| manifest.mf file [message #127612] |
Mon, 16 March 2009 03:25  |
Originally posted by: egidijus.vaisnora.nomagiclt.com
Does manifest.mf support relative paths "Bundle-ClassPath"?
Problem appeared when I have moved runtime information (relative paths to libraries) from the plugin.xml to the manifest.mf
file into "Bundle-ClassPath". The result is strange - there are no exception (-debug option was used), plugin is shown in
plug-in list, but there are no UI item of this plugin!
Another question: Does "Export-Package" support patterns like "*"? In help it is not mentioned, but Eclipse doesn't complains
if I use such pattern...
Please advice
Thank you!
Egidijus
| Re: manifest.mf file [message #127771 is a reply to message #127747] |
Thu, 19 March 2009 11:23  |
The OSGi spec may be useful to you.
http://www.osgi.org/Specifications/HomePage
For Bundle-Classpath, section 3.8.1.
For Export-Package, section 3.5.5.
Egidijus Vaisnora wrote:
> I ment relative path something like:
> Bundle-ClassPath: ../../../../../lib/x.jar,
> ../../../../../lib/y.jar,
> plugin_eclipse_api.jar,
> ../../../../../lib/z.jar,
>> to libraries) from the plugin.xml to the manifest.mf file into
>> (-debug option was used), plugin is shown in plug-in list, but there
>> help it is not mentioned, but Eclipse doesn't complains if I use such
>> pattern...
>> Please advice
>> Thank you!
>> Egidijus
FUDForum. Page generated in 0.03453 seconds
