Equnox installer [message #126623] |
Sat, 28 February 2009 11:43  |
I've just tried Equinox Installer, hoping to see an impressive
performance with 3.4.2, as promoted in the N&N.
Instead, after much downloading, I get an error during 'configuration'.
Has anyone validated it with the current releases?
Neale
Log is:
!SESSION 2009-02-28 16:22:36.796
eclipse.buildId=@build@
java.version=1.6.0_11
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_GB
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.osgi 4 0 2009-02-28 16:22:37.875
!MESSAGE Bundle org.eclipse.swt.gtk.linux.x86 not found.
!MESSAGE Bundle org.eclipse.swt.carbon.macosx not found.
!ENTRY org.eclipse.equinox.p2.metadata.repository 2 0 2009-02-28
16:25:39.500
!MESSAGE Error parsing metadata repository
!SUBENTRY 1 org.eclipse.equinox.p2.core 2 0 2009-02-28 16:25:39.500
!MESSAGE Error at line 9, column 90: Missing required attribute in
"repository": url
!MESSAGE Error at line 9, column 90: Illegal value for attribute "url"
of element "repository": null
!MESSAGE Error at line 10, column 93: Missing required attribute in
"repository": url
!MESSAGE Error at line 10, column 93: Illegal value for attribute "url"
!MESSAGE Error at line 11, column 90: Missing required attribute in
"repository": url
!MESSAGE Error at line 11, column 90: Illegal value for attribute "url"
!MESSAGE Error at line 12, column 93: Missing required attribute in
"repository": url
!MESSAGE Error at line 12, column 93: Illegal value for attribute "url"
!MESSAGE Error at line 13, column 93: Missing required attribute in
"repository": url
!MESSAGE Error at line 13, column 93: Illegal value for attribute "url"
!MESSAGE Error at line 14, column 93: Missing required attribute in
"repository": url
!MESSAGE Error at line 14, column 93: Illegal value for attribute "url"
16:25:41.484
!SUBENTRY 1 org.eclipse.equinox.p2.core 2 0 2009-02-28 16:25:41.484
"repository": url
"repository": url
"repository": url
"repository": url
"repository": url
"repository": url
!ENTRY org.eclipse.osgi 2 1 2009-02-28 16:25:44.562
!MESSAGE NLS missing message: Can_not_create_temp_dir in:
org.eclipse.equinox.internal.p2.artifact.optimizers.messages
!MESSAGE NLS missing message: Can_not_delete_temp_dir in:
!MESSAGE NLS missing message: Empty_stream in:
!ENTRY org.eclipse.equinox.p2.engine 4 4 2009-02-28 16:34:51.125
!MESSAGE An error occurred while configuring the installed items
!SUBENTRY 1 org.eclipse.equinox.p2.engine 4 0 2009-02-28 16:34:51.125
!MESSAGE No action found for: addRepository.
!STACK 0
java.lang.IllegalArgumentException: No action found for: addRepository.
org.eclipse.equinox.internal.p2.engine.InstructionParser.loo kupAction(InstructionParser.java:66)
org.eclipse.equinox.internal.p2.engine.InstructionParser.par seAction(InstructionParser.java:44)
org.eclipse.equinox.internal.p2.engine.InstructionParser.par seActions(InstructionParser.java:34)
org.eclipse.equinox.internal.provisional.p2.engine.Installab leUnitPhase.getActions(InstallableUnitPhase.java:161)
org.eclipse.equinox.internal.provisional.p2.engine.phases.Co nfigure.getActions(Configure.java:34)
org.eclipse.equinox.internal.provisional.p2.engine.Installab leUnitPhase.getActions(InstallableUnitPhase.java:117)
org.eclipse.equinox.internal.provisional.p2.engine.Phase.mai nPerform(Phase.java:111)
org.eclipse.equinox.internal.provisional.p2.engine.Phase.per form(Phase.java:79)
org.eclipse.equinox.internal.provisional.p2.engine.Installab leUnitPhase.perform(InstallableUnitPhase.java:53)
org.eclipse.equinox.internal.provisional.p2.engine.Phase.per form(Phase.java:46)
org.eclipse.equinox.internal.provisional.p2.engine.PhaseSet. perform(PhaseSet.java:38)
org.eclipse.equinox.internal.provisional.p2.engine.Engine.pe rform(Engine.java:53)
org.eclipse.equinox.internal.p2.director.SimpleDirector.prov ision(SimpleDirector.java:78)
org.eclipse.equinox.internal.p2.installer.InstallUpdateProdu ctOperation.doInstall(InstallUpdateProductOperation.java:120 )
org.eclipse.equinox.internal.p2.installer.InstallUpdateProdu ctOperation.install(InstallUpdateProductOperation.java:212)
org.eclipse.equinox.internal.p2.installer.ui.InstallDialog$7 .run(InstallDialog.java:437)
Re: Equnox installer [message #126661 is a reply to message #126623] |
Sat, 28 February 2009 13:31  |
Most of the work in 3.4.2 was focused on robustness issues around the
reconciler, but there was no explicit effort on performance. Btw, what is
the link the N&N ?
If you happen to have steps for the logs below please open a bug
report. Thx
I have been able to update from 3.4.1 to 3.4.2 and then installed some
more stuffs.
FUDForum. Page generated in 0.11711 seconds
