Home » Modeling » BPEL Designer » ExtensionPoint for Tabbed Properties question
ExtensionPoint for Tabbed Properties question [message #11560] Sun, 22 March 2009 12:01 Go to next message
I recently created some ExtensionActivity elements for BPEL and have
successfully imported them into the eclipse BPEL designer.
Also, adding them to the palette was no problem.
Now I want to be able to change some properties of that extension activity
objects. To do so, I planned to extend the
org.eclipse.ui.views.properties.tabbed.propertyTabs / propertySection
extension points of the BPEL Designer.
Now, when I deploy the plugin and load an BPEL File into the BPELEditor,
nothing is added to the properties view (no tabs, now sections).
As the documentation on the BPEL Designer Homepage is terribly out of date
(last change 2005!!!), I'm asking here in this newsgroup for help.
What am I doing wrong? Any help is appreciated.
greets
Chris
Re: ExtensionPoint for Tabbed Properties question [message #11739 is a reply to message #11560] Fri, 17 April 2009 13:13 Go to previous messageGo to next message
anyone here?
Re: ExtensionPoint for Tabbed Properties question [message #479473 is a reply to message #11560] Tue, 11 August 2009 05:43 Go to previous message
May you try Equinox Aspects?
Luke
Previous Topic:Eclipse 3.5 -> javax.wsdl 1.5
Next Topic:Invoking Drools Rules Engine from GMF
Current Time: Wed Nov 05 18:29:03 EST 2025
Powered by FUDForum. Page generated in 0.03361 seconds
