Home » Language IDEs » Java Development Tools (JDT) » run ant
run ant [message #127031] Fri, 12 December 2003 16:09 Go to next message
Originally posted by: lxuattech.yahoo.com
The following is my deploy.xml.
<project name="deploy" default="usage" basedir=".">
<taskdef name="jag_connect"
classname="com.sybase.jaguar.management.jagtool.ant.ConnectTask "/>
<property name="jaguar.host" value="lxuw2k" />
<property name="jaguar.port" value="9000" />
<property name="jaguar.user" value="jagadmin" />
<property name="jaguar.password" value="" />
<target name="connect" unless="already.connected">
<property name="already.connected" value="true"/>
<echo message="Connecting to the server ${jaguar.host}"/>
<jag_connect host="${jaguar.host}" port="${jaguar.port}"
user="${jaguar.user}" password="${jaguar.password}"
</target>
</project>
I run the deploy.xml outside of eclipse. Everything is OK. But when I run
inside of eclipse(I put all the helper.jar in ant classpath. ), the
following error occurs:
Arguments:
Connecting to the server lxuw2k
Build exception: D:\Program Files\eclipse\workspace\Patriot\deploy.xml:34:
Cannot connect to server at lxuw2k:9000
D:\Program Files\eclipse\workspace\Patriot\deploy.xml:34: Cannot connect
com.sybase.jaguar.management.jagtool.ant.ConnectTask.execute (ConnectTask.java:77)
at org.apache.tools.ant.Task.perform(Task.java:217)
at org.apache.tools.ant.Target.execute(Target.java:184)
at org.apache.tools.ant.Target.performTasks(Target.java:202)
at org.apache.tools.ant.Project.executeTarget(Project.java:601)
at org.apache.tools.ant.Project.executeTargets(Project.java:560 )
org.eclipse.ant.internal.core.ant.InternalAntRunner.run(Inte rnalAntRunner.java:262)
at org.eclipse.ant.core.AntRunner.run(AntRunner.java:234)
org.eclipse.ui.externaltools.internal.core.AntFileRunner.exe cute(AntFileRunner.java:56)
org.eclipse.ui.externaltools.internal.core.DefaultRunnerCont ext.executeRunner(DefaultRunnerContext.java:428)
org.eclipse.ui.externaltools.internal.core.DefaultRunnerCont ext.run(DefaultRunnerContext.java:479)
org.eclipse.ui.externaltools.internal.ui.AntLaunchWizard$1.r un(AntLaunchWizard.java:117)
org.eclipse.jface.operation.ModalContext$ModalContextThread. run(ModalContext.java:98)
--- Nested Exception ---
org.omg.CORBA.INITIALIZE: can't instantiate default ORB implementation
com.sybase.CORBA.ORB vmcid: 0x0 minor code: 0 completed: No
at org.omg.CORBA.ORB.create_impl(ORB.java:297)
at org.omg.CORBA.ORB.init(ORB.java:336)
com.sybase.jaguar.management.jagtool.JTContext.initialize(JT Context.java:125)
com.sybase.jaguar.management.jagtool.ant.ConnectTask.execute (ConnectTask.java:73)
Caused by: java.lang.ClassNotFoundException: com.sybase.CORBA.ORB
at java.net.URLClassLoader$1.run(URLClassLoader.java:198)
at java.net.URLClassLoader.findClass(URLClassLoader.java:186)
at java.lang.ClassLoader.loadClass(ClassLoader.java:299)
at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:265 )
at java.lang.ClassLoader.loadClass(ClassLoader.java:255)
at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:315 )
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Class.java:217)
at org.omg.CORBA.ORB.create_impl(ORB.java:295)
Any idea?
Thank
Xiao
Re: run ant [message #127044 is a reply to message #127031] Fri, 12 December 2003 16:20 Go to previous messageGo to next message
So you have a JAR on your Eclipse Ant runtime classpath that contains
com.sybase.CORBA.ORB?
Darins
"xiao" <lxuattech@yahoo.com> wrote in message
news:brdaq3$ic8$1@eclipse.org...
> </target>
> </project>
> Arguments:
> at
a:77)
> at
va:262)
> at
> at
..java:25)
> at
er.java:56)
> at
> at
> at
rd.java:117)
> at
..java:98)
> at
> at
a:73)
> at
va:262)
> at
> at
..java:25)
> at
er.java:56)
> at
> at
> at
rd.java:117)
> at
..java:98)
> at java.security.AccessController.doPrivileged(Native Method)
> Any idea?
> Thank
> Xiao
Re: run ant [message #127057 is a reply to message #127044] Fri, 12 December 2003 17:12 Go to previous message
Yes.
> Darins
> > </target>
> > </project>
> > Arguments:
> > Build exception: D:Program FileseclipseworkspacePatriotdeploy.xml:34:
> > D:Program FileseclipseworkspacePatriotdeploy.xml:34: Cannot connect
> > at
> a:77)
> > at
> va:262)
> > at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
> > at
> > at
> ..java:25)
> > at
> er.java:56)
> > at
> > at
> > at
> rd.java:117)
> > at
> ..java:98)
> > at
> > at
> a:73)
> > at
> va:262)
> > at
> > at
> ..java:25)
> > at
> er.java:56)
> > at
> > at
> > at
> rd.java:117)
> > at
> ..java:98)
> > Any idea?
> > Thank
> > Xiao
Previous Topic:Unable to run JUnit test cases
Next Topic:Error on assert
Current Time: Tue Aug 19 22:18:42 EDT 2025
Powered by FUDForum. Page generated in 0.05660 seconds
