Home » Modeling » GMF (Graphical Modeling Framework) » commands chaining
commands chaining [message #127554] |
Sun, 20 May 2007 18:24  |
I'm trying to implement the following behaviour: a user clicks element A
with element B creation tool, and then element B appears on the diagram
connected to A with a link.
In the model this corresponds to creating EObject for B and an EObject for
A->B reference.
I have 2 commands for both these actions - there is also some side-work
performed there. So, operation 2 (create reference A->B) needs to take as
an input the result of operation 1 (create new B).
What is the right way for chaining these operations in GMF? Or maybe
should I create a separate command for this action? Hoping not.
Alexey
Re: commands chaining [message #127831 is a reply to message #127717] |
Mon, 21 May 2007 10:54   |
--------------070202030908050107030006
Artem,
EMF's commands always have a getResult that should typically be the
thing added, removed, created, copied, or whatever the command is doing
that would best be considered the result of the command. I'm just not
sure how that applies or is accessible in GMF...
Artem Tikhomirov wrote:
> CompositeCommand or #chain() depending on what commands (EMF/GEF/GMF) you
> are using, however, passing data from one command to another is up to you.
> E.g. one can use Request (e.g. see CreateElementRequest#setNewElement) to
> pass this data around.
> "Alexey Semenov" <alexeysem@gmail.com> wrote in message
> news:op.tsncjpbo32v8ru@asdell...
>> A->B reference.
>> Regards,
>> Alexey
<html>
<head>
</head>
Artem,<br>
<br>
sure how that applies or is accessible in GMF...<br>
<br>
<br>
<blockquote cite="midf2rs3b$3lb$1@build.eclipse.org" type="cite">
<pre wrap="">CompositeCommand or #chain() depending on what commands (EMF/GEF/GMF) you
"Alexey Semenov" <a class="moz-txt-link-rfc2396E" href="mailto:alexeysem@gmail.com"><alexeysem@gmail.com></a> wrote in message
<a class="moz-txt-link-freetext" href="news:op.tsncjpbo32v8ru@asdell">news:op.tsncjpbo32v8ru@asdell</a>...
</pre>
<blockquote type="cite">
<pre wrap="">Hi,
A->B reference.
Alexey
</pre>
</blockquote>
<pre wrap=""><!---->
</pre>
</blockquote>
<br>
</body>
</html>
--------------070202030908050107030006--
Re: commands chaining [message #127881 is a reply to message #127831] |
Mon, 21 May 2007 13:43  |
------=_NextPart_000_001A_01C79BE0.5217F5B0
charset="ISO-8859-1"
getResult() (for those lucky EMF clients ;), GEF's are whining) is still =
only half of the issue - to pass this result to another command one may =
need to put some extra efforts. I assume neither operation 2 nor =
operation 1 knows about its counterpart.
Artem
"Ed Merks" <merks@ca.ibm.com> wrote in message =
news:f2sbqn$a90$1@build.eclipse.org...
Artem,
EMF's commands always have a getResult that should typically be the =
thing added, removed, created, copied, or whatever the command is doing =
that would best be considered the result of the command. I'm just not =
Artem Tikhomirov wrote:=20
CompositeCommand or #chain() depending on what commands (EMF/GEF/GMF) =
you=20
are using, however, passing data from one command to another is up to =
you.=20
E.g. one can use Request (e.g. see CreateElementRequest#setNewElement) =
to=20
"Alexey Semenov" <alexeysem@gmail.com> wrote in message=20
I'm trying to implement the following behaviour: a user clicks element A =
with element B creation tool, and then element B appears on the diagram=20
In the model this corresponds to creating EObject for B and an EObject =
for=20
A->B reference.
I have 2 commands for both these actions - there is also some side-work=20
performed there. So, operation 2 (create reference A->B) needs to take =
as=20
What is the right way for chaining these operations in GMF? Or maybe=20
Alexey=20
=20
=20
<HTML><HEAD>
<META content=3D"MSHTML 6.00.2900.3086" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<DIV><FONT face=3DArial size=3D2>getResult() (for those lucky EMF =
clients ;), GEF's=20
are whining) is still only half of the issue - to pass this result =
to=20
another command one may need to put some extra efforts. I assume neither =
operation 2 nor operation 1 knows about its counterpart.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT> </DIV>
<DIV><FONT face=3DArial size=3D2>Artem</FONT></DIV>
<BLOCKQUOTE=20
<DIV>"Ed Merks" <<A =
href=3D"mailto:merks@ca.ibm.com">merks@ca.ibm.com</A>>=20
wrote in message <A=20
href=3D"news:f2sbqn$a90$1@build.eclipse.org">news:f2sbqn$a90$1@build.ecli=
pse.org</A>...</DIV>Artem,<BR><BR>EMF's=20
thing=20
added, removed, created, copied, or whatever the command is doing that =
would=20
best be considered the result of the command. I'm just not sure =
how that=20
applies or is accessible in GMF...<BR><BR><BR>Artem Tikhomirov wrote:=20
<BLOCKQUOTE cite=3Dmidf2rs3b$3lb$1@build.eclipse.org =
type=3D"cite"><PRE wrap=3D"">CompositeCommand or #chain() depending on =
what commands (EMF/GEF/GMF) you=20
you.=20
to=20
"Alexey Semenov" <A class=3Dmoz-txt-link-rfc2396E =
href=3D"mailto:alexeysem@gmail.com"><alexeysem@gmail.com></A> =
wrote in message=20
<A class=3Dmoz-txt-link-freetext =
href=3D"news:op.tsncjpbo32v8ru@asdell">news:op.tsncjpbo32v8ru@asdell</A>.=
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">Hi,
for=20
A->B reference.
performed there. So, operation 2 (create reference A->B) needs to =
take as=20
Alexey=20
</PRE></BLOCKQUOTE><PRE wrap=3D""><!---->
</PRE></BLOCKQUOTE><BR></BLOCKQUOTE></BODY></HTML>
------=_NextPart_000_001A_01C79BE0.5217F5B0--
Current Time: Sun Aug 31 07:17:12 EDT 2025
Powered by FUDForum. Page generated in 0.03793 seconds
