| Execution of any testsuite fails - InactiveProcessException [message #126511] |
Mon, 17 March 2008 04:15  |
Steps To Reproduce:
1. Install tptp.runtime.allInOne-4.5.0M5 (on Win XP SP2)
2. Install cosmos-sdk-incubation-COSMOS-1.0.0-200802131535
3. Checkout
org.eclipse.cosmos/tests/data-collection/org.eclipse.cosmos. dc.cmdbf.services.tests
from dev.eclipse.org, /cvsroot/technology
4. Right click any testsuite (eg: TestQueryInputTransformer.testsuite) in
junits folder
5. Runs as -> Test
6. Hangs at 36% and fails with the error:
IWAT4039E The Test Execution Harness reported the following
problems:org.eclipse.hyades.internal.execution.local.control .InactiveProcessException
Note: org.eclipse.cosmos.dc.cmdbf.services.tests plug-in has a dependency
on
org.eclipse.cosmos.common.tests. Please checkout the same from
org.eclipse.cosmos/tests/common in same repository
More information:
Tried with both Sun & IBM java 1.5. Also tried cleaning and refreshing the
workspace and restarting eclipse/OS. Also tried with
tptp.runtime.allInOne.win32.win32.x86-TPTP-4.4.1, but same error.
But the junit can be executed successfully by right clicking and running
the
java file in src folder.
I have also reported a bug for the same
https://bugs.eclipse.org/bugs/show_bug.cgi?id=222382
Has anyone come across a similar situation before? Is this a setup
problem? For eg: a dependency missing, something has to be running while
executing test suite, firewall is blocking something etc...
| Re: Execution of any testsuite fails - InactiveProcessException [message #128927 is a reply to message #127283] |
Wed, 23 April 2008 06:33  |
Bobby,
Are you still have problems running your test suite from the command
line?
Paul
"Bobby" <bobbyjoseph@in.ibm.com> wrote in message
news:fsah1v$5nl$1@build.eclipse.org...
> Thanks DuWayne.
> I tried setting up tptp.runtime.allInOne.win32.win32.x86-TPTP-4.5.0M5 on
> another machine, and it is now working from eclipse with no problems.
> I don't remember doing anything different though.
> Anyway, I am trying to execute the same testsuite now from command line
> using the automation-client-adapter.bat and got stuck with the following
> error:
> C:\Bobz\workarea\tptp.runtime.allInOne.win32.win32.x86-TPTP- 4.5.0M5\eclipse\plugins\org.eclipse.hyad
> es.execution_4.4.100.v200801150400>java -cp
> ./bin;tptp-automation-client.jar org.eclipse.hyades.auto
> mation.client.adapters.shell.AutomationClientAdapter -configfile
> cosmos.config
> org.eclipse.hyades.test.tools.core.execute
> java.lang.Exception
> at
> org.eclipse.hyades.automation.server.ServiceProxy.<init>(ServiceProxy.java:100)
> at
> org.eclipse.hyades.automation.server.AutomationServer.run(Au tomationServer.java:254)
> at
> sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:85)
> at
> sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:58)
> at
> sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:60)
> at java.lang.reflect.Method.invoke(Method.java:391)
> at
> org.eclipse.equinox.internal.app.EclipseAppContainer.callMet hod(EclipseAppContainer.java:547)
> at
> org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:195)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:106)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:76)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:362)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:175)
> at
> at
> at
> at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 564)
> at org.eclipse.equinox.launcher.Main.basicRun(Main.java:504)
> at org.eclipse.equinox.launcher.Main.run(Main.java:1251)
> This is the content of the config file (cosmos.config):
> eclipse =
> workspace =
> C:\Bobz\workarea\tptp.runtime.allInOne.win32.win32.x86-TPTP- 4.5.0M5\new_workspace
> suite =
> C:\Bobz\workarea\tptp.runtime.allInOne.win32.win32.x86-TPTP- 4.5.0M5\workspace\org.eclipse.cosmos.dc.cmdbf.services.tests \junits\TestQueryInputTransformer.testsuite
> classpath =
> C:\Bobz\workarea\tptp.runtime.allInOne.win32.win32.x86-TPTP- 4.5.0M5\workspace\org.eclipse.cosmos.common.tests;C:\Bobz\wo rkarea\tptp.runtime.allInOne.win32.win32.x86-TPTP-4.5.0M5\wo rkspace\org.eclipse.cosmos.dc.cmdbf.services.tests;..\org.ec lipse.hyades.logging.core_4.3.200.v200801240400/common.runne r.jar;..\org.eclipse.hyades.logging.core_4.3.200.v2008012404 00/http.hexrecr.jar;..\org.eclipse.hyades.logging.core_4.3.2 00.v200801240400/http.hextgen.jar;..\org.eclipse.hyades.logg ing.core_4.3.200.v200801240400/http.runner.jar;..\org.eclips e.hyades.logging.core_4.3.200.v200801240400/java.runner.jar; ..\org.eclipse.hyades.logging.core_4.3.200.v200801240400/man ual.runner.jar;.\org.eclipse.hyades.logging.core_4.3.200.v20 0801240400/tools-core.jar;
> vmargs = -Xquickstart
> Any pointers would be really helpful. How do I find more information about
> the error? Is there any log I can look for more info?
> Thanks in advance...
> Bobby
> "DuWayne Morris" <dmorris@us.ibm.com> wrote in message
> news:67685c6febec2ecdb57d0756eeffabf9$1@www.eclipse.org...
>> In general, the InactiveProcessException means that the session JVM
>> kicked off the test runner java process, which then immediately died.
>> Typically, this problem is due to missing items in the classpath for the
>> test to execute such that the runner failed to start. I have existing
>> defects to improve the error messages to the user.
>> DuWayne
FUDForum. Page generated in 0.05988 seconds
