Exporting a feature [message #126900] |
Fri, 12 December 2003 14:06 |
I have devoped a primary feature that defines 3 plugins. As long as there
are no code dependancies between the plugins, the feature exports fine.
However, one of my plugins depends on code from the other. As soon as I
add the dependant plugin, I get compile errors (see below), and a failure
dialog box.
I can't seem to resolve the dependancy. This only happens during feature
'Export'. Everything builds within my workspace fine.
Is there something I need to do?
I also included my feature.xml file for good measure.
-Mitch
----------Security.jar.bin.log
1. ERROR in
C:\dev\rapid\plugins\Security\src\com\informatixinc\rapid\pl ugins\Security\AuthenticateDlg.java
(at line 20)
import com.informatixinc.rapid.model.security.User;
The import com.informatixinc.rapid.model cannot be resolved
...and lots more
----------feature.xml
<feature
id="com.informatixinc.rapid.features.Primary"
label="Primary"
version="1.0.0"
provider-name="Informatix, Inc."
plugin="Primary"
os="win32"
ws="win32"
nl="en_US"
arch="x86"
primary="true">
<requires>
<import plugin="org.eclipse.ui"/>
<import plugin="org.eclipse.core.resources"/>
<import plugin="com.informatixinc.rapid.plugins.ImageViewer"/>
<import plugin="org.eclipse.update.core"/>
</requires>
<plugin
id="com.informatixinc.rapid.plugins.Core"
download-size="0"
install-size="0"
version="1.0.0"/>
<plugin
id="com.informatixinc.rapid.plugins.HibernatOR"
download-size="0"
install-size="0"
version="1.0.0"/>
<plugin
id="com.informatixinc.rapid.plugins.Security"
download-size="0"
install-size="0"
version="1.0.0"/>
</feature>
FUDForum. Page generated in 0.03765 seconds
