Home » Archived » BIRT » Check if a script variable is defined?
Check if a script variable is defined? [message #127231] Thu, 09 February 2006 11:35
Originally posted by: hbanh.jinnova.com
Hi all,
I use scripted dataset in my report. The dataset reads data from a
business object, which is passed using setScriptableObject().
It works at run time. However, at design time, when I clicks on preview
tab, a script error of course.
To avoid that error, I need to check the availability of the script
object. Can someone tell me if this possible, please?
Huy.
Previous Topic:Swing rendering?
Next Topic:Error Building viewer
Current Time: Sun Oct 19 02:38:36 EDT 2025
Powered by FUDForum. Page generated in 0.04185 seconds
