Can I use VE to make RCP applications for Eclipse? [message #125992] |
Sat, 10 June 2006 15:29  |
Originally posted by: bnegrao.gmail.com
hi guys,
I'm starting with eclipse plugin development and I need to do a complex
GUI as an RCP application using eclipse's RCP framework as base.
I'd like to know if it's possible to use VE to develop my plugin, at least
the some of the graphical components.
thank you,
bruno
Re: Can I use VE to make RCP applications for Eclipse? [message #126302 is a reply to message #126291] |
Thu, 15 June 2006 18:29   |
Originally posted by: richkulp.us.NO_SPAM.ibm.com
What versions of Eclipse, VE, EMF, and GEF do you have?
What is in the .log file?
What does "create a new Visual Class, nothing happens" mean? Does it
mean there is no menu, does it mean the create wizard won't come up?
Does it mean the create wizard crashes?
Bruno wrote:
> Thanks Jeff,
> But when I create a plugin, and try to open the View.java(which extends
> ViewPart) class with the Visual Editor i receive the following errors:
> An internal error occurred during: "Create Remote VM for Visual Editor
> for Java".
> for Java".
> It seems the visual editor cannot guess how to render my program in the
> WYSIWYG editor.
> Also, if I already have a plugin project and then click over a package
> name (using the Package Explorer view) and then i try to create a new
> Visual Class, nothing happens. So i definately cannot use VE to do
> plugin development.
> Do you have any tip?
> thank you,
> bruno.
Rich Kulp
Re: Can I use VE to make RCP applications for Eclipse? [message #613333 is a reply to message #125992] |
Mon, 12 June 2006 09:29  |
Bruno,
Yes, you can use the VE to help you develop the grapical components of
your plug-in. VE supports the visual development of EditorParts and
ViewParts, Composites that can be embedded within your app, and UIs
using the Forms toolkit.
Hope this helps,
- Jeff
bruno wrote:
> hi guys,
> least the some of the graphical components.
> thank you,
> bruno
Re: Can I use VE to make RCP applications for Eclipse? [message #613354 is a reply to message #126016] |
Thu, 15 June 2006 17:36  |
Thanks Jeff,
An internal error occurred during: "Create Remote VM for Visual Editor for
Java".
for Java".
WYSIWYG editor.
Visual Class, nothing happens. So i definately cannot use VE to do plugin
development.
thank you,
bruno.
Re: Can I use VE to make RCP applications for Eclipse? [message #613355 is a reply to message #126291] |
Bruno wrote:
> Thanks Jeff,
> for Java".
> for Java".
> WYSIWYG editor.
> plugin development.
> thank you,
> bruno.
Rich Kulp
Re: Can I use VE to make RCP applications for Eclipse? [message #613361 is a reply to message #126302] |
Fri, 16 June 2006 19:43  |
Eclipse 3.1.2
VE 1.1.0
EMF 2.1.0
GEF 3.1.1
> Does it mean there is no menu, does it mean the create wizard
> won't come up? Does it mean the create wizard crashes?
I had a progress now. When I tryed to create a new visual class for my
existing pluging project and the wizard appears. Then i select the "RCP"
style and make "org.eclipse.ui.part.ViewPart" the superclass. When I
click in "Finish" I receive those errors I said before.
All this stuff bellow.
!ENTRY org.eclipse.ui 4 4 2006-06-16 20:33:14.218
!MESSAGE Unhandled event loop exception
!ENTRY org.eclipse.ui 4 0 2006-06-16 20:33:14.234
!MESSAGE org/eclipse/pde/internal/core/PDECore
!STACK 0
java.lang.NoClassDefFoundError: org/eclipse/pde/internal/core/PDECore
org.eclipse.jem.internal.proxy.core.PDEProcessForPlugin.find Plugins(PDEProcessForPlugin.java:38)
org.eclipse.jem.internal.proxy.core.ProxyPlugin.findPlugins( ProxyPlugin.java:999)
org.eclipse.jem.internal.proxy.core.ProxyPlugin.expandProjec t(ProxyPlugin.java:961)
org.eclipse.jem.internal.proxy.core.ProxyPlugin.getIDsFound( ProxyPlugin.java:901)
org.eclipse.ve.internal.java.codegen.wizards.NewVisualClassW izardPage.handleFieldChanged(NewVisualClassWizardPage.java:3 07)
org.eclipse.jdt.ui.wizards.NewContainerWizardPage.containerD ialogFieldChanged(NewContainerWizardPage.java:291)
org.eclipse.jdt.ui.wizards.NewContainerWizardPage.access$1(N ewContainerWizardPage.java:286)
org.eclipse.jdt.ui.wizards.NewContainerWizardPage$ContainerF ieldAdapter.dialogFieldChanged(NewContainerWizardPage.java:2 73)
org.eclipse.jdt.internal.ui.wizards.dialogfields.DialogField .dialogFieldChanged(DialogField.java:70)
org.eclipse.jdt.internal.ui.wizards.dialogfields.StringDialo gField.setText(StringDialogField.java:162)
org.eclipse.jdt.ui.wizards.NewContainerWizardPage.setPackage FragmentRoot(NewContainerWizardPage.java:421)
org.eclipse.jdt.ui.wizards.NewContainerWizardPage.initContai nerPage(NewContainerWizardPage.java:146)
org.eclipse.jdt.ui.wizards.NewClassWizardPage.init(NewClassW izardPage.java:88)
org.eclipse.ve.internal.java.codegen.wizards.NewVisualClassC reationWizard.addPages(NewVisualClassCreationWizard.java:403 )
