Home » Eclipse Projects » Equinox » P2 Software Update UI shows .qualifier, but Help/About does not
P2 Software Update UI shows .qualifier, but Help/About does not [message #127157] Fri, 06 March 2009 14:22 Go to next message
Could somebody explain why the result from a headless PDE Build that uses
the p2 generator property, and runs the director, ends up building a product
that, when you look at Help/About shows full versions for features/plug-ins
(where the .qualifier was replaced) but in the P2 UI shows literally
".qualifier" ?
Is PDE running some P2 tasks before the .qualifier has been replaced?
Also, the P2 director is invoked without the version argument (so it picks
up the latest (only!) version, I suppose).
Thank you!
- Eddie
Re: P2 Software Update UI shows .qualifier, but Help/About does not [message #127167 is a reply to message #127157] Fri, 06 March 2009 14:36 Go to previous messageGo to next message
Adding some information:
the .product file version reads "1.2.3.qualifier" ; I used to not even set
the version in that file, but decided to start doing so. Does PDE not update
that .qualifier?
- Eddie
Re: P2 Software Update UI shows .qualifier, but Help/About does not [message #127207 is a reply to message #127167] Mon, 09 March 2009 09:03 Go to previous message
https://bugs.eclipse.org/bugs/show_bug.cgi?id=246060
> set the version in that file, but decided to start doing so. Does PDE
> not update that .qualifier?
> - Eddie
Previous Topic:The state indicates the bundle is resolved?
Next Topic:2 versions of log4j-core.jar
Current Time: Tue Nov 18 17:10:01 EST 2025
Powered by FUDForum. Page generated in 0.03232 seconds
