Home » Language IDEs » ServerTools (WTP) » Download fails
Download fails [message #126784] Thu, 28 July 2005 07:06 Go to next message
Originally posted by: njayaraman.tomax.com
I am not able to download WTP zip file. This link always fails. Any idea ?
Re: Download fails [message #127049 is a reply to message #126784] Thu, 28 July 2005 14:41 Go to previous messageGo to next message
Perhaps the mirror you were accessing from is temporarily down. Try again,
or try a different link.
"Narayanan" <njayaraman@tomax.com> wrote in message
news:b997eb920eb639faa6ddb29913e53313$1@www.eclipse.org...
Re: Download fails [message #127192 is a reply to message #127049] Fri, 29 July 2005 03:09 Go to previous messageGo to next message
I tried from eclipse.org site. When I click the link it downloads only the
html file as Zip file with the size of 7 KB. Any idea ?.
Re: Download fails [message #127244 is a reply to message #127192] Fri, 29 July 2005 04:42 Go to previous messageGo to next message
> the html file as Zip file with the size of 7 KB. Any idea ?.
When you click on a link in the mirror list for a build it's
actually sending you to another HTML page. *That* page records that
a download was attempted and then forwards you onto the actual file.
Are you trying to save the .zip file directly from the mirror
selection page?
- Nitin
Re: Download fails [message #127270 is a reply to message #127244] Fri, 29 July 2005 05:05 Go to previous message
I found out DAP was causing this issue. Thanks for your help.
Previous Topic:Highlighting for XML without DTD or XML Schema and without *.xml extension
Next Topic:[rdb] DDL generate for one column only
Current Time: Mon Jul 21 22:03:40 EDT 2025
Powered by FUDForum. Page generated in 0.06850 seconds
