Home » Language IDEs » C / C++ IDE (CDT) » Managed Build: Clock skew problem. Please help
Managed Build: Clock skew problem. Please help [message #126015] Thu, 04 November 2004 14:53 Go to next message
Hi, all:
I think this probably not an Eclipse cdt problem, since nobody asked this
before. Could somebody give some hints?
I tried the Eclipse 3.0.1 with CDT 2.0.2, and use the managedmake to
create C project.
My problem is:
Whenever I clean and rebuild the project, there is always time skew
warnining (see below, but it did build everything with the annoying
warning). However, when I run make over the generated makefile directly,
there is no time skew warning.
Any hints?
-Chengdong
The time skew warning:
**** Full rebuild of configuration Debug for project ManagedMakeCProject
make -k clean all
make: *** Warning: File `objects.mk' has modification time in the future
(2004-11-04 11:52:53 > 2004-11-04 11:52:51.00083)
rm -rf main.o main.d ManagedMakeCProject
Building file: ../main.c
gcc -O0 -g3 -Wall -c -fmessage-length=0 -o main.o ../main.c
Finished building: ../main.c
Building target: ManagedMakeCProject
gcc -o ManagedMakeCProject main.o
make: warning: Clock skew detected. Your build may be incomplete.
Finished building: ManagedMakeCProject
Build complete for project ManagedMakeCProject
Re: Managed Build: Clock skew problem. Please help [message #126041 is a reply to message #126015] Thu, 04 November 2004 16:33 Go to previous message
There is a difference between my local machine and file sever machine.
Install time server, then fixed.
-chengdong
chengdong wrote:
> Hi, all:
> create C project.
> My problem is:
> Any hints?
> Thanks
> -Chengdong
> make -k clean all
Previous Topic:Debugger inconsistent STEP INTO behavior
Next Topic:Help with Refactor
Current Time: Mon Oct 27 11:42:02 EDT 2025
Powered by FUDForum. Page generated in 0.05089 seconds
