Multi-file replace [message #11604] |
Fri, 21 January 2005 23:51  |
Originally posted by: dmerrillq.usaq.netq
Are there any stable plugins for doing multi-file or project-wide text
replacement? Did I miss where this is in Eclipse itself?
I'm using Eclipse 3.0.1, if that matters.
Dave Merrill
Re: Multi-file replace [message #13122 is a reply to message #12981] |
Sun, 23 January 2005 09:08  |
Thanks Jeff. Reflexes got the better of me; with an editor pane active, I
hit ctrl-F, which worked, but isn't that much more capable tool. For some
lame reason, it didn't occur to me to look in the menus... not good...
Dave
"Jeff Myers" wrote in message news:csv5e1$mt9$1@www.eclipse.org...
> Dave,
> Open the Eclipse search from the menu, or press Ctrl-H. Switch to the
> File tab, and enter the text you'd like to search for. Choose the file
> name patterns and search scope as applicable, then hit the Replace
> button at the bottom of the dialog. The rest should be self explanitory.
> Hope this helps,
> - Jeff
> > Thanks,
> > Dave Merrill
FUDForum. Page generated in 0.09134 seconds
