Home » Newcomers » Newcomers » Multi-file replace
Multi-file replace [message #11604] Fri, 21 January 2005 23:51 Go to next message
Originally posted by: dmerrillq.usaq.netq
Are there any stable plugins for doing multi-file or project-wide text
replacement? Did I miss where this is in Eclipse itself?
I'm using Eclipse 3.0.1, if that matters.
Dave Merrill
Re: Multi-file replace [message #12981 is a reply to message #11604] Sat, 22 January 2005 22:25 Go to previous messageGo to next message
Originally posted by: myersj.gmail.com
Dave,
Open the Eclipse search from the menu, or press Ctrl-H. Switch to the
File tab, and enter the text you'd like to search for. Choose the file
name patterns and search scope as applicable, then hit the Replace
button at the bottom of the dialog. The rest should be self explanitory.
Hope this helps,
- Jeff
> Dave Merrill
Re: Multi-file replace [message #13122 is a reply to message #12981] Sun, 23 January 2005 09:08 Go to previous message
Thanks Jeff. Reflexes got the better of me; with an editor pane active, I
hit ctrl-F, which worked, but isn't that much more capable tool. For some
lame reason, it didn't occur to me to look in the menus... not good...
Dave
"Jeff Myers" wrote in message news:csv5e1$mt9$1@www.eclipse.org...
> Dave,
> Hope this helps,
> - Jeff
> > Thanks,
> > Dave Merrill
Previous Topic:Ant + Eclipse
Next Topic:Different package explorer icons for classes, abstract classes, interfaces
Current Time: Wed Jul 16 01:29:37 EDT 2025
Powered by FUDForum. Page generated in 0.08970 seconds
