnectionAnchor fixedAnchor = new FixedConnectionAnchor(
getFigure());
fixedAnchor.offsetH = 120;
fixedAnchor.offsetV = 40;
//it creates an anchor for source on point 120,40
return fixedAnchor;
* @generated NOT
public ConnectionAnchor getSourceConnectionAnchor(Request request) {
getFigure());
return fixedAnchor;
* @generated NOT
public ConnectionAnchor getTargetConnectionAnchor(ConnectionEditPart
arg0) {
getFigure());
fixedAnchor.offsetH = 0;
return fixedAnchor;
* @generated NOT
public ConnectionAnchor getTargetConnectionAnchor(Request request) {
getFigure());
return fixedAnchor;
> ----A A----
> Ugo
>> Hello!
>> are used to place connection ends so you may write your own anchor if
>> none of the existing ones do what you need. Standard EllipseAnchor
>> places connection ends on ellipse edge.
>>> to be above the connections in the z-order.
>>> the node. I also don't want the user to be able to move the anchor
>>> point around - there should just be the one anchor point in the
>>> centre of the node, so I don't think connection decorations would do
>>> the trick.
>>> to appear behind those nodes, not in front.
>>> TIA
Re: Changing anchor location and z-order of connections [message #148736 is a reply to message #71497] |
Sat, 01 September 2007 05:51   |
Originally posted by: blaent.gmx.de
Many thanks to Julia, it works fine!
After moving the figure the anchors are no longer fixed... How can I
achieve that?
Thanks for any help,
Markus
> * @generated NOT
> @Override
> arg0) {
> getFigure());
> return fixedAnchor;
> * @generated NOT
> @Override
> getFigure());
> return fixedAnchor;
> * @generated NOT
> @Override
> arg0) {
> getFigure());
> return fixedAnchor;
> * @generated NOT
> @Override
> getFigure());
> return fixedAnchor;
>> only at the left and right (the A's on the "figure" below) anchors of
>> a figure.
>> ----A A----
>> Ugo
>>> Hello!
>>>> the trick.
>>>> TIA
Re: Changing anchor location and z-order of connections [message #513227 is a reply to message #11688] |
Tue, 09 February 2010 07:42  |
I've the same problem. But your solution doesn't work with the current
version of GMF. So how is it possible to swap the node and connection
layers now?
thanks,
Bastian
> TIA
Current Time: Sat Jul 12 19:09:52 EDT 2025
Powered by FUDForum. Page generated in 0.05047 seconds
