Home » Eclipse Projects » GEF » Word Wrap with \r\n
Word Wrap with \r\n [message #127409] Thu, 15 April 2004 05:22 Go to next message
Originally posted by: sellai.yahoo.com
I have a figure which functions like the label in the logic example.
However, in my case it word wraps. I've discovered that if i don't set any
layout manager for the TextFlow, it will not recognize "\r\n" etc... If i
set the layout manager as "SimpleTextLayout", it works fine. But is there
a layout that allows both scenario? so that i don't have to set different
layout for different part of the input text?
Thanks in advance.
June
Re: Word Wrap with \r\n [message #127445 is a reply to message #127409] Thu, 15 April 2004 10:41 Go to previous messageGo to next message
Have you tried the "ParagraphTextLayout"? You may also want to take a look
at the label in the current Logic Example (3.0 Stream). It allows for direct
editing of text including wrapping and hard line breaks.
"June" <sellai@yahoo.com> wrote in message news:c5lk9j$amr$1@eclipse.org...
> Thanks in advance.
> June
Re: Word Wrap with rn [message #127586 is a reply to message #127445] Thu, 15 April 2004 21:31 Go to previous messageGo to next message
I tried ParagraphTextLayout as well, but it was no use. I think it is the
default layout manager for TextFlow....
> > Hi,
> > layout manager for the TextFlow, it will not recognize "rn" etc... If i
> > Thanks in advance.
> > Regards,
> > June
Re: Word Wrap with rn [message #127669 is a reply to message #127586] Fri, 16 April 2004 10:32 Go to previous message
Have you tried a new build of GEF, or looked at the new label in the Logic
Example?
"June" <sellai@yahoo.com> wrote in message news:c5nd2c$l03$1@eclipse.org...
look
direct
> > > Hi,
example.
any
i
there
different
> > > Thanks in advance.
> > > Regards,
> > > June
Re: Word Wrap with \r\n [message #127729 is a reply to message #127409] Fri, 16 April 2004 10:01 Go to previous message
Newlines were not handled in 2.1 I believe. What you have to do, is create
a BlockFlow for each paragraph.
> Thanks in advance.
> June
Previous Topic:button field in MouseMotionListener.mouseDragged() always 0
Next Topic:Newbie: Resize in draw2d
Current Time: Sat Nov 15 10:54:41 EST 2025
Powered by FUDForum. Page generated in 0.07168 seconds
