Home » Eclipse Projects » Remote Application Platform (RAP) » Could not register custom theme
Could not register custom theme [message #127420] Tue, 07 April 2009 02:11 Go to next message
I had a little problem using my custom theme. All the time I got the
error message 'Could not register custom theme...'. The solution a small
change in the org.eclipse.rap.ui.workbench bundle. The internal class
in
org.eclipse.rap.ui.internal.servlet.EngineConfigWrapper#regi sterThemes
uses the #getResource Method of the bundle to get the url to read the
theme from. I changed this for my self to #getEntry - and it works as
expected. May this is a bug?
Christian
Re: Could not register custom theme [message #127466 is a reply to message #127420] Tue, 07 April 2009 05:42 Go to previous messageGo to next message
Hi Christian,
> in
Could you describe the problem in more detail? Do you use fragments,
what does the paths in your extension look like, etc.? Could you post
the complete stack trace of the error you get?
I don't think that your solution is feasible since #getEntry does not
work with fragments.
Regards, Ralf
Re: Could not register custom theme [message #127512 is a reply to message #127466] Tue, 07 April 2009 08:37 Go to previous message
after some more playing around with this, I found this article (
http://www.eclipsezone.com/eclipse/forums/t101557.rhtml ) that helped me
out. My fault was that I didn't have the '.' in the classpath of my
manifest file.
No it works as expected, thanks for your help.
Christian
Previous Topic:GEF with RAP
Next Topic:Composite as a TreeItem
Current Time: Mon Nov 10 06:30:09 EST 2025
Powered by FUDForum. Page generated in 0.04331 seconds
