Home » Eclipse Projects » Eclipse Platform » properties vs. resources
properties vs. resources [message #126019] Tue, 09 September 2003 15:01 Go to next message
Originally posted by: ThisisFake.Fakeness.xyz
Still working on my database based application.
Wondering if my database connection information should be a property or a
resource. That is, should I put the DB values as property on the project
resource? or should I create my own file, and put the db values in that
file?
seems like if I use a property on the project, then it will not be easy
to package up my project because some of the projects info will be in the
..metadata file. seems like properties would be excellent for something
like build status which is not important to transfer when you move a
project.
Am I in the right line of thinking here?
Thanks once again,
CL
Re: properties vs. resources [message #126296 is a reply to message #126019] Wed, 10 September 2003 05:50 Go to previous message
Hi gilbert,
> file?
> project.
I think so. Properties are logically linked with the plugin. You can specify
default values (by code). If you change something the change will only
saved within the current workspace. Change the workspace and the
new workspace will denie do know anything about your change property.
(you are right its in the .metadata directory and therefore the new
workbench
will have a diffrent one.)
So if you can provide default connection settings you may run for a
property.
The user may change your properties easily by using a property sheet.
If you save it as a resource you may move your project/plugin. But think
about
it. Why should someone move the plugin? What if someone expects to move
projects around? (meaning using your application not developing it). And
remember
a plugin has only one directory within every workbench its installed in. So
if you
have two users, one types Jon Doe and the other user changes the login to
Joan Doe (uses another worbench within the same mashine). Now Jon Doe hits
connect and is logged in as Joan Doe?! Strange wouldn't it be?
I think login and connection informations should be placed as
properties/mementos
for sure.
Ca
Martin (Kersten)
Previous Topic:NullPointerException when launching ANT with custom task
Next Topic:problem launching Eclipse with the j9 VM
Current Time: Fri Jul 25 01:51:48 EDT 2025
Powered by FUDForum. Page generated in 1.24762 seconds
