| MetaCoder XML/XSLT Code Generation Development Perspective [message #11637] |
Tue, 23 July 2002 06:46  |
The MetaCoder plugin version 1.0 has just been release (
http://metacoder.info ). Using this as a statement of direction I would like
collaborate with other developers in producing a "State of the art" Open
Source XML/XSLT Code Generation Development Perspective.
For starters,
Base lining
A frank and open discussion on Code Generation as it applies to the software
development process
The Pro's and Con's of XML/XSLT based generators
The Pro's and Con's of MetaCoder's specific implementation
Moving things forward
What do we want to change?
The incorporation of a UML type Modelling interface. On the basis that
unless the UML construct is directly render able as code it is meaningless
for our purposes?
XML import from non-XML sources. Java source/class. Database Meta Data,
Antlr parser for regular text documents?
What existing plug-ins can be tailored to improve Meta-Code development
productivity?
Should there be enough support for the idea the intent would be to create an
official sub project.
To that end join me and post your comments and suggestions
Best
Tayo
P.S. Hat's off to IBM for what they have started by open sourcing eclipse.
In my humble opinion it was an inspired decision and forms an inspiring
foundation for developing ideas.
| Re: MetaCoder XML/XSLT Code Generation Development Perspective [message #11859 is a reply to message #11787] |
Wed, 24 July 2002 02:48  |
Interesting idea ;-)
Could you expand a little on how it would work?
Best
Tayo
"Rong C. Ou" <rong.ou@verizon.net> wrote in message
news:3D3E17D3.1020006@verizon.net...
> I always thought it'd be fun (and productive) to
> write the code generator using the code generator
> itself. Once you've created a minimal set of
> bootstraping classes, you can use the tool to
> write the tool. Kinda like the idea behind eclipse.
> Do you have any plans for that?
> Rong
like
> > For starters,
> > Base lining
software
> > development process
meaningless
> > for our purposes?
> > productivity?
create an
> > Best
> > Tayo
eclipse.
| Re: MetaCoder XML/XSLT Code Generation Development Perspective [message #569971 is a reply to message #11637] |
Tue, 23 July 2002 22:58  |
Rong
> For starters,
> Base lining
> development process
> for our purposes?
> productivity?
> Best
> Tayo
| Re: MetaCoder XML/XSLT Code Generation Development Perspective [message #570010 is a reply to message #11787] |
Best
Tayo
> Rong
like
> > For starters,
> > Base lining
software
> > development process
meaningless
> > for our purposes?
> > productivity?
create an
> > Best
> > Tayo
eclipse.
FUDForum. Page generated in 0.03969 seconds