org.eclipse.jface.wizard.WizardSelectionPage.getNextPage(Wiz ardSelectionPage.java:110)
org.eclipse.ui.internal.dialogs.WorkbenchWizardSelectionPage .getNextPage(WorkbenchWizardSelectionPage.java:99)
org.eclipse.jface.wizard.WizardDialog.nextPressed(WizardDial og.java:747)
org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDi alog.java:345)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.jav a:556)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:90)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:843)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3125)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2758)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:809 )
at org.eclipse.jface.window.Window.open(Window.java:787)
at org.eclipse.ui.actions.NewWizardAction.run(NewWizardAction.j ava:181)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:996 )
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:538)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:488)
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:400)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1699)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1663)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:367)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
!ENTRY org.eclipse.ve.java.core 4 16 2006-06-16 20:34:30.625
!MESSAGE An internal error occurred during: "Create Remote VM for Visual
Editor for Java".
!STACK 1
org.eclipse.core.runtime.CoreException[2]: java.lang.NoClassDefFoundError:
org.eclipse.jem.internal.proxy.core.ProxyLaunchSupport.creat eDefaultConfigurationContributionInfo(ProxyLaunchSupport.jav a:497)
org.eclipse.jem.internal.proxy.core.ProxyLaunchSupport.fillI nLaunchInfo(ProxyLaunchSupport.java:530)
org.eclipse.jem.internal.proxy.core.ProxyLaunchSupport.start Implementation(ProxyLaunchSupport.java:396)
org.eclipse.jem.internal.proxy.core.ProxyLaunchSupport.start Implementation(ProxyLaunchSupport.java:304)
org.eclipse.jem.internal.proxy.core.ProxyLaunchSupport.start Implementation(ProxyLaunchSupport.java:236)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorVMController$CreateRegistry.run(JavaVisualEditorVMContro ller.java:184)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:76)
!SUBENTRY 1 org.eclipse.core.runtime 4 2 2006-06-16 20:34:30.625
Editor for Java".
!STACK 0
!ENTRY org.eclipse.core.runtime 4 2 2006-06-16 20:34:30.625
Editor for Java".
!STACK 0
!ENTRY org.eclipse.jem.beaninfo 2 0 2006-06-16 20:34:32.62
!MESSAGE IWAV0155E Introspection failed on class "java.lang.Object."
msg="."
!STACK 0
org.eclipse.jem.internal.beaninfo.core.BeaninfoPlugin.getOve rridePaths(BeaninfoPlugin.java:488)
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoClassAdap ter.createOverrideCache(BeaninfoClassAdapter.java:992)
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoClassAdap ter.applyExtensionDocument(BeaninfoClassAdapter.java:962)
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoClassAdap ter.introspect(BeaninfoClassAdapter.java:695)
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoClassAdap ter.introspectIfNecessary(BeaninfoClassAdapter.java:474)
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoClassAdap ter.introspectIfNecessary(BeaninfoClassAdapter.java:461)
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoClassAdap ter.introspect(BeaninfoClassAdapter.java:682)
org.eclipse.jem.java.impl.JavaClassImpl.getEAnnotations(Java ClassImpl.java:387)
org.eclipse.ve.internal.cde.emf.ClassDecoratorSourceIterator .findDecorator(ClassDecoratorSourceIterator.java:37)
org.eclipse.ve.internal.cde.emf.ClassDecoratorIterator.initi alize(ClassDecoratorIterator.java:47)
org.eclipse.ve.internal.cde.emf.ClassDecoratorSourceIterator . <init>(ClassDecoratorSourceIterator.java:33)
org.eclipse.ve.internal.cde.emf.ClassDecoratorFeatureAccess. getDecoratorWithFeature(ClassDecoratorFeatureAccess.java:67)
org.eclipse.ve.internal.java.codegen.java.rules.DefaultVisit orFactoryRule.retrieveFromCache(DefaultVisitorFactoryRule.ja va:82)
org.eclipse.ve.internal.java.codegen.java.rules.DefaultVisit orFactoryRule.getTypeVisitor(DefaultVisitorFactoryRule.java: 109)
org.eclipse.ve.internal.java.codegen.java.JavaBeanModelBuild er.visitType(JavaBeanModelBuilder.java:508)
org.eclipse.ve.internal.java.codegen.java.JavaBeanModelBuild er.build(JavaBeanModelBuilder.java:417)
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.reverseParse(JavaSourceTranslator.java:832)
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.decodeDocument(JavaSourceTranslator.java:914)
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.loadModel(JavaSourceTranslator.java:575)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$Setup.run(JavaVisualEditorPart.java:1881)
"org.eclipse.ui.part.WorkbenchPart." msg="."
!STACK 0
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoClassAdap ter.applyExtensionDocument(BeaninfoClassAdapter.java:972)
!ENTRY org.eclipse.jem.beaninfo 2 0 2006-06-16 20:34:32.78
"org.eclipse.ui.part.ViewPart." msg="."
!STACK 0
!ENTRY org.eclipse.jem.beaninfo 2 0 2006-06-16 20:34:32.109
msg="."
!STACK 0
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoNature.cr eateRegistry(BeaninfoNature.java:470)
org.eclipse.jem.internal.beaninfo.adapters.CreateRegistryJob Handler.doCreateRegistry(CreateRegistryJobHandler.java:159)
org.eclipse.jem.internal.beaninfo.adapters.CreateRegistryJob Handler.processCreateRegistry(CreateRegistryJobHandler.java: 114)
org.eclipse.jem.internal.beaninfo.adapters.UICreateRegistryJ obHandler.processCreateRegistry(UICreateRegistryJobHandler.j ava:52)
org.eclipse.jem.internal.beaninfo.adapters.CreateRegistryJob Handler.createRegistry(CreateRegistryJobHandler.java:80)
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoNature.ge tRegistry(BeaninfoNature.java:451)
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoNature$6. getRegistry(BeaninfoNature.java:318)
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoAdapterFa ctory.getRegistry(BeaninfoAdapterFactory.java:78)
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoClassAdap ter.getRegistry(BeaninfoClassAdapter.java:344)
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoClassAdap ter.introspect(BeaninfoClassAdapter.java:767)
org.eclipse.ve.internal.cde.emf.ClassDecoratorIterator.findN ext(ClassDecoratorIterator.java:76)
org.eclipse.ve.internal.cde.emf.ClassDecoratorIterator.initi alize(ClassDecoratorIterator.java:49)
!STACK 0
!ENTRY org.eclipse.jem.beaninfo 2 0 2006-06-16 20:34:32.156
msg="."
!STACK 0
org.eclipse.ve.internal.cde.emf.ClassDecoratorIterator.findN ext(ClassDecoratorIterator.java:78)
!ENTRY org.eclipse.ve.java.core 4 0 2006-06-16 20:34:32.156
!MESSAGE Exception thrown.
!STACK 0
org.eclipse.ve.internal.java.codegen.java.rules.DefaultVisit orFactoryRule.retrieveFromCache(DefaultVisitorFactoryRule.ja va:83)
thank you
Re: Can I use VE to make RCP applications for Eclipse? [message #613364 is a reply to message #126377] |
Mon, 19 June 2006 09:54  |
You need to have Eclipse SDK installed, not the runtime. You seem to be
missing PDE.
By the way, I would run update and pick up the VE 1.1.0.1. That is the
latest for VE 1.1 and has many fixes in it.
> Eclipse 3.1.2
> VE 1.1.0
> EMF 2.1.0
> GEF 3.1.1
> !STACK 0
> at
> at
Rich Kulp
Re: Can I use VE to make RCP applications for Eclipse? [message #613372 is a reply to message #126484] |
Tue, 20 June 2006 09:21  |
We use the PDE to process your Plugin's classpath. Without the PDE we
can't do that.
I don't know anything aoubt easyeclipse. I use only the Eclipse SDK from
the eclipse site itself.
The source for Eclipse is contained in the Eclipse SDK from the Eclipse
download site.
Bruno wrote:
> I also installed http://www.easyeclipse.org/site/plugins/eclipse-sdk.html
> but on that page there's a note saying:
> "Note that this does not contain the entire "Eclipse SDK" as defined on
> the eclipse.org website; it only contains the elements that are not
> present in the platform or in the JDT."
> do you think this can be the reason? Why would the source code affect VE
> functioning?
> thank you,
> bruno
Rich Kulp
FUDForum. Page generated in 0.06457 seconds
